Question about Refrigerators
GE profile Arctica mo# PSC23SHMDBS Water Pump is not working how to repair pump
    Sergeant:
  • 479 Answers
It is hard to tell what you might referring to a refrigerator does not have a pump but it does have electrical water valves. if it is still making ice then the source is ok you might have a bad valve for the water side or a frozen resivoir
Posted on Mar 24, 2014
  • 1122 Answers
SOURCE: GE Profile Arctica Icemaker
YOU CAN PULL THE FRONT COVER OFF TO SEE IF THE GEAR WHEEL IS BROKE,OTHER THEM AT CALL YOUR LOCAL APPLIANCE PARTS STORE AND YOU CAN GET A NEW ONE FOR AROUND $70,THANKS-MIKE
Posted on May 29, 2008
Sea Breeze
  • 4654 Answers
SOURCE: GE Profile Arctica PSS25SGNA BS Icemaker is not
The water dispenser and ice maker side run separate sides of the water control valve. Fill ice maker with tap water and let it freeze. If it dumps the ice then does not refill then the water control valve is the problem. I will be back soon with a photo and some links, Thanks, Sea Breeze
Posted on Nov 18, 2009
aasc
  • 1606 Answers
SOURCE: GE Profile Arctica ice dispenser switch quits working
I came across this problem recently , and found the main control board was bad . Check this site first , to see if it can be covered under warranty .
http://www.scribd.com/doc/13371507/Ge-Motherboard-Concession-Letter
It was covered under warranty , at the previous customers residence .
Posted on Nov 20, 2009
Testimonial: "Thanks for the information on the main control board. I replaced it and its working great. I checked the warranty info but mine wasn't covered."
  • 256 Answers
SOURCE: GE Profile Arctica refrigerator - water is leaking
Turn off the water supply and check for cracked or broken water tubing/line. Make certain that there is teflon (white) tape on threads connecting water inlet hose from shut off valve at wall to water valve at refrigerator. If there is no apparent damage to tubing or hose, then your problem may be with a water valve solenoid that is not seating/closing tightly. Replace the water valve assembly, if necessary.
Note: If plastic tubing is damaged, etc., you can splice the tubing with a "coupler" and/or more tubing purchased from Home Depot or Lowe's.
Posted on Feb 19, 2010
SOURCE: GE Profile Arctica model # PSS25NGMD - can't control temperature
Check the little damper door next the water filter at top inside the unit. You will have to remove the covers to get it. The little plastic ends will break off and then you can not control the temperture it act like a freezer. Hope this helps Also you can get this part online.
Posted on Jan 31, 2011
Where are the duel water inlet valves located on ge fridge arctic profile
unless you have a water dispenser, top mount refrigerators usually only have a single inlet water valve. Either way, the valves will be located in the back on the machine and covered by the lower portion cover, but will have a small area for the water line to hook up. Just remove the lower panel in the back and you will be able to see it
May 22, 2012 | GE Profile Arctica Stainless Steel Top...
Nov 20, 2009 | GE Profile¿ Arctica® Energy...
GE Profile Arctica PSS25SGNA BS Icemaker is not working seems to be filling with water but no ice.
Nov 18, 2009 | GE Profile Arctica Stainless Steel Top...
Nov 17, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Water has stopped dispensing. was working fine yesterday. GE Profile ARCTICA
Could be in the door dispenser panel, Sol valve, main control board, water line freezing in freezer door? Call a qualified service company.
Ge refrigerator repair
Oct 22, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
My ice maker will not work, Ge profile Arctica.
Here you go...my dad had the same issues...Good Luck!
http://www.youtube.com/watch?v=sW2yqQjEcLI&list=HL1329704348&feature=mh_lolz
Jun 23, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
