Question about HP F4480 All-In-One Printer
Printer functions fine, but nothing is printed on paper
Ink levels fine, cleaned cartridge with alchohal wipes, and i still cant get anything to print that i ask it too, paper runs thru fine and it sounds like its printing but in the end there is nothing but a blank piece of paper
  • 406 Answers
Are these new carts? or have they been sitting around long before you installed them?
Posted on Mar 24, 2014
jaylex
  • 417 Answers
SOURCE: HP LaserJet 3550 spits out blank paper when job sent from computer but prints fine when printing directly from printer
Try connecting the printer via the USB port on either one of the computers. Then test if the machine prints fine then likely possibility is that the Network interface card is faulty remove the network card and install in a different slot and test. If the same thing happens then reinstall the drivers and test.
Hope this helps
Thanks J
Posted on Jan 28, 2008
jaznet
  • 75 Answers
SOURCE: HP Deskjet F380 won't print
i think the inside printer have dirt or obstacles that blocken the cartridges while printing.
try to clean manually the printer by using powerful air blower,repeatedly.
Posted on Sep 14, 2008
Soulvisitor
  • 1113 Answers
SOURCE: Cannot print with new ink cartridge
Sounds like a non genuine, aftermarket ink that is dodgy.
if not ensure it is indicating the same colour that you replaced
Posted on Dec 12, 2008
jilpeshpatel
  • 259 Answers
SOURCE: HP J4580 Printing blank pages
fist click the start menu
and click the printer and fax
and select the hp printer and rith cilck the proparties and seat the print colar coular that time
select only black...............ok
Posted on Apr 08, 2009
  • 1218 Answers
SOURCE: My printer is not printing
You need to take it a couple steps further after your test print. Sounds like your print heads need cleaning or your cartridge may need aligning. It’s best to do this each time you install a new cartridge. for more information….... http://en.kioskea.net/forum/affich-40171-printer-not-printing-black
Posted on Sep 09, 2010
Printer sounds like it is printing but paper is blank when done
gabriel, have you tried to 1. clean and 2 allignment of cartridges using the tool function.?
Mar 24, 2014 | HP F4480 All-In-One Printer
Print job disappearing and not printing
1. Check for a paper jam. Paper jams occur when one or more sheets of paper become stuck in the feeding or printing mechanism. Gently remove any jammed paper and reset the printer.
2. Check ink levels. Those ink cartridges run out fast. If your printer looks like it is printing but nothing comes out on the page, you might be out of ink. Try replacing the cartridge and printing again.
3. Check for a clogged print head. If you know you have ink, the print head might be clogged. Navigate to "Control Panel > Printer > Right Click > Properties > Maintenance > Clean Cartridges" to attempt to clean the print head.
4. Reinstall printer drivers and software. If none of the above helps, try uninstalling and reinstalling the printer and software to correct possible software bugs, errors or conflicts.
Canon-Specific Issues
5. Check printer drivers. Navigate to "Control Panel > Printers > Right Click > Properties > Update Driver" to check for a new driver for your printer. You can also find drivers and software on the Canon Support site (see Resources).
6. Resolve the Waste Ink Error. Press menu on the printer and press scan/copy to enter service more. Press the right arrow to access "NVRAM." Set ABS-M level to 0. Set ABS-P level to 0. Press "Stop" to exit.
7. Resolve Wrong Cartridge Message. Turn off the printer and unplug the power cord. Remove the cartridges and the print head. Clean the print head in lukewarm water. Set it aside to dry. Clean the contacts gently with an eraser and wipe with a tissue. Reinstall the print head and reinsert the cartridges. Run a cartridge alignment.
8. Resolve E0D02 error. Clean the cartridges and the sender strip. The sender strip is behind the rubber drive belt behind the main hatch. It runs horizontally across the machine. Wipe it gently with a lint free cloth.
Aug 19, 2012 | Canon Pixma Mp250 Printer
I put new ink cartridges in my hp 2575 about ~six months ago and hadn't used the printer since then. I tried to print and it goes through the motion of printing but nothing shows up on the page. The...
The Ink at the head of your Printer Cartridges has dried up.
Try this:
Load some plain paper in the printer
Remove the cartridges from the printer and carefully dab the print heads of the cartridges with a damp paper towel. ( when you start to see ink, the ink is starting to flow).
Replace the cartridges into the printer.
Go to:
Start
Control Panel
Printers
RIGHT click on this printer
choose Printing preferences
services
clean print cartridges 9some papers may print)
follow the instructions and do the heavier cleaning as well
Run the calibration function and allow the paper to print.
