Question about Husqvarna EZ4824 24 hp 48" Zero Turn Lawn Mower
Oil light goes I filled it with oil but it won't run
Oil light still on
  • 1,162 Answers
Could be a bad sensor.
Posted on Mar 27, 2014
Oil capacity
just fill it till it hits the level mark, then crank it till oil light goes out, then recheck after runs for a few seconds, to level in sight glass.
Jan 20, 2014 | 2000 Suzuki GSX 1300 R Hayabusa
Oil min light keeps coming on
What kind of oil? Is its not synthetic it's wrong...the Audi engines have a small oil pickup tube and the cheap oil gunks up the engine and clogs pump screen causing light to come on eventually engine failure....you need to flush engine ....you can use kerosine or go to parts store and tell them you want to clean the internals of gunk ...pour in engine oil let run for few min drain oil ...buy cheap oil for this do same thing 3 times ...when light goes off your done fill with fully synthetic oil and you just saved your engine ...only synthetic oil
Jan 11, 2014 | 2001 Audi A4
Won't stay running
All mowers have a low oil sensor, fill oil with 30w.
Jul 04, 2012 | Troy Garden
Oil light goes on and off
That's really bad ... First of all check oil level when its cold... The clanking sounds are your valves running dry. This will cause massive damage the heads. If you oil is low fill it back up & check the engine for leaks & hope there is not valve damage. If the oil was low and you filled it & you still get the clanking noise the valves are permanently damaged & the head/heads & valves will need to be replaced.. Big costs
Feb 05, 2012 | 2005 Nissan Almera 1.8
I just got an oil change in my 2003 vw jetta. The next day my oil light started flashing and beeping and won't stop. Should I be worried??
yes- check your oil level - sounds like they didn't fill completely or something is loose and leaking oil out
May 24, 2011 | 2003 Volkswagen Jetta TDI
2000 saab 95 wagon,2.3t. oil pressure light came on. checked and filled oil, about 2 quarts. light did not go out. driving on highway, car shut down when check engine light came on. now car will only run...
Oil pressure sensor blocked or faulty. both oil level sensor and oil pressure sensor activate the oil light. engine goes into safe mode and shuts off ignition.
Mar 04, 2018 | Saab 9 5 Cars & Trucks
Harley davidson flstc heritage softail 1997
The fork oil is a very specific job needing a manual and a special tool, I don't want to insult anyones mechanical knowledge but if you have never done it before, best to take somewhere else. Engine oil on the other hand is easy, the drain tube to any softail is on the right side by where the frame meets the swing arm, has somekind of plug in it. Start and run bike for a little while, long enough to get it warm but not hot. Remove fill plug and then remove plug in drain line. Using a peice of cardboard or something put in between filter and frame , directing the oil to your drain pan instead of where ever it goes. Put 1 qt oil back in (after everything is reinstalled) start the bike and make sure the oil light goes out, when it does shut bike off and fill to the point that when it is standing upright you get a little oil on the tip of your finger, over filling may result in loss of oil cap from pressure (been there)
Jun 15, 2009 | Harley Davidson FLSTC Heritage Classic...
Husqvarna EZ4824 24 hp 48" Zero Turn Lawn Mower Logo
43 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
