Question about Bosch Ovens
Oven burning food
My Bosch electric oven burns almost everything cook in it.
  • 25 Answers
Don't worry my wife does the same thing. Not sure if your talking about the range top or the baking potion. We'll assume the baking area. If your using cheap bakeware that could be part of the problem try using a different cake or loaf pan of heavy construction. Also you may try reducing your temp in 25 degree increments to see if your oven runs hot. Example buy 3 cheap frozen pizzas and if they say value at 400 try 375 , 350, and 325. If one of those temps gives the desired result assist accordingly and consider contracting Bosch customer service to inquire about how to fix thermostat errors.hope that helps I didn't have much to work with.
Posted on May 08, 2014
vest6
  • 196 Answers
SOURCE: Oven not cooking evenly, outside is getting brown but inside is undercooked
Sounds like the igniter is not operating at full capacity. What happens is that the oven does not light when it should. Instead, the oven is cooling down much too far so when the oven does light it has too heat more rapidly. This causes the outside to brown/burn long before it should.
Posted on Jan 26, 2008
dauphine
  • 207 Answers
SOURCE: Oven gets too hot
Thermostat needs to be replaced.
Posted on Apr 11, 2008
SOURCE: Oven bakes unevenly and burns food
Jenn Aire oven is about 5 to 7 % cooler than electronic temperature setting. How may this be re-calibrated?
Posted on Oct 14, 2008
  • 147 Answers
SOURCE: large yellow flame, not cooking food thoroughly
I think ill give it a try for you. The gas lines come in thru you cutoff valve then thru you gas valve and on to the burner. right before the burner you will see a bell shape fitting. The gas line is in the center of the fitting and there will be some opening around this fitting That fitting has dust clogging it up. This is where the gas mixes with the air Turn your oven off and blow this fitting out.
Posted on Oct 25, 2008
SOURCE: Oven not working properly
I just solved this problem with my GE gas range. I waited forever for the oven to warm up. The igniter would glow, light the burner and burn for a minute or so and go out. It would repeat this process till oven reached operating temp, which took forever. Problem is in the igniter. It may be glowing, but it is not letting the gas valve stay open, because it is not hot enough to create resistance in it to keep gas valve open. I had replaced the thermostat thinking it was the problem. The good part about it was I could take it back because my buddy works at supply house. Once the igniter was replaced, the oven fired up and stayed lit till operating temp was reached. It will also hold the oven temp much better. Oh yea, the igniter will stay glowing while the burner is on. Hope this helps.
Posted on Nov 29, 2008
Tip
Common heating faults with Bosch HBL 5052 double oven
For all Free appliance repair videos visit our VIDEO TUTORIALS 1, If the Bosch fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the BOSCH element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your BOSCH fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your BOSCH oven thermostat
4, A quite common and easily overlooked answer is if your BOSCH oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
on Jan 19, 2010 | Bosch HBL 5052 Electric Double Oven
Large oven burning food on top shelf when in fan assisted mode
Always cook food in the middle of the oven. Assuming this is an electric oven, there is a heating element up there that will cause burning of food, much like a broiler works.
If you must cook that high up in the oven, then cover the food your cooking with foil.
Dec 16, 2009 | Kenmore Ovens
Hbn7052gb/05
If you have a BOSCH electric Cooker or Fan Oven which isnot heating it could be one of the following problems.
1, If the fan motor in the back of the oven is goinground and the temperature light is on (normally little red light), but there isno heat then you will probably need a new oven element, these are generallyvery easy to fit and readily available from our website these can be testedwith a electric meter.
To gain access to the BOSCH element you will have to remove the back platefrom inside the oven. Once removed you will see the fan and element,if you look closely at the element you will probably see a small holeburnt in it where it has blown. Sometimes however there is no evidence of afault but the element is open circuitie: broken inside the element casing, either way it will need replacing. Some elementswill are fixed from inside the oven and some are held in place by nuts from therear of the machine.
2, If your BOSCH fan oven is getting warm but takes avery long time to cook or is burning the food more on one side than the other,then you need to check if your oven fan motor is working you willsee the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into theoven then you need To replace the oven fan motor is a little moreexpensive and a bit more involved.
3. If you have theopposite problem ie: your oven is over heating and burning everything then youwill need to replace your BOSCH oven thermostat
4, A quite commonand easily overlooked answer is if your BOSCH oven is not working at all ie: no heatand no fan then the chances are that someone has put the oven timer into AUTO mode,simply put oven back to MANUAL mode and all should be working again.
Jul 30, 2009 | Bosch HBL 5032 Electric Single Oven
Tip
Common heating faults with Bosch HBL 5056 double oven
on Jan 19, 2010 | Bosch HBL 5056 Electric Double Oven
Tip
Common heating faults with Bosch HBL3420UC Electric single oven
on Jan 19, 2010 | Bosch HBL3420UC Electric Single Oven
Tip
Common heating faults with Bosch HBL 5032 single oven
on Jan 19, 2010 | Bosch HBL 5032 Electric Single Oven
Tip
Common heating faults with Bosch HBN 560570B / 560550B single oven
on Jan 19, 2010 | Bosch HBN 560570B / 560550B Electric...
Tip
Common heating faults with Bosch HBN 442 / HBN446 single oven
on Jan 19, 2010 | Bosch HBN 442 / HBN446 Electric Single...
Tip
Common heating faults with Bosch HBL 442 / HBL 446 single oven
on Jan 19, 2010 | Bosch HBL 442 / HBL 446 Electric Single...
Tip
Common heating faults with Bosch HBL 742 / HBL 746 single oven
on Jan 19, 2010 | Bosch HBL 742 / HBL 746 Electric Single...
Ovens Logo
181 people viewed this question
Top Bosch Ovens Experts
ashburton
Oloyede Monsuru
Are you a Bosch Oven Expert? Answer questions, earn points and help others
