My omega washer dryer, OWD8000WA, does not wash
After it gets the water, it stops for a while to think, then a few minutes later it ends the cycle (i've used all the different cycle settings, from express to daily cycles without success) without emptying the water. I then have to run the rinse function to empty the water, which it does so successfully.
    Prodigy:
    An expert who has answered 500 questions.
  • Washing Mach... Expert
  • 517 Answers
Have you checked the wash heater
Posted on Apr 02, 2014
TheMobilian
  • 8220 Answers
SOURCE: Bosch WVD24520GB washer dryer runs a wash fine but
If your dryer is a condenser type maybe you need to yank out the condenser and give it a good clean. Could not make the model number posted work.
Posted on Sep 21, 2010
SOURCE: I've moved into rented property
set the drying time and push in the button marked half load, it should start drying in a few seconds.
Posted on Oct 24, 2010
SOURCE: My Kenmore Kenmore 24 in.
Usually find coins stacked in the hose before the pump and drainage hose.
Posted on Dec 14, 2010
rickead1
  • 1998 Answers
SOURCE: My washer rarely spins anymore
due to not seeing a model number provided I will assume this is a top loader one of the ways to check the spin is to start the unit in the spin mode with no clothes in the unit then take the palm of your hand and put the palm against the side wall if the unit stops spining then you would need to replace the clutch in the unit here is also a video of how the clutch is replaced if you have any further questions message me back or if your unit is not a top load whirlpool also message me back with this information and please remember when our chat has fully concluded to rank how this opinion has helped in your appliance repair situation Thanks again Rick
click here to see the video http://www.youtube.com/user/RepairClinic?v=tVc6SZ2DD4U&feature=pyv&ad=5454782141&kw=washer%20clutch&gclid=CNWuobSBvqgCFYXc4Aodl3k-rA
Posted on Apr 28, 2011
SOURCE: Omega washer dryer
hgjkdfhj
Posted on Apr 25, 2013
Problems with BEKO WMB 751441 7.5 kg washing machine
take it back to the place you bought it from immediately and demand your money back or contact consumer affairs.
Jan 27, 2014 | Washing Machines
Reset frigidaire affinity washer
Yes there is buy a new drain pump so all the water will get out
Jan 19, 2014 | Washing Machines
C514 STOPS mid cycle
I'm having the same problem. It's new and it did it with the first wash. Can anyone help.
jackie
Jul 15, 2009 | Candy CNW136 Front Load Washer/Dryer
Washer will not stop!
call a service technician to get a proper diagnosis and quote then decide to fix or junk
Jun 10, 2017 | Kenmore 98702 Stacked Washer/Dryer
Washer Dryer - drum is filled with water even when switched off and door can still open!
Try the valves inside the back where the water hoses connect to the machine they should default to the closed position when water is not required
Oct 31, 2008 | De Dietrich LZ9619 Front Load Washer /...
Dry cycle
Try setting the washer dial to the stop setting at the end of setting number 4 then set the dryer timer and turn on the machine.  This works for mine to get the dryer to run by itself.  It should begin about 30 seconds later, when the door locks.  Hope this helps.
May 13, 2008 | Malber WD1000 Front Load Washer/Dryer
Neptune MAH3000AWW will start to fill when start is pressed, but stops seconds later
either a faulty pressure switch / pot or faulty controller - either way you will need to call someone in.
Jul 24, 2007 | Maytag Neptune Washer
How can I fix my whirlpool thin twin washer?
It almost sounds like your motor is kicking out on overload. The fact that it starts agitating after the fill can rule out the pressure switch. You have installed a new timer so we should be able to rule that out. It's possible that your pump is binding, which is attached directly to your motor and causing it to overheat. To tell for sure you would have to check the motor to see if it's getting power when it cuts out. Check your terminal block where the power cord comes in to see if all connections are secure. Other possibilities could be the clutch and brake assy. With out being there too see the problem, this is where I would start.
Apr 27, 2006 | Whirlpool LTE5243D Top Load Stacked...
Washing Machines Logo
89 people viewed this question
Top Washing Machines Experts
