Question about Moen 7065 Vestige Single-Handle Kitchen Faucet with Side Spray Chrome...
Faucet hex-screw not tightening correctly
Underneath faucet cap, I loosened the hex-screw to lubricate and eliminate squeaking when turning faucet. Everything was fine until I tightened the hex-screw again. It I tighten too much, it faucet will not turn. If under tightened the hex screw turns when the faucet is rotated; hex is actually loosening and tightening as faucet turns. How do I fix this? Many thanks!
    Habit-Forming:
    Scholar:
  • 60 Answers
Anytime you remove the screw you speak of there is a donut washer/seal made of rubber or plastic underneath that must be replaced even if it looks OK to the naked eye. The screw when tightened compresses the washer/seal which is made with a consistency that allows for no residual memory to return to it\'s original shape. The problem (or what makes them work so good) with them is that they form to the underside of the screw and the inside of the screw housing to provide a seal and this formation is basically impossible to place exactly as was when reassembling they fixture. Thus in order to not have it leak the need to make it too tight is prevalent or as you say the handle will turn willy-nilly due to being loose. It is an easy fix and they are cheap. The washer/seals can be purchased at any hardware type store and it should make it easier to tighten properly without your preceding problems.
Posted on Mar 24, 2014
Cannot remove 1/8" hex nut on handle. I am trying to replace valve control due to a leaky faucet. Nut seems frozen. Mel
A faucet handle? In Automotive?
If you mean a sink faucet, what brand? Is it single lever? On some, it's not a hex; rather a narrow slotted screw.
Oct 15, 2016 | Cars & Trucks
Tip
How to remove Glacier Bay Lever Kitchen Faucet Handles
To remove the lever handle from a Glacier Bay two-handle kitchen sink faucet: Insert a 2.5mm hex wrench into the small hole underneath the lever. Work the wrench into the small handle set screw.Turn the wrench and setscrew counterclockwise to loosen. Pull the Glacier Bay lever handle off the faucet stem. P.S. You do not need to remove the screw to take the handle off.
on Oct 07, 2010 | Globe Union Glacier Bay 8 In Double Handle...
Tip
How to repair a washer-type faucet
REPAIRING A LEAKY WASHER-TYPE FAUCET
  • Washer-type faucets work with a rubber or composition washer that closes onto a metal washer seat (Fig. 1). The washer can become hardened, worn or the seat wears, causing the faucet to leak. You can close the faucet tighter to stop the leaking temporarily, but this increases the internal damage to the faucet.
  • To repair the leak, first turn off the water. If there's a shutoff valve beneath the fixture, turn off the water at that point. Otherwise, turn it off at the main house shutoff valve in the basement, utility room, or crawlspace. Turn off the hot water supply at the water heater.
  • Take the faucet apart by removing the handle (this may not be necessary on some older faucets). Loosen the Phillips-head screw, which usually is beneath a decorative cap in the center of the handle. The cap either unscrews or snaps off when you pry it with a knife blade. If you must use pliers on decorative faucet parts, pad them with electrical tape or cloth to protect the finish. And take special care with the plastic parts found on many modern faucets. Next, lift or pry the handle off its broached stem. Unscrew the packing nut beneath the handle, exposing the rest of the stem. Remove the stem by rotating it in the "on" direction. It will thread out. Reinstall the handle if you have difficulty turning it (Fig. 1). Clean chips from the faucet cavity, but do not use harsh abrasives or a file.
  • Examine the stem. If the threads are badly corroded or worn, take it to your retailer and get a new stem to match. Clean the stem if it's dirty.
  • Now look at the washer, which is located on the lower end of the stem and held in place by a brass screw. If the washer is squeezed flat or has a groove worn in it, replace it–this should stop any dripping. Take the washer with you to your dealer to ensure an exact match in size and style. If the brass screw is damaged, too, replace it with a new brass screw.
  • The washer seat is located inside the faucet body. You probably can't determine if the washer seat is causing the leak just by looking at it. Any faucet that needs frequent washer replacement obviously has a damaged seat. The seat should either be refaced with a seat-dressing tool. A seat-dressing tool is not costly. Every home with washer-type faucets needs one. Use the tool according to the manufacturer's directions, placing it in the faucet along with the packing nut. Then rotate (Fig. 2) until the seat is smooth, and blow out the chips.
  • Some washer seats can be unthreaded and replaced. Check the faucet body with a flashlight to see if it has a square or hexagonal hole through its center or is slotted for a screwdriver; if so, it is replaceable. However, if the seat simply has a round hole through its center and no slots, it is not replaceable. In this case, dress it with a seat-dressing tool. To replace it, you'll need a faucet seat wrench, which comes with a combination of square and hex heads to fit most faucet seats. Turn the washer seat counterclockwise to loosen, clockwise to tighten (Fig. 3). Add a little silicone rubber sealant (RTV) or pipe joint compound around the threads of the seat before you install it to make it easier to remove during future repairs.
  • It's important to install the correct type of faucet washer (Fig. 1, bottom). A swiveling washer (C) is preferable to either (A) or (B). To install washer style (C), file the shoulder off the end of the stem, drill out the threads of the screw hole. Instead of rubbing against the seat as it closes, a swiveling washer closes with a straight-down, frictionless action – this allows it to outlast fixed washers.
  • Following this seat and washer service, your faucet should be like new. Put the parts back together in the reverse order of taking them apart. Spread a bit of petroleum jelly or silicone grease on the threads of the stem to lubricate the faucet's action.
