Question about Intec G5755 Action Board Wii Fit - Nintendo Wii - Black
When i turn the power on the wii balance board it won't stay on and im having trouble trying to sync it to my wii console what should i do
The wii fit board wont stay on when i turn the power on
    Scholar:
    New Friend:
  • 46 Answers
Sorry to say this, but that sounds like a short with the internal wiring.
If you have experience, or want to obtain some, you will want to crack that thing open and start testing the internals with a voltmeter. Once you have identified the short you can either fix the wire (not likely the case here) or remove and replace the solder/weld (more likely as time produces corrosion on these just like any other metal).
Posted on Jun 20, 2014
How to connect wii fit board to the wii
Important Note!
Do Not use "One-Time Mode" sync.
Syncing can be completed only if a compatible game disc is running in the console.The Wii Balance Board may need to be synced to each compatible game individually.Some games may require you to go into a specific screen to sync the Wii Balance Board.These sync settings will be saved even after the console is turned off.
1. Insert a Wii Balance Board compatible game disc in the Wii console.
2. Use the Wii Remote to select the Disc Channel from the Wii Menu, then select "Start" to begin the game.3. Open the SD Card slot cover on the front of the Wii console.4. Remove the Battery Cover on the bottom of the Wii Balance Board.
5. Press and release the SYNC button on the Wii Balance Board. The Power LED on the board will start blinking.
6. Press and release the SYNC button on the console while the Power LED on the board is still blinking.
7. The Power LED will stop blinking and light steadily once the synchronization is complete.8. Replace the battery cover and return the board to the normal operating position.
Nov 16, 2011 | Nintendo Wii Fit for Wii
How can i re connect the wii fit balance board to my wii ?
Synching can be completed only if a compatible game disc is running in the console. Compatible game discs (such as Wii Fit) will display the Wii Balance Board icon on their packaging.
The Wii Balance Board must be synced to each compatible game individually.
Follow these directions to sync the Wii Balance Board (so that it is recognized by the Wii console):
Insert a Wii Balance Board compatible game disc (such as Wii Fit) in the Wii console.
Mar 16, 2011 | Nintendo Wii Console
How do you sync the wii fit board and wii console
  • Put four AA batteries into the battery housing located on the underside of the Wii Balance Board.
  • Insert a Wii Balance Board compatible game into the Wii system.
  • Select the "Disc Channel" on the screen with the Wii remote, and choose "Start."
  • Open the SD card slot to reveal a sync button on the Wii system. This is located behind a cover under the power and eject buttons.
  • Turn the Wii Balance Board upside down.
  • Remove the battery cover under the balance board to reveal another sync button.
  • Pres the sync button on the balance board, then press the sync button on the Wii. Do not hold down the buttons. You know it is synchronized when the blue light on the Wii Balance Board stays steady
  • Place the board on a flat surface directly in front of the TV. Face the power button away from the TV.
  • Mar 03, 2011 | Nintendo Wii Console
    I have a wii fit board, when you power it up, it
    Had the same problem. It's a sync problem.
    First, best to double check you have fresh batteries.
    Next, turn the board upside down and remove the cover from the battery compartment.
    Open the small hatch cover on the front of your console unit.
    Now start wii fit from the disk menu item.
    Next, press the small red button inside the balance board battery compartment. The blue lights will blink for approx 3=5 sec.
    While they are blinking, press the red button on the console (in the hatch compartment).
    This should re-sync your board and the light stays lit.
    Good luck.
    Apr 07, 2010 | Nintendo CTA Digital WI-BBP Wii Fit...
    My wii fit board keeps telling me to ''step off the balance board and press A'' I am not standing on it when i get this message. I've checked the batteries, re synched the board to my wii, taken out the...
    Looked around for a solution for a long time for this one.
    1) removing the batteries from the Wii Fit balance board for at least a minute.
    2) Turn the Wii OFF by pressing the POWER Button on the front of the console. Unplug the power cord from the wall outlet for a few seconds. After a few seconds plug the cord back into the outlet.
    2 Turn the power of the Wii console ON. When you see the Health and Safety screen, open the small flap on the front of the Wii console to find a red button labeled "SYNC." Press and hold the SYNC Button down for 15 seconds. This should clear all the old syncs on the Wii.
