Question about Sole Fitness Sole F60 Treadmill
Recalibrate a sole f60 treadmill
Recalibrate so motor will work
Sole F60 Treadmill showing LS1 code...Belt won't start
You have a bad controller. You'll need a controller and a walking belt. Should be about $450 for parts.
May 30, 2017 | Exercise & Fitness
Sole f60 incline error E2
does the incline work at all. if not try to calibrate the incline. if this fails something could be wrong with the incline motor
Oct 20, 2014 | Sole Fitness Sole F63 Treadmill
After putting together my sole f60 treadmill the display wont turn on, it gets a clicking noice, connections are connected. any idea where to start
Hook up the main harness . Make sure you didn't plug one of the connections up backwards. Hooking them up backwards will cause the incline to go all the way up and the display will not come on.
Aug 10, 2014 | Sole Fitness Sole F60 Treadmill
Sole F85 E2 error code. Have adjusted the sensor several times along with running recalibration. All grounds and board connections seem to be secure. What else should I check. Unit worked until we...
If it was moved . Most likely the cable was damaged where the right upright bar slides into the frame. You will need to take the console off and remove the right upright , too access the cable. Unless you live in NC you could call, wilsons triad fitness 336-313-6253
Dec 08, 2017 | Sole Fitness Sole F85 Treadmill
E3 error on sole E95 elliptical
The E95 incline motor is out of calibration. Recalibrate the incline by holding the UP INCLINE button and the START button simultaneously for 5 seconds. This will put the machine into incline calibration mode. Press ENTER to start the calibration and let it run. It will take a minute or two.
Refer to page 25 (the last page) of the user manual, hidden right at the bottom.
Sep 20, 2012 | Exercise & Fitness
Sole Fitness Sole F60 Treadmill Logo
60 people viewed this question
Top Sole Fitness Exercise & Fitness Experts
Art Wilson
Art Wilson
Level 1 Expert
Electro Med Services...
Ross Metcalfe
Ross Metcalfe
Are you a Sole Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
