Question about Toshiba 32C120U
HDMI cable does not work, and is not recognized
It says no video signal, the cable works i tried it on another tv, and still says no signal, tried HDMI 1 and HDMI 2 and still nothing
  • Toshiba Master
  • 15,634 Answers
What are you connecting to the HDMI connections on the television? You may need to turn it on if you are using a computer.
Posted on Mar 24, 2014
3dmaster
  • 183 Answers
SOURCE: No picture when on TV/Sat mode on receiver
Dear Customer,
Try another tv to this bales,
than try another cables with this your tv ,this way you got problem & find out solution on which you can spend time for ,
than try some channels to sets up your tv configuration,
or must not be imported from another country cause its not similar to your country's signal identification,
THNX
Posted on May 18, 2008
  • 159 Answers
SOURCE: Toshiba TV fails to recognize HDMI input
If the tv does all those symptoms but after some seconds the tv works and stays doing the job. THen the tv has a slow microprocessor to recognice the different resolutions or video inputs.
But if the tv cannot do anything and stay aout of signal forever. send the tv to the waranty. (no waranty? you have to use the component input instead to have digital signal reproduced
Posted on Apr 24, 2009
SOURCE: Help HDMI Splitter Doesn't Work!
The HDMI splitter is intended to take one source to two displays. You need an HDMI switch to take two sources to one display, a device you can tell which input to select.
Posted on Jul 08, 2009
SOURCE: TOSHIBA 37E200U TV gets "NO VIDEO SIGNAL" error on
I am facing similar problem showing "no video signal" following failed attempt to connect Wii. Even after trying to reset, it won't come out again.. I am totally at loss? Toshiba Customer Desk has not been connected well and appreciate any advise.
Posted on Feb 14, 2011
spr1949
  • 1182 Answers
SOURCE: 47regza has a pink screen says no video signal
Try changing the input device to something you are sure, works such as a DVD player. Look for loose contacts of jacks, sockets and cables.
Switch off TV manually, switch off power, remove plug and retry after 48 hours.
If problem persists, please refer it to a qualified service technician.
Posted on Aug 03, 2012
TV input not recognizing cable signal; shows "No Signal" when connected
Use the remote and go to every input, dvd / component 1 / component 2 / aux / hdmi etc. Try them all. If that doesn't work, try using a different connector, example, if you're using s-video or hdmi, try using RCA plugs (red,yellow,white) instead. 9 times out of 10 that;ll fix it. Hope I helped Grim
Aug 18, 2015 | Televison & Video
Signal out of range
If your trying to play youtube videos it wont work. it will only play through apples video player
Feb 04, 2014 | Televison & Video
55 inch led tv will not recognize my hdmi cable?
on you r remote there should be three hdmi settings just try each one it will likely work with one of them
Apr 16, 2012 | LG Televison & Video
Phillps led tv color problem
Dear Friend,
If you are using HDMI cable might sure that your PS3 recognized the signal as "HDMI" and you can achieved this by going to your Settings panel > Display Settings > and follow the Display input setting configuration. Also turn the RGB Full HDMI to ON.
You might want to try another HDMI port in your TV or a known working HDMI wire if the problem still persisting.
Good Luck!
Jan 05, 2012 | Sony PlayStation 2 Slimline Console
Toshiba 40XV645U - No picture on HDMI 1 when TV is turned on
I assume that you have set the input source selction as in Page 32 and HDMI 1 is solid and and not grayed out. If so check the Preferences menu and see if there is an option for power on set up.
Also look at page 51 about HDMI feature settings. I assume you turn the cable box on first before turning the TV on.
Dec 19, 2009 | Computers & Internet
HDMi ( no signal, not supported) doesn't work with Dmr-Ez47v
Any HDMI cable manufactured in the last couple of years should all be HDMI 1.1 compliant, your problem is most likely the logic board in the TV itself or the HDMI connector on the logic board has a bad connection..
Have you tried hooking-up a standard DB15 VGA cable to the AKAI TV and your laptop?
If this works your problem is in the TV and will most likely have to be repaired to receive the HDMI signal since your Panasonic DVR and your laptop are not recognized by the HDMI input on the TV.
Ren
Jun 03, 2009 | Akai LCT2785TA 27 in. LCD Television
PS3 No signal to the TV
To solve this, when the ps3 is in standby (solid red light), just hold the power button. It should beep on, then beep again in about 5 seconds. This will automatically search for the optimal audio video output. if if beeps on then turns off, just try again, it takes 1 or 2 tries sometimes. the reason this is happening is because your ps3 is set to one AV output, ex. composite(red yellow white), HDMI, and then you changed the cable to a different one. another way to fix it is plug both cables, HDMI and composite, into the tv and ps3, then go to settings and change the output to the desired one.
Jun 02, 2009 | Sony Playstation 3 (PS3) Console
HDMI ON ILO 32HD
it sounds like there is a problem with either the output on the PS3 or the input on the circuit board of the TV. I would try a reset on the PS3 first. Also make sure that there are no other video or audio cords plugged into the PS3 because this will cause the PS3 not to send the signal via the HDMI.
Mar 14, 2008 | iLO 2600 Television
Toshiba 32C120U Logo
113 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
