Question about T-Mobile Cell Phones
P1 mean Why what is the code for
P1 light stays on. I even unplugged the unit for a day and it still shows P1
Hi Marilyn,
I've just searched for "error code p1 perfect" and the second hit was on fixya in June 2012. Have a look and see what I mean. The easy way to find answers for every product question Just Ask
Jul 29, 2015 | PERFECT AIRE Dehumidifier PA65
Blue star Visi cooler subzero error code p1
Amazon.com: Questions And Answers: WHAT DOES THE P1 error code mean??
www.amazon.com/.../ref=ask_dp_dpmw_al_hza?asin...
Amazon.com, Inc.Oct 19, 2014 - Hi David, According to the manual: "P1- Unit is defrosting-- Allow the unit time to automatically defrost. The error will clear after the unit self ...
Jul 26, 2015 | Dehumidifiers
P1 code what does this mean
what does the user manual tell you .
Jan 17, 2015 | Cameras
What is the P1 code on my Dayton Dehumidifier 5eaj9 mean?
Empty the bucket. Reseat the bucket carefully or the code will not reset. This is the only documented action for code P1.
Jun 14, 2014 | Dehumidifiers
What does P1 mean
t appears to mean "defrosting." In other words, the condenser coils have gotten too cold and are icing up..
The filter is probably full, or the thermostat is faulty. Open it up and clean the filter first.
Sep 17, 2012 | Midea MDF1-30AEN3-BA4 WP 30PT ES...
Spt 65 pint error code p1
According to the manual, this code, P1, means that it is in a defrost cycle. I now have the problem that my unit is in the P1 mode as often as it is in the dehumidification mode.
May 15, 2012 | Sunpentown 65 Pint Dehumidifier with...
Code on Top
I have another of their dehumidifiers, the MDF1-30AE. The first time the P1 came on, the unit stopped, because the filter needed cleaning. Recently P1 came on but the unit didn't turn off, and I had already cleaned the filter, so I phoned Midea customer service at 1-866-646-4332. The man told me P1 means it's in defrost mode and said to just leave it on and the P1 will eventually go away. It's been a while though....
Dec 01, 2009 | Midea MDC-45AE Dehumidifier
My Everstar mpm-08cr-bb4 stopped working and dislays P1
The P1 code means the lower water bowl is full.
Put a pan under it an pull the lower plug (some 10" below the upper drain plug that I hope you have a hose attached to.
Jul 07, 2009 | Heating & Cooling
My model is DDR4009EE, after it run for a while, the display changed from RH to "P1",what does "P1" mean?
My Danby DDR657EE shows P1 periodically also. So, I called Danby.
Danby's Consumer Help Line (1-800-263-2629) is always busy. So, I called their General number: 419-425-8627. The receptionist transferred my call to their Service dept. My call was answered in 2 minutes.
The Service Rep. described the following code for my dehumidifier model (DDR657EE):
P1 = Defrosting: the unit will go into Defrost mode periodically to ensure that the parts are working at the right operating temperature. It should be in Defrost (P1) mode for only a brief period of time. If the unit is in Defrost (P1) mode continuously for a couple of hours (or more), then you should call Danby Service for further assistance.
He had no documentation of a P2 code for my model.
He also described other General Codes (applicable to most Danby Dehumidifier/Humidifier models):
E1 = Not enough water
E2 = Not draining
E3 = Water temperature too cool
E4 = Overflow Switch activated
E6 / E7 = Problem with Temperature Sensor
So, if you see P1 periodically (for brief periods), then it would be normal.
Also, here is a link to Danby's FAQ page for Dehumidifiers (which answers some common questions):
https://www.danby.com/faqs.php?cat=12
I hope that helps.
May 11, 2009 | Dehumidifiers
Kenmore Dehumidifer P1 Problem...
I heard that the code P1 meant defrosting mode, and it will restart normally after it is done defrosting.
Apr 06, 2008 | Kenmore 53701 Dehumidifier
Cell Phones Logo
Top T-Mobile Cell Phones Experts
Starnley Johnwells
Starnley Johnwells
Computer Repairing
Computer Repairing
ismael castillo
Are you a T-Mobile Cell Phone Expert? Answer questions, earn points and help others
