Question about Bosch Axxis WFL 2060 Front Load Washer
A few months ago the unit started becoming sensitive: that is, when I would close the door, less than gently, it would automatically start, not waiting for me to press the start button on the panel. Now I can get it to fill and it starts to agitate but barely. If I press the drain selection to drain the water, I get a "door open?" error message - and a blown fuse.
    Genius:
  • 1,689 Answers
Hi dkensil,
thank you for using fixya.
yep you are correct, this is a blown fuse and a blown capacitor issue. worst case is a faulty control board, but this is thinking too far ahead.
these issue is usually a result for a faulted control board because the machine cannot understand the command you are giving it doing a different task. this can be resolved with cleaning and re-soldering of circuit of the control board. replacing the control board is also and option if the repair man tell you that re-soldering has a 200$ price tag.
this is doable through DIY, but having a professional do it will assure functionality.
regards,
voodoo
Posted on Jun 14, 2009
Difficult to start (hear noise) turn the key few times and starts
- For starting problem check the following:
- Battery (perform battery test with battery tester).
- Check battery terminals for any corrosion and sulfate deposits.
- Battery to starter motor cable.
- Battery to engine ground and chassis cable.
- Starter relay and solenoid.
- Starter motor.
- Ignition switch.
- Wiring and connectors.
- Alternator.
Mar 02, 2014 | Cars & Trucks
50@att.nethow do i adjust the travel and senativety of the door
On the side of the opener there are 2 knobs. One for sensitivity, one for close and open.With one of the closers in one hand start adjusting the open close until you have it right. Then put a empty cardboard box under the door to adjust the sensitivity,so it will automatically will open when it hits the box.
Aug 09, 2011 | Garden
I have a Samsung SMH9187 microwave oven that is about 9 months old. Just a few days ago, we opened the door to put something in and the fan instantly turned on. Closed the door and it stopped until we...
This problem is caused by a microswitch that is sticking in the closed position. Inspect and replace the defective microswitch in the latch assembly.
Nov 28, 2017 | Samsung SMH9187 Microwave Oven
Active Vent opens and closes continuously while unit is idle
I had GE look at the problem today (my microwave is less than a year old and under warranty). He replaced the cam louver and that seems to have fixed the problem. This is a small motor accessible by removing three screws and the active vent door. The whole visit was less than 15 minutes.<!-- from fixya rte -->
May 03, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
My automatic door on my van starts to close then when it is almost closed it automatically reopens without closing. I have looked and nothing is blocking it from closing.
Take a rag with rubbing alcohol and start wiping out all the creavas. Get it spick and span, those dern things are super sensitive a little peice of popcorn kernal will not let it close
Jul 29, 2008 | 2000 Nissan Quest
LG LMVM2055: Cooked itself?
First you will need to answer a few quick questions between yourselves.
  1. Do you have life insurance?
  2. Is it enough for the wife and kids to survive on
  3. Whats the number for 911
After you answer all these questions, then pick up the microwave, and take it for a long drive.
There are bits inside there that will happily kill you days after it has been turned off. (some even weeks)
For the cost of a replacement in this case, it's not worth it.
Apr 18, 2008 | LG LMV2055ST Microwave Oven
Door hard to close have starts to close stops and starts to open again have to keep stopping and reversing door mult times to get closed
There should be two small white adjustment knobs on the side of the unit that you turn with a small flathead screwdriver. These are the load / limit adjusters.
What it happening is it think there is something stuck under the door (like a car hood, etc)
These adjustments are VERY sensitive, so be patient while adjusting them.
Feb 06, 2008 | Sears Craftsman LiftMaster Chamberlain...
Loosing pressure sensitivity
I was trying also, didn't work at all, and I'm going to try to close and open Adobe Photoshop CS2. But I need it to work on a few adoptables! I need it NOW!
Nov 29, 2007 | Wacom (PTZ930AC) Graphic Tablet
Bosch Axxis WFL 2060 Front Load Washer Logo
29 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Marvin
Marvin
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
