Question about Panasonic Cameras
CAMERA DOESNT POWER UP BOUGHT A NEW BATTERY AND CHARGED IT UP THINKING THAT IT MIGHT BE THAT BUT STILL NO GO
WONT POWER UP
  • 1,162 Answers
This is common with some units if they are left a long time in a bag or not used sometimes the camera goes bad. I had this happen to a Nikon. Had to replace camera. Cheaper that way. Now it could be you did not install battery correctly, or the switch needs cleaning. I took one apart once an cleaned with contact cleaner an it worked fine. Which Panasonic is it?
Posted on Mar 24, 2014
  • Amanda Gaskin
    Amanda Gaskin Mar 24, 2014
    IT IS A LUMIX L10
  • cwradio73 Mar 24, 2014
    To nice a camera to replace. I would look for a camera shop an see price first before doing anything. Unless you can take one apart. It is a quest to do it but I had good success. It could be simple or a death as in my Nikon. Keep on mind if workman say a chip on the board is bad it is going to be costly.
markevans
  • 148 Answers
SOURCE: xti wont power up
appears to be a defect and not user serviceable.
sorry for the news.
good luck.
mark.
Posted on Dec 24, 2007
mcomijohns
  • 477 Answers
SOURCE: Wont Turn on at all - Casio Ex-z750
Contact the person @ www.digitalcamrepair.com he can repair it for you.
Posted on Jun 12, 2008
  • 11967 Answers
SOURCE: My kodak M893IS will not turn on. It tries to and
Sounds like a lens problem. Try these... Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Mar 29, 2010
  • 11967 Answers
SOURCE: no power - fully charged battery
How about cleaning the battery contacts in the camera first with a pencil eraser and then, with a cotton swab lightly dampened with rubbing alcohol.
Posted on Aug 02, 2010
potteryqueen
  • 5 Answers
SOURCE: The camera won't power on with a brand new freshly
Problem is likely a loose screw in the camera which is common on the G7 and the G9 Canon cameras. You'll want a place that not only fixes the problem but does the internal fix to the screws so it won't happen again. The place that is great for help with this problem is: www.camerasandparts.com All they work on our Powershots and they don't charge much at all. Plus you get the service with them included for the camera and the fix done too. If you need help with one of these, they're wonderful. Good luck with it.
Posted on Sep 16, 2011
Roomba 4106 new battery charged but wont start
see the diodes, resistor, capacitor inside for test.
since the battery is new, the power charger is faulty, power regulator IC is bad.
God bless you
May 16, 2012 | Roomba 3005 Pro Robotic Vacuum
No power - fully charged battery
Aug 02, 2010 | Canon Rebel XT / EOS 350D Digital Camera
I own a Sony DCR-HC47E Handycam.It will not turn on
i have a problem with my sony dcr-sr47 camcorder it wont charge the battery camera works fine with power supply any solutions.
Dec 15, 2009 | Sony DCR-SR47 Camcorder
My Nikon Coolpix 8700 wont turn on!
Try another battery. Even though you bought a new battery and charged it doesn't mean it is not bad.
Jul 17, 2009 | Cameras
Fuji F10 No power
You said that you changed the battery, did you put it in the right way around?.
I had exactly the same trouble, changed the battery (got it on ebay for £2.99) charged it and it worked.
Having said that, I closed the lense from external power. If the camera wont operate from external power then the camera is probably dead.
Sep 13, 2008 | Fuji FinePix F10 Digital Camera
D40 will not power up
When a charged battery is installed, the card access led on the back of the camera should blink once. If it doesnt, try resetting the camera with the small microswitch on the bottom of the camera body (opposite side from battery compartment). Failing those, have a Nikon shop look at it.
May 10, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Rechargeable Battery won't charge
I think this is a general Fuji design fault in the camera circuitry. I have an older F455 which has exactly the same problem and I did the same - bought new batteries only to discover that didn't help. The only solution is to spend even more money for a stand alone battery charger.
Sep 07, 2006 | Fuji FinePix A340 Digital Camera
Cameras Logo
24 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
