Question about HP F4480 All-In-One Printer
Printer sounds like it is printing but paper is blank when done
Ink levels are fine, cleaned cartridge with alchohal wipes, printer functions fine, it sounds like its printing and going thru the motions but in the end the paper is blank when it comes out.
    Master:
  • 966 Answers
Gabriel, have you tried to 1. clean and 2 allignment of cartridges using the tool function.?
Posted on Mar 24, 2014
Printer functions fine, but nothing is printed on paper
are these new carts? or have they been sitting around long before you installed them?
Mar 24, 2014 | HP F4480 All-In-One Printer
My x7550 wont print pictures.....says its printing and ink level goes down, but photo paper comes out blank
It could be that your cartridges need some cleaning. From the printer operator panel, scroll to the Maintenance menu and select Clean Cartridges. Your printer will then print a test page forcing ink through the cartridges nozzles and clean them.
After doing the clean cartridge function, try to print another photo to determine if the problem is fixed.
Hope this helps.
Apr 30, 2012 | Lexmark X7550 InkJet Printer
My printer is making the sounds that it is printing but the paper is coming out blank. we have not used the printer before however the ink cartridge looks fine..is there something obvious as to why the...
Hello
Sure the ink in the cartridge is clogged and needs to be cleaned. Follow the steps below
1. Open the cartridge access door on your right side of the printer.
2. Remove the cartridge from printer
3. Take a tissue paper with a little water
4. Wipe the nozzles of the cartridge gently
5. Wipe again with an dry tissue and you will find ink deposit on the dry tissue
6. Install back the cartridge in printer
7. Use cartridge cleaning option in the printer.
You are done.
Jul 21, 2011 | HP Photosmart A516 InkJet Printer
My printer is only printer blank pages? When it prints, it runs the paper through at a rate as if it was actually putting ink onto it but than the paper just comes out blank. Help!
Check the ink cartridges for ink level - it might just be empty. If you've replaced them with new cartridges already, clean the print heads with a "Q" tip and alcohol and run the "clean-cartridge" function in the printers properties.
Nov 22, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Printer goes thru the motions but does not print.have not used in a while. the ink cartridges look clean and the chart shows plenty of ink when i print the allignment page(it's blank twice) the display...
If the printer has been unused for a considerable time the cartridges may have become blocked with dried ink.
Remove the cartridge(s). Take a slightly dampened cotton bud or piece of kitchen paper and carefully wipe the copper coloured surface on the cartridge(s). Then wipe with a dry piece of kitchen paper.
Re-insert the cartridge(s) and perform the print head cleaning function in your printer control panel.
Now try printing.
Mar 26, 2010 | Office Equipment & Supplies
HP Photosmart C4480 won't print
I had almost the same exact problem. Left the printer unused for a month or so, came back, no black ink being printed, even though the level was still sufficient.
What I did, was boiled a small pot of water, and held the black ink cartridge over the steam, about 3-4 inches above the boiling water, for 2 increments of about a minute. Try not to burn your hand or cook the cartridge lol. I wiped the cartridge head with a piece of paper periodically until I noticed a good bit of dark ink on the paper, then gently wiped the condensation off of the cartridge with a paper towel so as not to put a wet cartridge back in my printer. Put it back in the printer and voila!
Works great so far, although I can't vouch for the long term effects of this solution. I did look at the cartridge a bit later to make sure it wasn't leaking, and it wasn't. You have to steam it the right amount of time. I would guess that the printer cartridge head will inevitably dry out again with limited use. I'm hoping that it will keep working though haha. Hope this helps anyone else with this problem.
Jun 24, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
Blank paper
To solve the printing problem..
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Hope this help. Please Rate My Response! Thanks!
