Question about Bosch WFVC3300 Washer
Glass Window Shattered During Wash
During a spin cycle, the washer started making an odd, but not alarming noise. About 15 seconds later, the glass window shattered (its a front loading machine). Its like it exploded, with TONS of tiny glass shards everywhere. Has this ever happened to anyone else? Is there any sort of recall on this issue? I'm planning on repairing it myself - should i expect any sort of internal damage to the washer, or is it just a matter of vaccuming out the broken glass and replacing the window? Thanks in advance.
  • Stephanie Rosenberger
    Stephanie Rosenberger Mar 24, 2014
    ALSO: This was a load of towels. I am 100% certain nothing in the wash caused the glass to shatter.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 86 Answers
Maybe the internal drum was rocking due to an unbalance with the weight of the towels that it has knocked onto the door causing the glass to break. only thing i can think of , glass shouldn't break unless its hit or there is a large amount of temperature change, adding cold water to a hot glass for instance.
Posted on Mar 24, 2014
  • 1 more comment
    That would actually make a lot of sense and would explain both the noise I heard and the crazy amount of broken glass. It coudnt have been a water issue, as it happened during the spin cycle. Do you know of any way to stabilize the drum, or to prevent this from happening again? Do you think the broken glass has damaged the washer at all?
  • weirdtop Mar 24, 2014
    depending on the age of the machine it might be casued from old stabilisation springs. or it could just be an unfortunate circumstance where the towels didn't evenly lay around the drum when spinning. was it a full load of towels? maybe less of a load would prevent future issues.
    Add a Comments oh the only thing that would be a issue of glass damaging the machin i can think of is if the glass got into the water pump area, would damge the pump itself or at least the outflow pipes
3 Suggested Answers
vest6
  • 196 Answers
SOURCE: Front glass window seems loose
When the machine is spinning, place your hand gently against the glass and check for a vibration. Do not push on the glass.
This is to check and see if the vibration is from the door or from somewhere else.
The front door comes apart. Disassemble the door and check the seal where the glass sits. If this seal is worn or out of place it will allow the glass to rattle against the rear panel. When the machine is spinning, place your hand gently against the glass and check for a vibration. Do not push on the glass
Posted on Jan 12, 2008
  • 5 Answers
SOURCE: what is the life expectancy of Bosch front loader
not long. have a Bosch Axiss WFL 2060. It started making buzzing noises starting about a year ago and I ignored them. It failed and I am replacing either the motor or/and more things. If ur a DIY its definitely less expensive than a new machine. dwkendall sends
Posted on Jan 18, 2011
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
We discovered broken glass dish in bottom of dishwasher with some pieces below the bottom pump area. Shortly after the washer is making a louder noise during operation time. The water pump is quite when...
sounds like you have broken glass in the wash pump you will have to remove pump from sump and clear also check the drain pump.good luck let me know how it goes
Jun 22, 2010 | KitchenAid KUDK03ITBK Built-in Dishwasher
Washing machine - terrible noise during spin cycle
sounds like the drum is rubbing on some part of an exterior wall of your washer,.or you have a bearing going, or worst case scenario you have transmission problems and need to get a serviceman in to check your machine.But firstI would call the manfacturer and explain the problem they may be able to resolve it over the phone give them model no. Make and year of manfacture they hopefully can help you with this
Jan 07, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
Maytag washer makes loud grinding noise during the spin cycle
if it's making a noise then either your drain pump bearing is going out or your thrust bearing is going out (assuming the noise happens in both spin and wash). Tip the washer backwards so that you can get underneath of it. Take the belt off and spin the pump pulley on the right side. This should spin effortlessly.
The middle pulley is the trustbearing pulley. Spin this--- one direction it should have a little bit of resistance--- the other should have more resistance
Aug 20, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Our dishwasher is making a loud noise during wash cycle.
if you have a torx 20, and torx 15 screw driver, you an remove the screws from the top plate of the wash motor, and underthere youll see another t15 screw converingthe "chopper" assy, sounds as if a seed, of chicken bone, perhaps apiece of glass hasgottne down there
Jan 25, 2009 | Whirlpool GU3600XTSY Stainless Steel...
Washing machine makes buzzing noise
Check the water pump for an obstruction in the chamber area, your pump may be sticking and that will cause the buzzing sound. The water pump runs during the fill portion of the cycle on several of the selected wash cycles to recirculate the water.
Nov 06, 2008 | Fisher Paykel EcoSmart GWL15
NAV5800a top loader washer
The inside of your agitator became worn, and possible strip out the spline that allows the agitator to properly grip the shaft. The loud noise mustly occurs during the spin cycle. If you hear this loud noise your load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it.
Sep 02, 2008 | Amana NAV5800A Top Load Washer
Jan 12, 2008 | Bosch WFMC 3200 Front Load Washer
Bosch WFVC3300 Washer Logo
113 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