Jan 10, 2011 | HP Photosmart 2575 All-In-One InkJet...
MY LEXMARK 4505 LEAVES 3-4 BLACK BLOTCHES ON THE EDGE OF EACH PAPER IT PRINTS, TRIED CLEANING THE ROLLERS TO NO AVAIL, ANY SUGESTIONS
ADJUST THE COLOR AND PRINT SPEED You may need to adjust the color and print speed. CHECK THE LEVEL OF INK IN THE PRINT CARTRIDGES 1 From the Finder desktop, double-click the Lexmark X5400 Series folder. 2 Double-click the Lexmark X5400 Series Utility icon. 3 From the Maintenance tab, check the ink levels of the cartridges. If an exclamation point (!) appears on a cartridge, the ink level is low. Install a new cartridge. Improving print quality These are possible solutions. Try one or more of the following: CHECK PAPER • Use the appropriate paper for the document. If you are printing photos or other high-quality images, for best results use Lexmark Photo Paper or Lexmark PerfectFinish Photo Paper. Do not use Lexmark Premium Photo Paper. Your print cartridges are not compatible with this type of paper. • Use a paper that is a heavier weight or bright white. CHECK PRINT CARTRIDGES If the document still does not have the print quality you want, follow these steps: 1 Align the print cartridges. For more information, see "Aligning print cartridges" on page. If print quality has not improved, continue to step 2. 2 Clean the print cartridge nozzles. For more information, see "Cleaning the print cartridge nozzles" . If print quality has not improved, continue to step 3. 3 Remove and reinsert the print cartridges. For more information, see "Removing a used print cartridge" on and "Installing print cartridges" . If print quality has not improved, continue to step 4. 4 Wipe the print nozzles and contacts. For more information, see "Wiping the print cartridge nozzles and contacts". If print quality is still not satisfactory, replace the print cartridges. For more information, see "Ordering print cartridges". CHECK PRINT CARTRIDGES If the document still does not have the print quality you want, follow these steps: 1 Align the print cartridges. For more information, see "Aligning print cartridges" on page 124. If print quality has not improved, continue to step 2. 2 Clean the print cartridge nozzles. For more information, see "Cleaning the print cartridge nozzles" . If print quality has not improved, continue to step 3. 3 Remove and reinsert the print cartridges. For more information, see "Removing a used print cartridge" and "Installing print cartridges" If print quality has not improved, continue to step 4. 4 Wipe the print nozzles and contacts. For more information, see "Wiping the print cartridge nozzles and contacts"
Nov 10, 2010 | Lexmark X5495 All-in-One &USB...
Printer will not print anything. Ink levels are
If it has been longer than 3 or 4 weeks since anything last printed, the problem may be clogged print heads. Run thru several cleaning cycles and see if anything begins to appear on the paper. If not, changing the ink cartridges may solve the problem. If it's been quite a long time since last printing, you may need new (and expensive) printheads. If that's the case, replacing the printer would be more cost effective. Sorry for the bad news.
Aug 13, 2009 | Epson Stylus C88 InkJet Photo Printer
Acts like it's printing, ink is good, but nothing prints out on paper.
Nothing at all? Poor you are. The pump may damage or lost electricity.
May 31, 2009 | Epson Stylus CX6400 All-In-One InkJet...
Have you removed the tear off tape from top of cartridges, it lets the air in and ink flows.
May 28, 2009 | Epson Stylus CX6400 All-In-One InkJet...
Printer print nothing or blank
Please these and try to clean the print heads of the cartridges manually:
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Apr 02, 2009 | Canon BubbleJet i560 InkJet Printer
Brother DCP-120C Printer - Does not print black, Black and magenta cartridges renewed with new Brother cartridges. Black ink level reset OK but not magenta. Have tried automatic head cleaning but still no...
have you recently had a paper jam. somtimes pieces of paper can become trapped under the print head which restricts the printing. if there is and its been there for a while the print head may need to be wiped/cleaned( a bit tricky) then a couple more print head cleans.
Nov 04, 2008 | Office Equipment & Supplies
No ink coming from cartridges.
Sounds like maybe the nozzles are clogged up. Try using the printer maintenance utility to "Clean Nozzles". I think for most Lexmark printers it is call the "Lexmark Solution Center" in your Windows Start Menu. If that doesn't work, try maybe wiping the cartridge with a damp paper towel at the place where the ink comes out.
Apr 15, 2007 | Lexmark X2250 All-In-One InkJet Printer
HP F4480 All-In-One Printer Logo
65 people viewed this question
Seeker5211
Seeker5211