PREM
Mar 23, 2009 | Canon Pixma iP6600D InkJet Photo Printer
F380 deskjet - error - refuses to pront
I have this printer with the same problem , worked fine for 1 year, printed over 1600 pages total ( according to the built in HP program that records how many pages I printed and how many times I used the printer) then it stopped printing. The ink cartridges are new, the software is fine, and it says ink levels are good. It physically goes through the motions of printing, loads the paper, makes all the normal sounds it used to and pushes out the paper when it's done - but the page is blank. I did some surfing and read some info that some HP printers are pre-programmed to stop certain functions so you buy a new printer. I know that might sound crazy. How long have you had the printer and how many pages do you think you printed?
Nov 09, 2008 | HP DeskJet F380 All-In-One Printer
It prints ok, but paper is blank (no ink at all)
1. Remove the protective tape from the cartridges:
1. With the printer power on, open the front cover of the printer. The cartridge carrier should move to the middle.
2. Remove the cartridge(s) from the printer.
3. Look on the underside of the cartridge(s). If there is yellow tape and/or transparent blue tape there, remove it.
2. Clean the cartridge nozzles:
1. Go to the Lexmark Control Program or Solution Center and run the Clean print nozzle test.
If a black cartridge is installed, you should see black lines only.
If the color cartridge is installed, you should see yellow, magenta (a reddish purple), and cyan (a dark sky blue) lines.
If a photo cartridge is installed, you may see different colors.
2. Examine the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right, with no gaps.
If there are gaps in the lines, you could run the Clean Print Nozzle page a few more times to try and clear it up or try the "wicking" procedure below to conserve ink.
If the page is faded from left to right and the wicking procedure doesn't clear it up, your cartridge is probably out of ink.
3. Clean ("wick") the cartridges:
1. Remove your cartridges following the instructions in your User's Guide.
2. Take a warm, damp paper towel and fold it so that it has about 4- to 6-ply thickness.
3. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are touching the towel, and hold the cartridge in this position for about 15 seconds. The nozzles are where the ink comes out of the cartridge.
4. Now drag the cartridge lightly across the paper towel in one direction only (left to right) until the bottom of the cartridge looks clean.
5. Turn the cartridge over so that you can see the bar code sticker on the back. Note: Only perform steps 6 and 7 if the contacts look dirty or corroded.
6. Using a clean pencil eraser, clean the contact points on the copper strip (only the little squares just below the bar code). Caution! Do not use the eraser on the nozzles that were cleaned, as this will damage the cartridge.
7. Using a clean part of your dry paper towel, wipe the eraser dust off the contacts; ensure that they are dry, and snap the cartridge back into the printer.
8. Make sure to install the cartridges following the instructions in your User's Guide, selecting Old Cartridge. Failure to do so could reset your ink levels as explained above.
9. Repeat the nozzle cleaning procedure one more time. At this point the diagonal lines should be solid.
10. If they are not and you think the cartridges should have ink in them, contact our technicians by e-mail and let them know the results of this test.
4. Reset the ink levels:
Lexmark printer cartridges do not have ink sensors. The levels of ink are produced by a mathematical calculation of ink drops and page counts. The printer stores this information and then writes it to the win.ini file on your computer.
Ink levels can be reset by telling the printer you have installed a new ink cartridge or by reinstalling the printer drivers and selecting Cartridges Installed. Once ink levels have been reset, there is no way to change them except by printing.
Accordingly, even if your computer says that your ink is full for a particular cartridge, it may be incorrect and the cartridge may need to be replaced. You may want to try a new cartridge to see if that clears up any print quality problems.
Oct 24, 2007 | Lexmark X83 All-In-One InkJet Printer
No ink coming from cartridges.
Sounds like maybe the nozzles are clogged up. Try using the printer maintenance utility to "Clean Nozzles". I think for most Lexmark printers it is call the "Lexmark Solution Center" in your Windows Start Menu. If that doesn't work, try maybe wiping the cartridge with a damp paper towel at the place where the ink comes out.
Apr 15, 2007 | Lexmark X2250 All-In-One InkJet Printer
HP F4480 All-In-One Printer Logo
129 people viewed this question
Seeker5211
Seeker5211
