Question about Apple Iphone 3g - 16gb - White at&t Smartphone Doesnt Turn On As Is
Acer 5744 repair
I have taken all screws out but still can't get back off is there a clip or screw holding it on where its hard to see. I don't want to break anything.
  • 1,162 Answers
I did a search an came up with video on youtube. You should do a search for service manual. They inform you with all the info on screws an how to get it apart.
Posted on Mar 24, 2014
How do i remove Hard Drive from my Acer Aspire Note Book Model 5742Z Taken one screw out of carrier for HARD drive still cannot remove drive &carrier help Ken Leatham
I found this online, so hopefully it helps. It's to a page selling a second hard drive caddy for the 3623WXCi, but at the bottom is has directions on replacing the hard drive for that model as well.
http://www.batterystyle.com/acer-aspire-3623wxci-caddy-p-413622.html
Sep 06, 2011 | Acer Aspire 3623WXCi Notebook
Tip
Mazda 5 SUV/van brake light assembly replacement
This is easy and takes maybe ten minutes. You need a phillips screwdriver and a pair of pliers. Open the hatch and remove two screws at the back of the brake light assembly. Pull the light assembly hard straight backward until the little pop-clip holding the front end of the light lets go. (This is the hard part, because there aren't any great places to grip the light and the front end pop-clip is stubborn.) Then unscrew the bulbs from the broken assembly (don't touch the bulbs or the slight oil from your fingers will make them explode when they heat up - use surgical gloves if you think you can't help handling the bulbs). Gently remove the wiring harness from the NEW light assembly and discard it. Push the existing wiring harness into place in the new assembly and screw the bulbs in. Line up the assembly's pop-clip to the front end screw that it pushes onto, and push hard from the back until it pops on. Have a helper lean into the light from the side to line up the two screw holes at the back, and put the screws back in. Use a pair of pliers to unclip the rear baffle from the broken light (two clips), then pop the baffle onto the new light.
on Jun 07, 2015 | Mazda Cars & Trucks
How do I replace a tail light assembly on a 2007 toyota camry?
I tried to search all over the places on internet but to no avail. So did it on my own and the result was successful.
I replaced the passenger side rear tail light assembly of my Toyota Camry 2007. The method is same for the late models till 2011 no matter what the side is.
Its very easy to unscrew 3 nuts inside the trunk after removing the only portion of cover that covers the light but this is not it, there is a bracket under the light assembly which actually holds the edge of bumper and in order to pull it out of the bumper, bumper has to be partially taken out or loosen out.
To began the process I took the wheel out to unscrew 2 screws located right behind the wheel on the lining of bumper cover holding the mud flapper at the same time, if you have small philips screw driver of approx 2" length you might not need to remove the entire wheel. please see the image 1 as I took the pictures while fixing the light up and that too all alone.
There are 2 more screws to be taken out one holds the flap and other holds the bumper cover, all need to be taken out to bring the flap apart.
Now there is a most critical and important part for the entire job, after loosing the screws and after pulling the flap down there is a hidden bolt which will come with small sized socket (usually available in basic socket set kit)
Loose the bolt like this.
Now just hold the loose side of the bumper cover and pull it out towards yourself, that particular cover side will easily come off.
You need to loose another screw hiding in the cover right behind the bumper, open the cover with a help of the plain flat screw driver and take the bolt out.
You have just loosen the edge of bumper cover holding the bracket of light, just pull the light towards you while facing it (do not forget to unplug the power supply sockets as in next image) bend it little to the top and slide the bracket out of the bumper cover edge and you got the light assembly out in your hand.
Disconnect or unplug the power supply from the sockets, just press the plastic tip and pull the plug out from the light socket, if you just forget the order don't worry, the gray will go in gray and black one in black (please do this in the very first stage as i forgot to put this in a beginning)
Now hold the new assembly, slide it's bracket in the bumper cover edge (the way it was taken off) slide the light carefully as there is a round shape plastic part in the body needs to hold the corner edge of the light assembly
Put the 3 nuts back on the light bolts from inside the trunk.
Attach the power sockets.
Push the snapped out side edge of the bumper cover back to its framing, the click sounds will confirm its proper attachment now put all the screws back in a same way they were taken out but don't forget to putting back the mud flap.
At the final stage, just mount back moldings from inside the trunk, please refer to the images, there are 2 bolts and rest clip in typed sockets, sometimes while snapping the moldings out the white male female clips remain in their housings, just take them out with hand or screw driver and put them back carefully back to the plastic molding before tucking them back
Hope this will help you guys out !
This entire process was done without any help of trained or professional, please handle the task by keeping maximum safety precautions and at your own risk :)
Faiz.
Sep 10, 2010 | 2007 Toyota Camry
How do I remove the display screen from an Acer Aspire 6930-6235 laptop? I have taken all the visible screws out but the bezel won't pop out at the bottom (where the hinge is). There appear to be more...
Unfortunately there is no manual from acers site on this laptop so it would be hard to tell.
If your trying to remove the plastic bezel just above the keyboard, there can be screws on the narrow side on the back, screws on the bottom of the laptop combined with plastic clips along the edges of it. Also could be screws behind battery if its located at the top on the back. I use these flat plastic tools for taking apart phones and mp3 players they work great for laptops
I just watched a youtube video showcasing the laptop and just watching that I would say there are screws under the battery. With the LCD closed you will probably have to unclip the bezel from the back end of the laptop as well as with the LCD open there are probably a lot of clips a long the edge.
Screws first then along the narrow end on the back then the rest of the clips should be easy to pop.
Nov 04, 2009 | Acer Computers & Internet
Opening up a laptop to start repair
Found how to remove keyboard (edge-clips), revealing the final three screws which was holding the motherboard to the chassis
Dec 30, 2008 | Computers & Internet
Acer ferrari 4000
There could be screws behind the battery area if you haven't found so. If it doesn't come out then you gotta remove the bezel on the top of the keyboard... might need some preying be careful plastics break easily. when you get the bezel off then you might see some screws holding the keyboard down and now remove those and be careful not to destroy and of the white ribbons they are extremely hard to replace if broken.
Aug 21, 2008 | Acer Ferrari 4000 Notebook
Acer aspire 5610 keyboard replacement
1. you need to remove the power cover (if you see the power button, that what i mean).
2. after you remove that cover, you will see 2 screw that hold the keyboard. Remove both screws.
3. Remove keyboard and replace it with new keyboard.
May 07, 2008 | Acer Aspire 5610-4648 Notebook
Door seal hotpoint 9540
undue the screws oat the back that hold the lid in place make sure washer is unplugged now open the door undue the clip that holds the front part of the door seal on this maybe a spring clip hidden under the edge of the seal or there will be a plastic clip remove and pull the clamp away now looking from the inside through were you have taken the lid off look to the back of your seal there will be a screw clamp un-screw it door seal will now pull out reverse this order to put new seal on m8
Sep 22, 2007 | Washing Machines
Apple Iphone 3g - 16gb - White at&t Smartphone Doesnt Turn On As Is Logo
46 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
