Question about Riccar Vacuums
Riccar model 1700 hose broken near where it enters the handle. How can I open the handle to repair the end of the hose?
If it is not repairable, can I purchase a hose and replace the house without buying the entire control handle?
More than likely you can just take it into your local guarantee vacuum and sewing center and they will tell you the cost and get the part for you
Posted on Mar 24, 2014
reddevil6
  • 1673 Answers
SOURCE: VACUUM REPAIR
There are 2 tabs that stick out on the release, they fit in slots, so from the top look down and you can see them, using a flatblade screwdriver that will fit in there, push the side in to release it, which isn't easy, but it can be done. When you get the old one out, then the new one, push down on it until it locks into place.
Posted on Mar 06, 2008
SOURCE: Whispertone powerhead handle release replacement
Take a butter knife and/or flat head screwdriver and press forward on the four tabs that retain the pedal.
Posted on Jun 02, 2008
SOURCE: Hoover agility steamer lower hose broken
Go in your garage or to your workbench and grab a BFH whack the **** out of the rest of the steamvac and never buy one again. For those of you not familiar with a BFH it is a Big F_ _ _ ing Hammer.
Posted on Jul 22, 2009
SOURCE: How to replace just the Kirby 210097 Hose End For
If you just grab it where it swivels and pull with a slight bending motion the plastic "bayonet" section on the end of the hose will pull out of the plastic housing that attaches to the vacuum. Don't pull on the corrugated hose section or you will ruin the whole assembly.
Posted on Jan 31, 2010
VacuumRepair
  • 438 Answers
SOURCE: repair hole in hose near handle, can't get handle
Hello There,
We've actually shot a video on how to repair the hose on the kenmore vacuum cleaners. The repair we show in the video is different from yours, but the video will clearly show you to pop open the handle assembly.
Here's the video;
I hope this helped you. If this was helpful, please be sure to rate the repair, or leave feedback for me. This is greatly appreciated by the Fixya community, and is what keeps repair experts like myself continue to answer free questions, and not just the premium questions which you have to pay for. Ranking someones solutions ensures FixYa will continue to have the best repair expert technicians around giving great free advice! Thanks so much,
Chris Jones
GoVacuum.com
Posted on Jan 08, 2011
Take handle apart
Duct tape fixes most things and a hammer the other things :>) In your case Duct Tape for a quick fix or Google
make model replacement hose
Jul 18, 2016 | Vacuums
What size replacement belt for riccar 1700 vacuum
You need to contact your local Riccar dealer. They are not available except from Riccar dealers.
www.riccar.com
Sorry.
May 30, 2014 | Riccar 3623210300 RC 1700, 1800 Full Size...
Riccar 8995 no suction
I think you mean it's an 8955, Riccar has not had a 8995 model. If there is no suction in the hose it has to have something clogging it. Open the little round opening on the back of the vacuum where the hose attaches to see if you have suction there.
May 18, 2014 | Riccar Vacuums
Riccar 1700 melted connector to circuit board...
It might be an easy fix but should be done by a qualified Riccar dealer.
Jun 03, 2013 | Riccar Vacuums
The switch to my Riccar 1500p hose is broken for the 2nd time. I don't want to replace the entire hose again, where can i get the switch and leads?
Take the screws out to take the handle apart. Remove the switch and take it to your hardware or local vacuum to to get the correct replacement.
Apr 03, 2013 | Riccar 1500 Simplicity S24 And S20...
Broken handle riccar radiance
Take the broken part to your Riccar dealer. The newer models have an upgraded more durable handle. You can get the upgrade for an older model.
Mar 25, 2013 | Riccar Radiance Vacuum Cleaner HEPA Filter...
Suction not working
If suction is good at the canister but not at the end of the hose you must have a clog in the hose
Jan 02, 2013 | Riccar Generic 1400 1500 1700 1800...
I have a CT600 power brush that would not power up. Thinking the motor was bad in it, I replaced it with a new CT700 power brush, I am still experiencing the same problem the power brush itself does not...
First try connecting the power nozzle directly to the hose. If it works, the problem is due to a broken wire or faulty connection in the wands. At least one wand will need to be replaced.
My guess is it's probably due to a broken or disconnected wire. This could be in the hose (most likely), the wands, or the tank wiring itself. You can test the hose wiring by using a multimeter or continuity tester. A tester may be easier for you to use, and will provide the info needed.
Disconnect both ends of the hose, sit down, and lay the ends on your lap. Touch one end of the probe to a terminal on one end of the hose. Place other probe on a connector at the other end. One connector will light, the other won't. Now repeat with the other terminal at the first end of the hose and repeat. The terminals will read opposite the reading in the first test. If the light fails to turn on with either test, it's a broken wire in the hose. This is most likely near/at the handle end, or at the wall end. In some cases it can be repaired, but not always.
It could also be due to a faulty switch.
For a definite diagnosis, take the unit, the hose, power nozzle etc. to a repair center.
Jan 28, 2011 | Broan-NuTone VX550 Bagged Central System...
Riccar 1700 power nozzle wont turn on
Make sure the 'Power brush' switch on the contol panel on the hose is depressed. Check the circuit breaker on the power nozzle; it will either be a button or a breaker that looks like a rocker switch, try to reset it.
Is the power nozzle motor running but the brush just isn't turning? If so you may have a broken belt. Not a likely solution since the belt is a lifetime belt, but still remotely possible.
Apr 23, 2009 | Riccar RC1100 Compact Vacuum
Riccar rc1100 won't turn off
I am an riccar dealer, and you either have a short in the wire leads from front of vacuum to circuit board or a bad circuit board which if so the boardd will have to be sent to manufacture to be rebuilt as there are no new circuit boards available. if not under warrenty which i doubt since riccar hasnt made these models for a while. would recomend replacement with either sunburst or moonlight model as they are a comparable replacement to the repair. or just simply just plug and unplug machine, if it doesnt bother you to do so. If more questions email me at drago640@yahoo.com subject riccar, or go to www.riccar.com to locate nearest dealer
Mar 22, 2008 | Riccar RC1100 Compact Vacuum
Vacuums Logo
83 people viewed this question
Top Riccar Vacuums Experts
ray gallant
Thatvacguy.com
Are you a Riccar Vacuum Expert? Answer questions, earn points and help others
