Question about OverDrive Media Console
Windows 7 can't uninstall
Error 2378
How to fix error message; Error in actiom 3: file of application c:\atscallingcard\install\atshotket.exe
Do you use the ATS calling card application?
As the error message is related to ATS calling card application, I would suggest you to uninstall and reinstall that application (if you still use it) and then check if it works.
Uninstall or change a program
http://windows.microsoft.com/en-us/windows/uninstall-change-program#uninstall-change-program=windows-7
Sep 27, 2014 | Dell Computers & Internet
Tip
Top 7 Tips for Windows 7 Maintenance
Want to keep your Windows 7 running as fast and stable as new? Updating hardware configuration and protecting your PC from being attacked by virus and spyware is indispensible, but, that’s not enough, even with the "impressive/promising" Windows 7.
Well, there is no rose without a thorn. For enjoying the non-compromised features of Windows 7 and keeping its freshness as long as possible, you can take the following top 9 tips for Windows 7 maintenance, and save your time, money as well as get full control of your PC!
Windows 7 Maintenance Tip 1: Cleanup hard disk
Windows temporary files, internet cache, cookies, invalid shortcuts and unused files and programs can take up much room on your hard disks. Even you have just upgraded to Windows 7, those junk files can soon accumulate and eat up hard disk space. So regular disk cleanup should be part of your Windows 7 maintenance routine.
Windows 7, as its predecessors, has a built-in Disk Cleanup program, you can find it in Start>Accessaries>System Tools>Disk Cleanup.
Windows 7 Maintenance Tip 2: Defrag hard disk
Your hard drive can be full of fragmentation with time, which dramatically slows down Windows running. Microsoft OS including Windows 7 provides the built-in Disk Defragmenter tool, which lets you remove empty patches, pack pieces of files together, and thus occupy contiguous storage locations, increase the speed of reading and writing files to/from hard disk.
Frequency: Disk defragmentation should be performed every two or three months, because frequent disk defragmentation can decrease the span of hard disk.
Windows 7 Maintenance Tip 3: Speed up Windows 7 boot
Open Run, input “msconfig”, then select “Boot”, you will see a list of programs in that auto-start folder. You can manage them there.
Windows 7 Maintenance Tip 4: Scan and repair registry
Registry is the central database of Windows which stores the necessary information and settings for software and hardware running smoothly. Even you have uninstalled a program, respective information is saved there. Windows registry can be full of errors that cause the main system crashes, error messages, freezes and slowdown. You will be amazed when you view how many errors exist in your registry.
Microsoft experts never suggest people to manually change their registry, since any improper operation to registry can cause serious damage. Instead of taking that risk, using a third-party safe Windows registry optimizer might be better. You may refer to this article and learn .
Windows 7 Maintenance Tip 5:Defragment registry
Just like hard drive needs defrag, registry needs too. Registry defrag is to remove fragmentations and creates a linear registry, which can speed up registry access and program response. Some defragger also compacts your registry to a smaller size, thus it can take up less memory and make room for other programs running fast. There is a free registry defrag software which can safely defrag registry in two minutes for most Windows systems.
Windows 7 Maintenance Tip 6:Uninstall unused programs
Uninstalling programs that you seldom use is better than just removing them from your hard drive., because simple deletion can cause Windows errors. Some programs have the built-in uninstall app while others don't. Then you can go to the control panel and uninstall them. For those malicious programs that don’t allow you to uninstall, you can make use of a third-party uninstall manager (known as built in Wondershare Registry Optimizer) to get rid of them.
Note: cleanup registry is necessary after the uninstallation. Detail is given in the following part.
Windows 7 Maintenance Tip 7: Boost performance by adjusting registry parameters
This step is to change registry parameters designed to boost Windows 7 system performance, such as automatically end hung applications, optimize internet connection, speed up loading web pages, speed up Windows shutdown, etc.
There are many online tips talking about how to manually revise registry settings for better system performance, but manual revisement fits more for computer expertsor than for beginners. Beginners has better use a system optimizing utility (known as built in Wondershare Registry Optimizer) to have this done in single 1 mouse click.
on Dec 23, 2009 | Computers & Internet
Install windows 7
Hello
The file "uncdms.dll" is associated with Windows Desktop Search. This is not required for installing Windows 7.
I would suggest booting the computer, ignore the "cannot find uncdms.dll" error message. Go to CONTROL PANEL, ADD REMOVE PROGRAMS or PROGRAMS AND FEATURES and uninstall Windows Desktop Search.
Reboot the computer and verify the error no longer appears. Once this is verified, you can continue with the Windows 7 install.
Nov 02, 2013 | HP Compaq Presario SR2010NX PC Desktop
Error Message on Starcraft install
I would uninstall the game then reinstall it and see if that makes a difference if not it could be you video card.
Jul 28, 2012 | Blizzard Entertainment StarCraft Battle...
I can't uninstall a software from my notebook with windows 7, 64bit. The error code is 1628.
download this http://www.techsupportforum.com/forums/external-link/?link=http%3A%2F%2Fcleanup.stevengould.org%2F and then try again :)
Feb 11, 2012 | Computers & Internet
Can not scan error code 00000015 , I have just updated to windows 7, scanner worked well with windows XP
Just uninstall and reinstall the printer driver because it is outdated in windows 7 operating system. If still not printing, try to download free software for windows 7 compatibility
Jan 05, 2011 | HP PSC 750 All-In-One InkJet Printer
How do i uninstall cd dvd maker 7 plat
( In Xp) Go to Start menu> Control panel > classic view on left side.
Add/remove programs
select the Cd Dvd maker 7 and click on remove.
This must take a while and uninstall the software.
If you get any error it will not be removed, there are other procedures to remove if you get error.
If you get error while uninstall contact me I will guide you.
I hope this helps you.
Rate my solution.
Regards
May 25, 2010 | Newtech NTI Media Maker 8 Suite for...
I get an error 0x00000015 when i try to scan from my pixma mp530. Iam running windows 7. Uninstalled printer the nreinstalled with " Latest drivers ?" Need a little help please.
Uninstalled the printer. Reinstalled using the cd that came with the printer instead of using the drivers off the internet. Configure the printer to work with windows 7.
Feb 03, 2010 | Canon PIXMA MP530 All-In-One InkJet...
I have a Canon MP620 Wireless all in one printer - it is printing and copying fine, but whenever I try to scan, it aborts due to scanner driver. It was working perfectly until I installed Windows 7...
If you upgraded from Windows Vista to Windows 7 on the same computer, did you uninstall the MP620 drivers first? If not, the old driver files can be causing the problem.
To correct, go to this link, type "windows 7" in the search box in the center of the screen, and click on the Search button. Now click on the link "ERROR: Cannot communicate with printer after upgrading to Windows 7". You will have a step-by-step procedure for uninstalling the old files and downloading/installing the Windows 7 drivers (printer and scanner).
Dec 29, 2009 | Canon MP610 Photo All-In-One Printer
OverDrive Media Console Logo
Top OverDrive Apps Experts
Lesley Cameron
Lesley Cameron
Are you an OverDrive App Expert? Answer questions, earn points and help others
