Question about Zephyr Cyclone AK6500 Kitchen Hood
Fan reve up and then go back down.
The vent fan reves up and then after a while it go back down for a few minutes. Also, seems like the air is blowing down instead of sucking up on one side. is this normal? are the lights supposed to be a certain type of r14s? I saw some that was for under cabinet lighting.
Brushes won't spin, motor reves down
1. clean the brushes of hair etc and manually turn to see if any obstructions.
2. check the belt and its tension.
It should work.
Mar 03, 2014 | Shark Navigator Bagless Upright Vacuum
My compaq presario become very hot within few miniute and then it is automatically shut down.what is its harm and how this problem can be solve.
It is overheating. It may be a few things, check the vents and make sure they are not blocked by anything (sometimes dust can block them as well). Also listen and feel at the vents to make sure you fell air blowing out (if not the fans may have died out).
The fact that it shut down means it is trying to save the components before they burn out. You should be able to turn it back on once it cools down enough. You can also use a fan to blow air through the vents to speed the process. If it continues to shut down, it will burn out eventually if not repaired. You can get by for a while by using a fan base (you sit the laptop on it and it has fans blowing air on it to keep it cool). You can purchase this at any bestbuy or staples.
May 20, 2011 | Compaq Presario 1400XL340 Cooling Fan...
My laptop makes a loud noise when connecting to the internet, like a plane reving up for take-off.
Hello.
The most likely problem is the cooling fan. Could be clogged or faulty.
First, disconnect all cables. Be certain to dispel static electricity by touching metal. Remove the back cover to expose the fan. With a can of compressed air, blow the dust from in and around the fan. Replace the cover and cables and try again.
If still a problem, the fan would likely need to be replaced.
Hope this helps.
Jan 31, 2011 | Acer Aspire 5610-4648 Notebook
I have a 1988 mk 2 golf when i start the engine the heater warms up as normal but when the engine warms up the heater starts blowing cold air out. also now that the cold weather has started after driving...
sounds like the thermostat stickng as when engine gets cold the choke will start workin again, causing the over reving or your electric fan is on all the time "over cooling" the engine
Dec 22, 2009 | 1988 Volkswagen Golf
4.6 liter has one heater hose warmer than the other. may be plugged core,or is ther a fuse to climate control switch?
Look for a heater valve on one of the hoses if there is no valve i would say its a plugged heater core.
Dec 11, 2009 | 1999 Ford F150 Regular Cab
My heater on my F350 does not seem to be working properly. When I take my foot of the gas....the heater pumps cold air. What is my problem?
if the heater fan is sill blowing then the only thing is maybe the water pump is faulty. Feel the hoses if you can get to them for the heater core when its idling.. If one cools down when you idle and heats up when your reving up the motor I would suspect a coolant flow issue, I have seen heater cores clog or become restricted so reving the motor would push more hot water thru You may have a control valve on one of the heater hoses going to the motor that may not be fully opening .
Now it they are both hot and stay hot then I would heater box as being the issue, I wouldnt suspect the control as being at fault.
Dec 01, 2009 | 2003 Ford F350 Super Duty DRW SuperCab
Exhaust fan doesn't work and blows air from top vent
Some microwaves have a adjustable fan. We have one that you can vent out the back, the back top or through the front top filters. The latter is what it sounds like you have. If you take the small back panel off and lift out the fan motor you'll see that you can place it in the direction you like.\\
KK
Jul 04, 2009 | Kenmore 60654 Microwave Oven
2006 envoy fan clutch or PCM
The emission controls (or PCM) do what you are describing intentionally. There is an electrically controlled fan clutch. It is noisey when cold. The shifts are held to increase engine speed to heat up the catalytic converter faster.
Jun 15, 2009 | 2006 GMC Envoy
Zephyr Cyclone AK6500 Kitchen Hood Logo
64 people viewed this question
Top Zephyr Kitchen Ranges Experts
Treefrog15
Treefrog15
The Vanguardian
The Vanguardian
Dale Copeland
Dale Copeland
Are you a Zephyr Kitchen Range Expert? Answer questions, earn points and help others
