Question about Yamaha RX-V575
No HDMI video using RX-V575 Yamaha Receiver with Panasonic TV C-P60ST30
I run the HDMI outputs from my Directv box and Sony Blu-Ray player into the back of the Yamaha receiver, then run the HDMI out from the receiver to the HDMI1 (ARC) input on my Panasonic TV. I get audio to work ok, but no video with either my Directv or Blu-Ray selected. I have the right HDMI input set on the receiver when I'm trying each device, and as I said I'm getting the audio, but the TV just has a "No signal...." message displayed all the time. The TV is set to the HDMI1 input as it should be. Is there some problem with the receiver passing the HDMI through? Previously I had these same devices using the same HDMI cables hooked into the back of my TV and video is fine. I bought one new HDMI cable when I bought the receiver to connect from the back of my receiver to TV...it says it supports 3D, ARC, 4k, 1080P etc...it wasn't a really cheap cable. I've tried another cable I had laying around that's also decent quality and I get the same thing. Not sure why the Yamaha wouldn't support basic HDMI pass through functionality.
    Master:
  • 966 Answers
Michael, I still think it is a connection problem. Try disconnecting the HDMI and see if you get the video. If no, it is a connection problem. Check the connections carefully.
Posted on Mar 24, 2014
  • Michael Wilson
    Michael Wilson Mar 24, 2014
    Hi...can you explain what you mean? I'm not getting video now with the HDMI connected. What do you expect to happen when I disconnect the HDMI? This really is a very basic setup, and the quick setup guide from Yamaha is easy to understand and I'm connected exactly like they say to do. I'm just surprised after not getting video and googling this how many folks seem to have the same problem with many different Yamaha receivers. Seems like the main recommendation is to not use the HDMI through the receiver and instead plug directly to the TV, then use fiber audio. That of course works fine and is what I'm doing now until I figure this out. I'd like to get the HDMI to work though so that I have everything HDMI controlled. Thanks, Mike
  • Ryan
    Ryan Apr 01, 2014
    I'm having the exact same issues
  • 1894 Answers
SOURCE: Connecting a YAMAHA RX-V2700 receiver to my TV and cable box
why not you use a normal AV cable
instead of hdmi cable
Posted on May 22, 2008
  • 151 Answers
SOURCE: Yamaha RX-V363 input settings
HI,you are not getting picture because the yam 363 dose not upscale or convert the picture from the composite input to hdmi.You will have to put a video cable from the composite out put on the amp to a scart convertor into the tv or put console picture into the tv and sound to the amp.
hope this helps.
CABLE GUY.
Posted on Jul 17, 2008
avenger77
SOURCE: Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
Solved problem with Yamaha HTR-6040 AV Receiver. My daughter had inadvertently changed the program to "Direct Stereo" mode which allows sources to bypass the decoders and DSP processors so you can listen to 2-Channel PCM and Analog sources. Nothing to decode digital audio in this setting!
Posted on Aug 10, 2008
SOURCE: Audio but no video from Sony Blu-Ray w/ HDMI hookup to RX-V663
Okay...my first contribution to any forum but I have the same problem (Yamaha RX-V663 and Samsung Blu Ray) and found the solution. The problem is you probably have your HDMI cables from your DVD player and reciever connected to a DVI input on your TV. The DVI may have problems communicating--not HDCP compliant. My system was working great then I hit a button on my remote...just playing around. I think it was the pure audio and I turned off the receiver. After that, the audio worked but there was no video. After many frustrating hours, the fix was to unplug the HDMI and DVI cable then turn the power off, cycle the power again, and plug the HDMI and DVI cables back in (the DVI was the last cable plugged in, not sure if that matters). By unplugging everthing you've reset the communication between the HDMI components and the DVI TV.
See page 18 of the yamaha owners manual, second to last note on bottom right of the page. It says there may be a problem...
I also noticed that the yamaha reciever was sending 1080p (my older tv is 1080I) and that is why the video wouldn't display on the TV. You can see this in the video signal info screen, unfortunately there is no setting to switch it back, just recycle the cables and power and it should reset.
Uncredibly frustrating but I got my picture back!
Jason
Posted on Jan 10, 2009
gymhasafit
  • 31 Answers
SOURCE: 8' Optical Cable from TV to Receiver and Signal is Breaking Up
Before you buy anything try checking the AUDIO Settings in the Menu of Each Device (Mostly TV) and see if they are set to PCM or BITSTREAM. HDMI is mostly set to PCM while Optical is generally Bitstream. The TV may be set to the opposite of what it needs to be. I would try to get PCM to work first cause it is Better, If not then set what you can to Bitstream and it should pass. Also check in TV Menu for SOUND OUT or AUDIO OUT or SPEAKERS. Some TV's have a problem passing Audio through when they are already Outputting them to it's own Speakers! I Hope this Helps out!
