Question about Bosch HBN 131560B / 131520 hot-air Electric Single Oven
Cleaning roof of oven, does the can the element be removed
    Problem Solver:
  • 8 Answers
Oven roof is made up of metal normally and i think Liquid Roof is best for repairing leaks. You should have a look at it.
Liquid Roof AND RV Roof Coatings
Posted on Apr 07, 2014
Euromaid oven instructions
Try search engine
Jul 20, 2014 | Ovens
How can I clean the roof of my Stoves 720EF Electric Double Oven
I have been using the Lakeland brush on oven cleaner for ALL of the inside of the oven including the stay clean bits without any problems. With the 720, I just brush on the cleaner and follow the instructions. To answer you question, I don't actually lie upside down, you should be able to reach it fairly easily. You may need a number of attempts to get the worse of! Be careful of the thermostat sensor at the top rear right of the oven. It should be bright and clean but will not take any heavy handed cleaning, especially the thin wire leading to/from it. FYI the fan cover at the rear of the oven is held on by 4 self tapping screw and comes off/ goes back on with any problems.(The rear of the cover by the vents build up with grease). Don't use the cleaner on any aluminuim bits ( which includes the fan) as it harms it.
Dec 31, 2011 | Stoves 720EF Electric Double Oven
How do I get the door open after self cleaning and what do I push to self cleaning
Hi, Some ovens are self cleaning During the cleaning process, the oven heats up to a temperature of 900 degrees Fahrenheit. The extreme heat cooks off food and spills inside the oven, leaving ash that can easily be wiped out. The oven door locks while it is cleaning to prevent the door from being opened. Self cleaning ovens are better insulated than regular ovens to keep the extreme heat inside.
Instructions
Read the owner's manual that came with your oven before you perform self cleaning. Although all self cleaning ovens work basically the same way, there may be slight variations for some manufacturers and models.
Take out the oven racks. You need to clean the oven racks by hand, and then put them back in when the oven is done cleaning.
Wipe up any spills and messes inside the oven first, using warm water and a mild soap. Ovens smoke more during cleaning when there is food inside. Wash the inside of the oven door as well. Do not scrub the door gaskets, just gently wipe them off. Damaging the gaskets prevents the oven from sealing.
Lock your oven door manually if your model does not lock it automatically when you clean.
Open a window near the oven for ventilation. There is a certain amount of smoke when you clean the oven. The dirtier the oven is, the more smoke is created.
Turn the control on your oven to "clean" and set the timer for 2 to 5 hours depending on how dirty your oven is, and what the manufacturer recommends.
Wait for the cleaning to finish and the oven to cool before opening door. When oven is fully cooled wipe up any ash inside. If your oven is not completely clean, next time set the timer for longer. If your oven is spotless you might want to see if you can get away with a shorter cleaning time.
Tips & Warnings
Because self cleaning ovens are better insulated, they are more energy efficient when used for cooking. However, if you run the self cleaning feature on your oven more than once a month, you offset the savings you realized. With light to moderate use your oven should be able to be cleaned every one to three months.
Save on the electricity used with a self cleaning oven by cleaning the oven right after use at a high temperature. For example, if you set your oven to clean after making French fries at 450 degrees, it takes less energy to get the oven up to the required 900 degrees.
If you have pet birds, take them out of the house before cleaning your oven. Over heated cooking surfaces, oils and fats, can create fumes that are harmful for a bird's delicate respiratory system.
Hope it helped.
May 28, 2011 | Ovens
Hi lost the manual..need to start self cleaning
An electric oven is a great oven choice because of the advanced self-cleaning feature often available on certain models. A self-cleaning oven uses high temperatures to clean crusty baking spills and splatters and free its owner from having to use harsh chemicals to clean his oven. The following 4 steps lay out how a self-cleaning oven works.
Step 1 - Setting the Self Cleaning Mode
Depending on the style and brand of oven you own, you start the self-cleaning cycle by setting the oven's operating dial to "Clean," a function that can be as simple as setting a timer knob or pushing one or two buttons.
Step 2 - Cleaning Cycle
Once you have set the self-cleaning cycle, the oven coils-both lower and upper--will begin to heat. These self-cleaning ovens are protected from high oven temperatures damage by heavy insulation installed in their walls and door during the manufacturing process.
Step 3 - Automatic Door Lock
When the oven reaches a pre-determined temperature, the lock on the oven door engages, preventing anyone from opening the door until the oven temperature has cooled.
Step 4 - Removing Residual Ashes
Once the cleaning process is completed, including cooling, you can then remove the residual ash by wiping the bottom oven surface with a damp cloth or sponge.
Hope this helpout
May 17, 2011 | Ovens
My grill element looks as if it has melted and
From the description you have given it would seem as if the element is'gone' i.e broken.
You will need to have it replaced before it does any more damage to the oven roof.
Jan 06, 2010 | Zanussi ZBF360X Electric Single Oven
How to clean roof of AKL 828 /1x
Buy a can of oven cleaner suitable for use in electric ovens and follow the instructions on the can. Its basically spray the aerosol foram and wait then rinse off or preheat the ovena nd do the same and depends on the brand that you buy. It is a bit smelly but does the job! Most supermarkets and domestic appliance stores stock these products.
Sep 29, 2009 | KitchenAid Architect Series KEBC208KSS...
Difficulty in cleaning my Miele combi oven
I have the same cleaning problem as Denise503 with her Miele combination oven - help if anyone has a solution - I have got to the stage where I don't want to use it.
Apr 10, 2009 | Ovens
Neff U1421W2GB/02 Double Oven Grill problem
There are a couple of solutions to this prob,
You can get some plastic metal and build up the corroded area after cleaning it first, then you can drill a new fixing hole for screw.
The other thing you can do is to cut a small metal plate to fit over bad area, drill and fix it to oven liner, again drill a new fixing hole for element to be secured.
Plz rate my solution.
Thanks.
Jan 15, 2009 | Neff U1421 Double circotherm Electric Oven
The screws holding the grill element to the roof of my Electrolux oven have come out.They can be removed in order to clean the roof of the oven. According to the manual, it is easy to screw these back in...
Possibly held with self tapping scerws, and hole has enlarged, all you will see are 2 small holes if this is the case, then use larger screws..
If this helps, please leave positive feedback. Thanks
Nov 26, 2008 | Ovens
Bosch HBN 131560B / 131520 hot-air Electric Single Oven Logo
98 people viewed this question
Top Bosch Ovens Experts
ashburton
paulcarew
Are you a Bosch Oven Expert? Answer questions, earn points and help others
