Question about Epson Office Equipment & Supplies
How do i set when my Laptop i connect to a MULTIMEDIA PROJECTORS.
When i connected it automaticaly project the displays on my desktop. Beacause im my friends presentation ruined due to not projecting any thing on the LCD
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 35 Answers
Just press windows p the you can choose to display on your multimedia or projector
Posted on Mar 24, 2014
How do I get the drivers to download on my toshiba laptop
Ensure the projector is plugged in and on BEFORE the laptop is turned on.
The laptop should then detect the newly connected display and windows will enable it for you.
You may need to open the Display settings in windows control panel, if the display needs to be set as a mirrored or extended desktop.
Oct 16, 2014 | InFocus LP 435Z Multimedia Projector
Laptop screen resolution
when u connect to projector.after connecting change your laptop screen resolution and by setting lowest resolution you will see full screen.
Feb 19, 2012 | InFocus LP530V Video Projector 2000 ANSI...
My sharp PG 10s Notevision comes on. However, is not projecting my computer images on the screen
Make sure the connection from the pc to the projector is secure, also make sure the display settings on the computer are set to extend the desktop onto the projector, and that the projector is set to pc mode.
May 12, 2011 | Sharp Notevision PG-B10S Multimedia...
Laptop display will not project onto screen
A couple of possibilities...
Connect a separate monitor to your laptop and verify that your laptop's external monitor port is functioning properly.
If yes, connect and power up the LP120. Press the source key on keypad. You should see the projector switch from video to computer.
Last option, does the projector display an "out of range" message on the screen. If so, reduce your laptop resolution to 1024 x x768.
Apr 05, 2010 | InFocus LP120 / 1000 Lumens / XGA / DLP...
Delay/ whitescreen when projecting video from laptop
1.
Connect the external display port on your laptop computer to the projection system, and then turn on the projector. For information about connecting external devices to your laptop, see the documentation for your laptop computer.
1.
Set the display resolution of your laptop computer to match the resolution of the projector system. First, on your laptop, open the Display Properties dialog box by using the Display icon in Control Panel, and click the Settings tab. Then, in Screen resolution area, move the slider to adjust the display resolution of your laptop. If you don't know which setting to choose, try 800 x 600 pixels; this is a common setting for many projector systems. YOURS sounds like 640x840.
3.
If you have audio in your presentation, connect a cable from your laptop's audio output jack to the audio input jack on the projector, and then test the volume by playing a file that contains sound.
4.
Start the Player on your laptop. If you want to only display the Player on the big screen, and not the desktop background, maximize the Player or set it to play your video using the entire screen (full-screen mode).
Jan 08, 2009 | Dell 3300MP Multimedia Projector
Infocus projector 4805 connected to Toshiba laptop
1.
2.
Jan 08, 2009 | InFocus ScreenPlay 4805 Multimedia...
Probem with connecting projector with laptop in vista OS
You need to change your graphics card settings from extended desktop to cloned desktop.
You will find that if you use your mouse currently to drag a window or icon across to the projected screen, it will move the window there. This is the extended desktop.
I assume that what you want is to have the exact same screen on your laptop and your projector - this is called the clone screen.
These setting can be by right clicking your desktop, select properties. Click on the display settings tab. click on the advanced settings button, and the the graphics card tab. There should be another button to launch the graphics card settings there.
Hope this helps.
Dec 13, 2008 | Epson EMP-S1H Multimedia Projector
Toshiba LCD projector
always make all connections first !! after that : switch on the laptop, or else no detection of an external monitor/projection device is possible.
Please check also your bios settings, some can be set to force simultaneous display of external screen and lcd of the laptop.
some laptops also require ddc communication between external connected devices.
Try to use a full wired ( except pin 9) VGA cable.
succes
Aug 31, 2008 | Radio Shack Cinego D-1000 Multimedia...
USB Driver for PLC SU70 Sanyo Multimedia Projector
Ok kumar i did some research on your problem.
Im not real savvy with projectors, but im going to try and lead you into the right direction. Now when you connect your projector to your computer, you need to go to your input settings on your projector and put them on "auto". In your product manual it says the computer should automatically detect the projector. Now if the projector isnt displaying a proper screen then you need to to go into the manual settings and adjust the settings.
Now i want you to goto this website:
http://www.aboutprojectors.com/pdf/sanyo-plc-xu73-manual.pdf
This is the manual for your projector. Scroll down to the table of contents and click on the bold letters COMPUTER INPUT click that and read a little about the way your computer connects to the projector. I hope this helps, please let me know an update. thnx
-robert
Jan 17, 2008 | Sanyo PLC-XU73 Multimedia Projector
Toshiba portege m600 cannot connect to projector ACER PD525
you can extend the display to the projector through desktop settings
Dec 07, 2007 | Acer PD525 Multimedia Projector
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
