Question about Neon ineo INA313U 35Inch External SATA Hard Drive Enclosure to USB 20 Capacity Support up to 2TB 1 (718122287444) Serial ATA USB 20 Drive Case
My pc at one point but now it is not. red light bloimking all the time
Thats it need help
I have a Gateway 310 XL H desk top PC. After the storm, Isaac, It won't power on. The red and green lights come on, the red goes off after a short time. The monitor flashes a manfacture logo then
The system is powered up if green light on, the hard disk is powered up if red-light on for a few seconds then goes off, but I assume it's not loading up after that. You have no output to video.
Try holding f2 or f4 to load default bios when turning on. If that doesnt work then That would point to me that there is a problem with either:
1) processor burnt out, or needs refitting following a knock to the case causing a bad connection.
2) ram burnt out or not correctly installed. Try refitting the ram or using a different combination of ram.
3. Bios chip burnt out. Sometimes you can literally see the chip is slightly melted.
4. Other motherboard fault, look for melted chip or damaged component.
5. Psu faulty or not connected properly. Check connections, or bench test with another psu.
Have you moved the pc recently? Sometimes dust builds up under processor or along ram, and when moving pc giving it a slight knock can cause bad connection. If dusty, remove clean and re install.
Hope it helps.
Sep 05, 2012 | Gateway 310 S PC Desktop
Error message - "some ink
All the ink tanks should be red with no flashing.
The tanks that are flashing or have no red light on , need to be replaced.
Feb 14, 2011 | Office Equipment & Supplies
Hello, When I power ON the desktop, It flashes a green light then after 1 second will start beeping with a red light. it beeps four times then pauses then beeps again for about twenty...
This issue might happen due to RAM.
To resolve this issue:
Turn of the power supply for your desktop.
Please remove the side case on your tower(CPU).
find the RAM slot and remove the RAM from the Slot.
Clean the RAM terminals with the help of cloth or Eraser.
After cleaning place the RAM on RAM slot.
Now try to turn ON the PC desktop. If it is working thats fine or else you need to replace another RAM to check.
Please refer the below figure to find the RAM Slot and the lock to remove the RAM.
Jan 21, 2011 | HP Compaq dc7700 PC Desktop
I want to add a light in my room which is apart of the upstairs lighting circuit. The only problem that I have is that all the terminals within the celling roses in the upstairs lighting circuit are being...
The problem is that you need to understand that the red and black wires may not be power and return. The main red line is broken at a point and a new cable run to the light ( red + black) or (blue+ brown) this is merely the switch circuit fore that light. So if you mistake the two points it may be that what you have is red+red to your globe. ( Is that clear?) you would need to find the common black + the red to take power to the Red+black to your new ceiling rose, but breaking the now new red wire somewhere and joining in a new red_+ black that goes down to the switch
Use a power checking device as sometimes in some roses where multiple circuitsw feed fom Black and Black can be live
Please rate my help++++Thanks for using FIXYA
May 29, 2010 | Electric Door Light Switch
Red arrow poiting down
If I'm right, and this vehicle is a stick, this model has shift indicator lights. Green arrow points up when its time to shift up, and red arrow points down when you need to downshift. If it does, the tach, which registers the motor rpm's, which controlls the lights, is malfunctioning.
Feb 03, 2010 | 2003 Pontiac Sunfire
Red warning light shows up
It is because of weather when the weather is not clear or it gets rain the device is unable to catch the signal that's why it get red. :)
*Cheers*
Dec 15, 2009 | Alvarion Wireless Access Point
We have a xbox360 and it keeps on locking up and some times we get 3 light can you help
It is headed for the 3 red lights. Its the solder under the GPU. When the motherboard heats up it bends and the solder points under the gpu lose contact. We can fix if interested email
xbox360fixer@verizon.net
for estimate
Thanks
Dec 25, 2008 | Microsoft Xbox 360 Console
Blinking red light
I DO HAVE THE SAME PROBLEM , ONLY THE RED LIGHT BLINKING ,NO SOUND NO PICTURE '
PLEASE I DO NEED HELP TO FIX IT .THNKS
Nov 15, 2008 | Akai LCT2715 27 in. LCD Television
Vista PC connecting to DSL-504T modem/router
first make sure that model router you have supports vista. i can help you more if i had alittle more info on your router.
Jun 01, 2008 | Compaq Presario 5000 PC Desktop
MY mouse has a red light that continously flashes. I charge it at night and all day the red lit flashes. Time for a new mouse or what?????
You need to tell us more then "MY mouse"... but I'll try to help.
First: there must be button to power off/on your mouse, switch to off and then on. If red light continues to flash clean connections on mouse and on dock (where you charge mouse), try to charge it, if red light continues to flash check if you can replace battery if not it's time for new mouse.
May 31, 2008 | Computers & Internet
Neon ineo INA313U 35Inch External SATA Hard Drive Enclosure to USB 20 Capacity Support up to 2TB 1 (718122287444) Serial ATA USB 20 Drive Case Logo
71 people viewed this question
Top Neon Computers & Internet Experts
David Payne
David Payne
Are you a Neon Computer and Internet Expert? Answer questions, earn points and help others
