Question about Huawei Prism U8651t Grey t-mobile
I can see my phone screen but cant unlock it
Ican see everything on it but when i slide/unlock it to go to my home screen nothing happens
  • Huawei Master
  • 928 Answers
This could probably be the digitiser. It needs to be replace or fix.
Posted on Mar 24, 2014
My iphone 3gs touch screen is not working, i cant unlock it because it will not slide. how do i get this fixed?
Try holding the power and home button, restarting your phone. Continue holding until Apple logo appears and then let go of power, continuing to hold home.
Aug 13, 2013 | Apple iPhone Smartphone
My LG phone screen will not react to touch
When a phone screen is blank or has a white screen, etc, there are three things that could be the cause;
1. Bad/defective screen and the solution is screen replacement. (In your case, your screen might be failing).
2. Software/Virus problem and solution is to flash the phone
3. Flex problem and solution is to change the flex. In some cases the flex might have shifted or not in it's right position, in this case, just fix the flex back properly and all will be well.
Bad/defective screen:
If your phone is having a white screen, first thing to do is dismantle the phone carefully, check if the screen is properly fixed to the phone board, also check if screen flex is intact. Once you've confirmed that all these are okay and screen is not still coming up, then it means your screen is bad. You can go ahead and replace the screen.
Make sure you confirm the screen is bad before you do any replacement.
Software/Virus:
Sometimes software/virus problem on phones are mistaken to screen problem. When a screen is white or blank, sometimes it's a virus problem. To further confirm, turn on the phone, wait for about 2 minutes when you know the phone must have booted fully, then use another phone to call the phone with white or blank screen. If the phone rings, it means it's not a virus problem, but if it doesn't ring, it means it's a software/virus problem.
If you discover your phone has a virus problem, you will have to flash the phone for it to display again,
Flex problem
When your phone screen is blank, white, has horizontal/vertical lines, turn images up-side-down, etc, be calm, there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out, that's why your screen is acting like any of the mentioned problem.
This is usually common with flip and slide phones. The flex worn out as a result of constant opening and close of the flip or slide phone. Samsung and Motorola phones mostly have this kind of problems.
Replacing the flex is the only solution to this problem. If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be replaced.
Conclusion
Disassemble your phone and check the screen part in order to verify from the above which is actually the cause of the problem.
Please let me know if you need anymore assistance.
Good luck.
Jan 12, 2012 | LG GT540 Cell Phone
I can not slide my unlock banor on my hd htc2. Took out sims and battery and nothing happened still cant unlock it .
Hi. Unfortunately your digitizer/touch pad needs to be replaced. No matter what you try u will have to replace it. You can buy it here.
http://cgi.ebay.com/HTC-HD2-GLASS-TOUCH-SCREEN-DIGITIZER-REPLACEMENT-OEM-/370508846486?pt=LH_DefaultDomain_0&hash=item56440c5596
The HD2 is an amazing phone but unfortunately this happens allot. If your phone is still under warranty you can contact your service provider, or you can chose to contact HTC and have them send you a replacement phone.
Jun 03, 2011 | HTC Cell Phones
Me screen will not function, it is visible on the phone, but is locked up and none of the touch features work. When I slide to unlock, nothing happens. I am receiving phone calls and texts but cannot...
Your phone is frozen, you need to hold the power and the home button together for at least 20 seconds. The phone it´s going to reset then it´s going to show the apple logo and then turn off. Then press the power button for 3 seconds and wait for the phone to restart.
Feb 19, 2011 | Apple iPhone Smartphone
Home screen magnified so large can't enter unlock code
Use three fingers and double tap on the screen. It's part of the new accessibility features on the 3GS.
Jul 04, 2009 | Apple iPhone Smartphone
I have a cect i9+ mobile phone and when I switch it on and try to slide to unlock it, nothing happen. Even when I receive a call and try to accept it nothing happens. Any solution pls
The 2 plastic layers beneath the glass and silicone infused screen have come in contact, resulting in the phone's processor inability to receive commands by touch. You'll have to purchase a new screen or send your phone in for a replacement.
Mar 06, 2009 | Dual Electronics CECT P168 Cellular Phone
My U700 Mobile Screen is black but keypad has lights
Hello nightstrom,
I have had the same problem. Looks like the slide cable is broken. I have managed to buy one and repaired the phone by myself, but it was not easy. This is a common problem by this phone.
Go to the shop and see if you stil have warrenty
Good luck
Feb 24, 2009 | Samsung SGH-U700 Cellular Phone
The screen on my cect i9 cell phone has stopped working.
Well i had the same thing happen with mines. So I played and played with it for like 45 minutes and then i figured it out. I turned it upside down and did the same thing where you have to slide it but i slided it upside down (Or Above the slide Bar) so after that it should work then everything will be opisite on the phone intill I did the
pen calibration so after that everything should work. :) well at least for Me
Feb 17, 2009 | Cell Phones
No touchflo
Do you mean that you cannot use the cube which IS displayed on the screen or there is no cube on the screen?
If the cube is not on the screen then just slide Firmly from the centre of the screen base so that the cube pops up.
If the cube is displyedbut not working...just hard reset..hope you have a data backup.
Feb 04, 2009 | HTC Touch Cell Phone (Unlocked) - Soft...
Huawei Prism U8651t Grey t-mobile Logo
53 people viewed this question
Top Huawei Cell Phones Experts
Computer Repairing
Computer Repairing
honeybun1986
john h
Are you a Huawei Cell Phone Expert? Answer questions, earn points and help others
