Question about OverDrive Media Console
Can't uninstall program
Can't uninstall error 2378
How can I uninstall the software if I'm receiving the error "the program cannot be uninstall"?
try going into safe mode and on installing it there is probably a program preventing it from uninstalling. What kind of Windows are you running?
Feb 19, 2015 | Iolo Technologies System Mechanic: Windows
Tip
How to uninstall program from my DELL computer
Questions people asked:
1 How to uninstall program that’s not showing up?
2 I go to add/remove programs and want to uninstall program. It says “error, can not delete the program”, how can I remove it from my DELL computer?
3 I recently install McAfee and my computer gets a Blue Screen, Should I uninstall it? How to remove it from Control Panel?
You may face stubborn program of uninstalling an unwanted program especially it is an anti-virus.
How to remove corrupt programs from your computer in one minute? You can get the best solution to remove a program completely from your PC.
Add/ Remove Programs utility usually helps you remove programs from your computer. Unfortunately, it can only find common program install on your computer. It can not show hidden programs and some malicious programs such like windows messenger, vista protector, Norton anti-virus 2006, etc.
You can not remove anything if you uninstall using Control Panel. Every time you install a program, your registry entries will be modified. The residue can be the causes of Blue Screen, computer freezing, DLL error and computer slow. If you want to remove programs completely, you should also remove associated registry entries. It is also the best solution to remove corrupt programs.
Get rid of programs which combine well with the operating system:
Troubled with uninstalling programs? Don’t worry! You can solve it in one minute. ErrorFix integrate with Windows registry fix tool, uninstaller, invalid file removal and IE restore program.
Download this excellent uninstaller now.
With this software, you can forcibly remove a program even it is running. Why not experience this wonderful software? You don’t have to get more computer savvy.
on May 26, 2010 | Microwave Ovens
How to fix error message; Error in actiom 3: file of application c:\atscallingcard\install\atshotket.exe
Do you use the ATS calling card application?
As the error message is related to ATS calling card application, I would suggest you to uninstall and reinstall that application (if you still use it) and then check if it works.
Uninstall or change a program
http://windows.microsoft.com/en-us/windows/uninstall-change-program#uninstall-change-program=windows-7
Sep 27, 2014 | Dell Computers & Internet
How can i hook up my 2 pyle pla 2378's to a sony cdx gt09 cd player and get the maximum wattage from my subs
your amp should work with any cd player. the only way to make sure to get maximum wattage out of your subs, is to make sure that they are wired properly to get the correct impedance at your amp
Oct 16, 2012 | Pyle NEW PLA2378 2000W 2 CH CAR AUDIO...
C:/Progam Files/blocktards/unins000.dat what is this error and how do i fix it
Hello crouch8323,
Welcome to FixYa.Com!
Unins000.dat is a files that if used by Blocktards' uninstaller to properly uninstall Blocktards off of your Desktop. If your are trying to uninstall Blocktards and you are getting an error message, I recommend that you uninstall Blocktards from the Control Panel's Add & Remove Program (for Windows XP) or Programs & Features (for VISTA or 7). If you still have the same error message, you can also try uninstalling Blocktards by going to the Start Menu, All Programs, Blocktards, and click Uninstall. If these steps give you the same error message, you may need to use Blocktards installer to uninstall the game, see if running the installer gives you the option to modify, remove or repair. And if all else fails you can always use a 3rd party uninstaller software like the option found in CCleaner.
Regards,
Deathschythe33
Aug 22, 2011 | Computers & Internet
Cant uninstall driver for a4tech cam pk-635 from uninstall programs for win 7.. getting error message >SetupDLL\SetupDLL.cpp(409)$7.0.100.132@Windows XP (7600) IE 8.0.7600.16800
You try uninstall driver of a4tech to add / remove programs you go to control panel you open add / remove programs then you wait till all the programs comes out then if you see the program or driver of a4tech in the programs list just clik then wait for the instruction remove this program or uninstall this program then if you like to uninstall just choose uninstall or remove which ever then wait for the uninstalling process.
Hope i can help for your a little problem.
Best regards,
Lito E. Fidel
Jun 28, 2011 | A4tech PK-635 Webcam
I want to uninstall the program but it won't. Dell Windows XP is my computer. It wasn't working so I was going to uninstall it and then reinstall it, but the program won't erase off my computer. It freezes...
try to use revo uninstaller to uninstall a program.
Instructions to use the program :
open up a program and select the program you want to uninstall. Select the option safe uninstall and click next. It will start uninstalling a program. If it gives you any error you just need to click next and it will show you all the files from the registry, select the files highlited in bold and click delete then click next. press select all and then delete all. clcik next and then finish.
To download the software click on the link below :
http://download.cnet.com/Revo-Uninstaller/3000-2096_4-10687648.html
Mar 07, 2010 | GE EasyCam Webcam
Remote Clicker Model No. KLIK 2 can not be programmed to operate a Chamberlain door opener FCC ID HBW 1127 w/Merk 1/2 HP motor (Model No. 929 ?) although I have followed the instuctions furnished with the...
If you follow the watch the video and follow the instructions on this site and still cannot get your opener to program then you have a bad logic board.
http://www.chamberlain-diy.com/doityourself/pages/accessoriesmodeldetail.aspx?modelId=1478
Nov 15, 2009 | Universal Garage Wireless Keyless Entry...
Uninstall a program that wont let you uninstall it.....
u can unistall it when u open the installing program that u can get from avast website
Feb 13, 2009 | Acer Aspire X1200 Desktop PC - Athlon X2...
OverDrive Media Console Logo
Top OverDrive Apps Experts
ray gallant
Are you an OverDrive App Expert? Answer questions, earn points and help others