Posted on May 05, 2009
Yamaha RX-V595 Receiver will play Dolby Digital 3/2.1 audio Blu-Ray disc with player set to bitstream but will not play DTS-HD 3/2.1 unless output is set to PCM. Is this an issue with the Yamaha Recei
The optical connection (SPDIF) doesn't have enough bandwidth to transfer DTS-HD audio. To use DTS-HD, you must connect the blue-ray player and receiver via HDMI cable.
Each DTS-HD audio track on blue-ray includes also "normal" DTS audio, which is probably used when you select PCM. Player decodes it and sends decoded (non-HD) audio via optical cable to receiver.
Nov 17, 2014 | Yamaha RX-V595 Receiver
No Audio
cant use both hdmi and opti outs try sum setting in blue ray but u nee dto plug all blue ray dish directto samsung hdmi then 1 master digital out form tv to sterio digital i n ok tell samsung your output also
Jan 20, 2008 | Sony STR-DG510 Receiver
I have no video output on my yamaha rx-v575
so you have connected hdmi from your xbox to the receiver then from the hdmi monitor out of your receiver which is always number 1 on the hdmi row back to the tv. sound will be there cause you have speakers connected to the receiver. but you need to send a hdmi back to your tv. hope this helps
Jan 21, 2014 | Yamaha Audio Players & Recorders
When connecting hdmi out from my panasonic blue-ray player to the dvd input in my yamaha rx-v365 there is not audio or video,why?
There are several video and audio inputs named DVD. For video you have HDMI, component and composite. For audio you have standard analog stereo and digital coaxial spdif input.
You need to configure the receiver to use the correct inputs - that means HDMI and coax. Also you need to connect the BD player via coax spdif cable to the receiver, because rx-v365 doesn't support audio via HDMI. If BD player has only optical output, use DTV/CABL HDMI input and DTv/CABL Optical input on the receiver.
Nov 23, 2009 | Yamaha DVD-S661 HDMI DVD Player
Digital Audio cutting out
I have the same problem with my RX-V565 receiver. Did you get this fixed?
Albert
Oct 08, 2009 | Sony Playstation 3 (PS3) Console
I would like to hook up my components without having to turn on the receiver to watch tv from DVR or Cable if possible. I have Scientific Atlanta Explorer 8300 HD Cable DVR w/HDMI out, Samsung TV w/HDMI ,...
You should not lose any picture quality from the DVD player. I am currently having the similar setup with PS3 as the Blu-ray DVD player with HDMI and a Samsung DVD as regular player with component cable to a Samsung LCD TV. Remember the quality on Blu-ray is better than normal DVD so don't expect more than what it is.
Oct 07, 2009 | Yamaha RX-V463 Receiver
I have the LG Dn798 hooked up through my Yamaha receiver
Does it work via component or in a different HDMI port? If it does it sounds like either a bad HDMI input on the tv or a bad HDMI output on the receiver.
I would also verify that the receiver is 100% compliant with the HDMI standard as not all devices are.
Jun 03, 2009 | LG DN798
Hookup diagram for Yamaha avr-863 receiver
It's the other way around.
Hook up the Cable box to the Amp; and the blu-ray to the amp, then connect amp to LCD.
you want to use the best available options for audio:
HDMI > Digital Optical > Digital Coax > standard RCA
And the similar for video:
HDMI > Component > SVideo > RCA cables
I would connect Blu-Ray via HDMI to Amp, and Cable box via HDMI to Amp. If your cable box does NOT support HDMI, but you have an HD package, ask your cable company for an upgraded box.
Mar 19, 2009 | Yamaha RX-V463 Receiver
Want to add all of my video components to my rxv 663 reciever
The rx-v663 has 2 hdmi inputs, and 1 HDMI Outputs, The way I would run is 1 HDMI in dedicated to the Blu-ray, This will do the audio HD True digital, DTS-HD , then video out to the TV for HD 1080p resolution, On the cable box out do you have an HDMI 1.3? If so sport it to the other available receiver HDMI IN, net the same in/out as the blue ray, minus a 1080p result video which will only happen Blu-ray, cable will result 1080i HD and audio HD will vary with the signal broadcast format.
Feb 01, 2009 | Yamaha RX-V663 Receiver
Jason
Dec 01, 2008 | Yamaha RX-V663 Receiver
Yamaha RX-V575 Logo
254 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