    3 After holding the SYNC Button on the Wii console down for at least 15 seconds, you can now "re-sync" your Wii Remotes:
    a With the first Wii Remote you wish to sync, remove the battery cover on the back of the Wii Remote to find a small red button just below the batteries.
    b Press and release the small red button just below the batteries on the Wii Remote; the blue lights on the front of the Wii Remote will turn on.
    c Quickly press and release the red SYNC button on the inside of the white flap on the front of the Wii console.
    d When the Player LED blinking stops and stays lit, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
    4 Start the game from the Wii Menu, don't forget to sync the Wii Balance Board from the opening screen of the game (you've deleted the syncs earlier).
    Another problem may be the surface on which you post the Wii fit, make sure it's flat, try put it on the floor directly or place it on a rug.
    And don't forget to "step on" it when it says and not before as the Wii console might be "overloaded".
    Jan 31, 2010 | Nintendo Wii Fit for Wii
    Wii fit board won't work
    Here you have different procedures on what to do if you get that error message. Please get back to me if nothing works.
    The exact procedure is:
    • Even if the battery level is strong, try the following:
    Remove the batteries in the Wii Fit Board for at least 1 minute…… better 15
    Try these steps!
    1 Turn the Wii console power OFF by pressing the POWER Button on the front of the console. Unplug the power cord from the wall outlet for a few seconds. After a few seconds have elapsed, plug the cord back into the wall outlet.
    2 Turn the power of the Wii console ON. When you see the Health and Safety screen, open the small flap on the front of the Wii console to find a red button labeled "SYNC." Press and hold the SYNC Button down for 15 seconds. This will clear all the syncs on the Wii, allowing you to get a clean start to begin the process described below.
    b Press and release the small red button just below the batteries on the Wii Remote; the blue lights on the front of the Wii Remote will blink.
    c Quickly press and release the red SYNC button on the inside of the white flap on the front of the Wii console (picture).
    4 Start the game from the Wii Menu, then sync the Wii Balance Board from the opening screen of the game.
    Hope it helped.
    Nov 24, 2009 | Nintendo Wii Fit - Balance Board + Game...
    I have a wii fit and tried to sych it to my console. I think I held the sych button on the balance board too long and messed up the remotes. They won't work at all now. Please help! Thank You
    Ensure your batteries are fresh. Ensure that the Wii Fit (or other Balance Board game) is started up completely before pressing the power button. Try turning off your wii and unplugging from the power source for a few minutes. The plug back in and turn on. At the initial warning screen press and hold the sync button on the will console for about 4 seconds. You will have to re-sync your wii remotes. Next make sure the disc for the game you are going to use the balance board with is in the system and start the game. Then try to sync the balance board.
    Oct 18, 2009 | Nintendo Video Game Consoles & Games
    Cant sync wii balance board
    I know it's been a while since you have posted and have prob already figured it out. But just in case this may help someone else. Try turning off your wii and unplugging from the power source for a few minutes. The plug back in and turn on. At the initial warning screen press and hold the sync button on the wii console for about 4 sec. You will have to resync your wii remotes. Next make sure the disc for the game you are going to use the balance board with is in the system and start the game. Then try to sync the balance board.
    Nov 17, 2008 | Nintendo Wii Fit for Wii
    Wii fit balance board
    You need to sync the balance board with the console. Instructions are in the manual. Sync button for board is in battery compartment and sync button for console is in panel under reset button.
    Took a few tries for me, be carefule not to hold sync button on console down for longer than 10 seconds because it will deregister all wii remotes.
    Sep 09, 2008 | Nintendo Wii Console
    Power led light
    If there is no reason for the Wii Balance Board to be on, it will automatically turn off. Start up a game that uses the Balance (Wii Fit) and it will tell you when to turn on the Wii Balance Board. If you still have problems, try to sync the Balance Board again.
    Aug 29, 2008 | Nintendo Wii Console
    Intec G5755 Action Board Wii Fit - Nintendo Wii - Black Logo
    136 people viewed this question
    Top Intec Video Game Consoles & Games Experts
    Martin Murray
    David
    David
    Colin Stickland
    Colin Stickland
    Are you an Intec Video Game Console and Game Expert? Answer questions, earn points and help others
