Question about John Deere Garden
Free wheeling lever is broken and the mower won't move at all. Is there some way to disconnect and allow my mower to move?
    Master:
  • 574 Answers
They usually pull on a wheel stop follow and see what its controlling.
Posted on Apr 09, 2014
4 Suggested Answers
  • 68 Answers
SOURCE: We just bought a Series 430 push mower --- had no
They usually put spring washers in there to keep things tight.
Try some good penetrating oil on the pivot bolt.
Last resort--loosen the bolt, use oil on it, retighten.
Posted on Apr 26, 2009
  • 52 Answers
SOURCE: Black and Decker Electric mower #M2370 lever
you could just try drilling the case out where the lever pivots and put a long nut and bolt to hold the lever in place
Posted on Apr 15, 2010
SOURCE: TORO ZERO TURN MOWER WON'T TURN OR MOVE ONE WAY
This page says there's one solution. What is it? Where is ti?
Posted on Nov 11, 2012
Won't move forward or backwards
Check the manual bypass for the transmission which allows the mower to free wheel. The manual bypass control lever is generally located at the rear of the riding mower.
Mar 13, 2016 | Garden
Exmark lazer choke won t engage
check cables from lever to carb make sure it is not pinched it should be a tube w another cable running trough it that moves back and forth or broken even disconnected
Jan 24, 2014 | Garden
Riding mower won't move forward or reverse
WHAT MAKE AND MODEL MOWER? YES...YOU EASILY COULD HAVE BROKEN THE AXLE!
SEE IF EACH WHEEL WILL SPIN INDEPENDENTLY OF ONE ANOTHER IN BOTH DIRECTIONS. ALSO, SOME MOWERS HAVE A ENGAGE/DISENGAGE TRANS LEVER (USUALLY PULLS IN AND OUT AND LOCKS WITH A CLEVIS PIN RETAINER)
Jul 26, 2013 | Garden
Lawn mower won't engage forward or reverse "drive belt is not broken
If it's a JD rideon make sure you have pushed the lever back in all the way!
Apr 17, 2013 | Husqvarna 22 hp 42" Yard Tractor YTH22V42
Blade engagement lever won't disengage
If this is a manual engagment system all the lever does is to pull a jockey wheel into the back of the belt to tention it thus starting the blades to turn, so either the cable is jammed that pulls the jockey wheel in, or the jockey wheel arm is seized and needs freeing off to allow the jockey to to move to the relaxed position.
Jun 23, 2012 | Craftsman 20 Hp 42" Deck Lawn Tractor
Freewheel lever broken
For the wire to come all the way out lever on top of the trans must be broken. I've seen a few. Jack rear of mower up, remove rear right wheel and find remnants of lever. With pliers turn this all the way forward, mower will now go. But to fit new lever trans will have to be removed. Dont forget the axle key.
Nov 12, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Snowblower wheels wont engage when they are on the ground they move slowly when I lift it
1) Traction drive belt slipping or worn
a) idler pulley not fully engaging
b) cable/lever adjustment
c) spring missing or broken
2) Friction drive disc slipping or worn
a) rust on hexagon shaft not allowing friction disc to move
b) missing or broken engagement spring
3) clevis pins missing or broken on wheels
4) roll pin on drive shaft missing or broken
inside the cover for the gearing mechanisms, chain drives, gears ect.
Dec 06, 2009 | Ariens Garden
Toro 6.5 self propelled Mower - Self Propell won't engage
see if the lever going to the gearbox is cracked or broken. there is a gear inside the box that has a pin going thru the shaft that may have broken but usually it is external. these mowers have a plastic lever to put the transmission lever in gear if the cable is overtightened they wont hold up.if it cracks it leaves practially no tension on the engagment system
Jul 17, 2009 | Garden
The free-wheel lever will not release.
I had same proble - spray some lubricating oil on the lever, let it sit for awhile, than GENTLY tap it with a hammer. Worked for me
Jun 26, 2009 | Pride Sonic 3 Wheel Portable Scooter
Garden Logo
272 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