  • If the faucet leaks around the stem rather than from the spigot, install new packing. You may want to install one of the newer nylon-covered or graphite-impregnated packings–their lubrication allows the faucet handle to turn more freely. Wrap one turn of this packing around the stem just beneath the packing nut (Fig. 1). Use three complete wraps if you're applying string-type packing. Some stems use O-rings, rather than packing. For these stems, replace the O-ring with a matching one to stop a leak. Hand tighten the packing nut, then tighten it another half-turn.
on Jan 16, 2010 | Plumbing
Where is the grub screw that has to be removed as I can't find it?
plumbing - How do I remove a stuck faucet/tap cover ...
diy.stackexchange.com/questions/.../how-do-i-remove-a-stuck-faucet-tap...
Apr 18, 2011 - Anybody can ask a question; Anybody can answer; The best ... There are total six faucets in a bathroom, two made into a bathroom basin ... The other possibility is that there's a small plastic "decorative" cap covering the screw.
How-To: Replace A Shower Faucet Cartridge ' Toolmonger
toolmonger.com/2009/12/01/how-to-replace-a-shower-faucet-cartridge/
Dec 1, 2009 - In many modern shower faucets like Delta and Moen (which is what I have) .... About a year ago, one of the bathtub faucets in my other bathroom jammedopen. .... the exact faucet I have in my shower, so you answered my first question, ...I can tighten and loosen the screw but the handle just won't come off!
Problem Removing Handle Off Of Delta Monitor 1400 Series ...
www.diychatroom.com/.../problem-removing-handle-off-delta-monitor-...
May 20, 2009 - 15 posts - ‎12 authors
... from a Delta Monitor 1400 series tub/shower single handle faucet. ... sorry for the REALLY sxxxxx question. which way to turn (loosen) the set screw. ... only suggestions i have on the issue. when a setscrew will not back off i ...
REMOVAL OF STUCK CURVED FAUCET HANDLE WITH HEX SCREW ' DIY Forums
www.diyforums.net/removal-of-stuck-curved-faucet-handle-with-hex-sc...
Feb 03, 2016 | Home
How to tighten swivel spout of moen kitchen faucet
pop the cover off the top of the spout tighten the screw underneath and replace the cap.
May 11, 2014 | Moen 7065 Vestige Single-Handle Kitchen...
I have a price pfister kitchen tap and it doesn' have a cap. how do i get the handle off to replace the cartridge
If this is the single-handle faucet I remember, there's a decorative hot/cold indicator on the front, a small half red/half blue circle. This pops out of the handle to reveal the retaining screw underneath. It's a hex-key (Allen key) screw but I don't remember the size. Once you've loosened the screw you'll be able to lift the handle off the faucet body to get at the cartridge housing.
Apr 03, 2011 | Microwave Ovens
Delta 476 faucet is leaking. I purchased the proper parts - RP4993 seats and springs and RP25 O-Rings for single handle faucet. Do we need any specific tools? Would you please be very...
http://www.faucetdirect.com/mediabase/specifications/476install_051710.pdf
Here is where to find the manual for your faucet. The only tools you should need are a pair of slip-joint pliars for the main ring and the hex key tool that came with the replacement parts. Remove the handle by loosening the hex screw on the underside. Make sure to turn off the water before you go any further and you will need to turn off both hot and cold.
Remove the dome-shaped cover either by hand or with some pliars.
Pull out the ball with the stem in it and underneath there will be two rubber washers with two springs underneath. Remove the washers and springs and put the new ones in. Put in the new stem (ball with stem) taking care to line up the slot in the side with the nub inside the base. Replace the round washer on top with the triangle hole in it and put the dome shaped cover back on.
Before turning the water on, use the back side of the hex-key tool to tighten the nylon ring that screws down into the dome shaped cover. Put the handle back on and try the faucet, if it moves too hard, loosen the nylon screw a bit, if too loose then tighten it. Once it "feels right" you can reattach the handle and turn the water back on.
I suggest turning on the water slowly and look for leaks. Not as difficult as it sounds.
Feb 24, 2011 | Delta Faucet Plumbing
How do I remove handle of lavatory faucet to replace cartridge? The faucet is dripping and making a noise
There should be a small hole under each lever handle. Inside the hole is a handle setscrew. Use a 2.5mm hex wrench to loosen, not remove, the setscrew. turn the screw counter clockwise to loosen, and then the handel should just pull straight up and off the faucet. Here is a parts breakdown for the PRICE PFISTER Treviso Wide Lavatory Faucet T49-DK00.
Sep 07, 2010 | Price Pfister Treviso Wide Lavatory Faucet...
Leaky eurostream kitchen faucet
if its leaking under the handle, all you need to do is remove the blue and red cap on the handle under you will find a 1/8 allen screw, loosen screw and remove handle and tighten the brass nut a little which will seat the packing underneath.
Jun 19, 2010 | Plumbing
Delta 473 loose connection to sick
There should be a nut holding the plate on. What is holding the u-shaped plate up?? You can't tighten the faucet from above. Seems strange the nut disappeared.
Aug 08, 2009 | Delta Model 473: Saxony Kitchen...
Moen 7065 Vestige Single-Handle Kitchen Faucet with Side Spray Chrome... Logo
208 people viewed this question
Top Moen Plumbing Experts
john h
Donni Steen
Don Numinen
Don Numinen
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
