How do i find the print head cleaning function for my hp deskjet F4480
I cannot find the control panel for my HP deskjet F4480 so i can perform the print head cleaning function, any help with this problem will be appreciated
    Problem Solver:
  • 13 Answers
Hi everyone,
I am also faced this situation to find cleaning Print heads can get clogged if the printers have not been used in awhile or a print cartridge has been empty or stored for a long time. Clogs in print heads can cause problems with the print job quality. This article will tell you how to clean print heads. 5 ways clean print heads:
  • Open the control panel menu and select "printers."
  • Choose the printer to be cleaned and right click. Select "properties" in the drop-down menu.
  • Choose the tab for cleaning. Various printers might have it listed under different names such as services, cleaning or maintenance.
  • Select the nozzles that should be cleaned, if applicable to your printer, and run the printer's cleaning program.
  • Print a test page and check results. Repeat cleaning 2 to 3 times if needed.
HP Deskjet f4480 Printer Driver For Windows Free Download
Posted on Dec 19, 2014
  • 406 Answers
Hp deskjet D1663 Pulls papers non-stop and output is blank
Perform a head cleaning process in you printer, If it is not helping the print head is faulty, take it to service shop
Apr 22, 2014 | HP deskjet d1660 inkjet printer - color -...
Hp 4480 how do you unpause it
The HP F4480 likely has a malfunctioning ink cartridge which is causing the printer hang (i.e. internal micro-electronics damage inside the HP 60 color or black ink cartridge). You can verify the electrical condition of both HP 60 ink cartridges by activating the Tap 41 diagnostic test report (see video here for complete instructions):
http://inkjet411.com/?page_id=440 (HP 60 - Deskjet F2400/F4400/F4500 models)
    1.While holding the Power button, press Cancel (X) button 4 times, then press the Color Copy button once.
    2.Release the Power button.
    3.The 'Tap 41' diagnostic test print should print.
    Providing the color cartridge is partially functioning the Tap 41 diagnostic test print will be printed (this is a forced service print test which is mainly used for the evaluation of ink cartridge electrical health). A good HP 60/60XL color cartridge should display 1248 good nozzles, while a good HP 60/60XL black ink cartridge should show 336 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. Refer to 2nd video on how to read the printout.
    http://inkjet411.com/?page_id=444 (HP 60 - Deskjet F4200 model)
    If the printer attempts to print the diagnostic test pattern (1 page) then the printer is generally considered operational and functional, if nothing is printed, but the printer attempts to print the pattern, then the tri-color ink cartridge is either empty, clogged or severely electrically damaged (black ink cartridge is not used). You can remove the tri-color cartridge, reactivate the tap 41 test and the printer will print the diagnostic test print in black ink.
    For additional support please visit http://www.inkjet411.com
    -Thank you
Dec 09, 2013 | HP F4480 All-In-One Printer
My printer goes through the motion of printing but the paper comes out blank. I've an hp deskjet d2360 and there is ink in it
Possibility cartridge print head dry.
Solution 1:
Do a clean process
cartridge automatically. Press START - Control Panel - Printers and Faxes - HP Deskjet d2360 right click and select Printing Preferences - Select the Color tab - select Printer Services - select Clean cartridge, wait for the cleaning process is completed - Perform Test print. If the print test results, has good graphics, press Finish. If the graph is not clear or drop out, repeat the cleaning process once again.
Solution 2:
1. Open the cover printer, cartridges will move to the middle position.
2. Remove the cartridge (be careful, do not touch the element cartridges or print head by hand), then stick the tip cartridge (print head) to clean water
3. Then, attach the print head to a tissue paper. If there is a tissue paper used in ink (black cartridges, black block lines, and color cartridges, three color red yellow blue lines), means the flow of ink to the print head is normal. If the
tissue paper no trace of ink, attach back into the water, repeat the above process.
4. After process is complete no.3, clean the cartridges with a tissue paper (careful, do not touch the element cartridges or print head by hand, because it will damage the cartridge). After cartridge clear of the water, insert the cartridges into printer.
Sep 24, 2011 | Office Equipment & Supplies
Deskjet f4480 prints documents with the letters in shadow
You may need to do an alignment of the print cartridges. 1. Open the HP Solution Center 2. Click on Settings 3. In the Print Settings section, click Printer Toolbox 4.Click Align the Print Cartridges 5. Click Print Page An alignment page will be printed. Placed the alignment sheet with the printed side down on the right front corner of the scanner glass. Press the scan button to complete the alignment.
Jun 09, 2011 | HP F4480 All-In-One Printer
Almost every caracter I try to print comes out with a shadow and blurry with my HP Deskjet F4480 printer. Can you help? Does it have anything to do with the ailgnment page used in the installation...
You may have to do another alignment of the printer.
Do a Clean the Print Cartridge cycle first.
This will allow the printer to print a good alignment page.
Mar 01, 2011 | HP F4480 All-In-One Printer
How do i remove ink cartridge hp deskjet F4480
Here is a short tutorial about hp deskjet F4480:
http://www.inkjet-laser.com/hp-deskjet-f4480-error-print-cartridge-is-missing-incorrectly-installed.html
Feb 17, 2011 | Computers & Internet
Printer is offline & will not print ... not even a test page.
First, make sure that the printer is properly connected to the computer and it's turned on.
Go to Control Panel > Printers > right-click the printer icon > select "Use printer Online".
Make sure the clear the pending documents on the queue before trying to print a test page.
Thank you for using FixYa!
Jun 13, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
HP Deskjet F4180 Color changes and lines in photo printing
HP always recommend that ink cartridge should be replace by original ink.
As this kind of scenario will occur if the ink will just be replace by a refill ink.
Sep 21, 2009 | HP Deskjet F4180 All-in-One InkJet Printer
HOW DO I CLEAN MY PRINTER CARTRIDGES/HEADS?
For using the HP Deskjet 5000 series Printer Assistant:
  1. Double-click the 5000 series printer assistant icon on the Desktop of the computer.
  2. Click Utilities .
  3. Click Printer Maintenance .
  4. Click Clean Cartridges .
  5. Follow the on-screen instructions.
read info on this HP link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpd09339&cc=us&lc=en&dlc=en&product=71896
copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 15, 2008 | HP DeskJet 5550 InkJet Printer
Printing problem
You have either a clogged colour print head or a non-functioning print cartridge (only one colour working). If the printer has separate cartridges for different colours (and black) you can do a partial swap, replacing the ones that have failed, but start by running the command CLEAN PRINT HEADS from the printer options or controller panel, and watch for the quality to improve. You may have to clean the heads two or three times. If no change in the quality after two flushes, replace the cartridges with new ones.
Good luck...
Nov 16, 2007 | HP DeskJet 610c InkJet Printer
122 people viewed this question
jasbo
jasbo
