Question about Health & Beauty
Charging light turns off after adaptor plugged in
Charging light turns off after a few seconds
Crankstart
  • 696 Answers
SOURCE: Laptop AC Adaptor
If the light is going out whenever you plug the Ac adapter in you most likely have a short in the laptop. The most likely culprits are a failed battery or a damaged AC port. Remove the battery and AC the use a pen or pocket knife to wiggle the pin in the center of the AC port. If it is solid, it's probably good, if it wiggles it's likely broken(may need a pro for this repair).
Assuming it's ok, leave the battery out and try plugging the AC back in. If the light goes out the problem is likely on the motherboard and may need a pro. If the light on the AC pack stays on turn on the laptop, if that works the battery is the problem, you can purchase a new battery.
Try these and let me know how you make out,
Chris
Posted on May 26, 2009
dreamkam
  • 83 Answers
SOURCE: my laptop will not turn on
Check if the AC power adapter can operate the notebook when the battery is removed. Do a normal shutdown of the PC. Remove the battery from the Notebook. Connect the power adapter and press the Power button to start the notebook. If the PC does not start and operate normally, the AC adapter is defective and must be replaced. If the PC does start and operate normally, the AC adapter is working properly If the notebook does not start with ac adapter and keeps flashing the lights only then we need to know how many blinks are flashing. Please check the following LED blink codes and the link below to solve the issue with your laptop. First you need to determine how many blinks you are getting when you try to power on the laptop. Check the blinking codes below and reason behind that for HP Compaq laptops Blinking battery power LED Battery Insufficient charge on the battery Blink: 1 - Caps Lock/Num Lock - CPU CPU not functional Blink: 2 - Caps Lock/Num Lock - BIOS BIOS corruption failure Blink: 3 - Caps Lock/Num Lock - Memory Module error not functional Blink: 4 - Caps Lock/Num Lock - Graphics Graphics controller not functional Blink: 5 - Caps Lock/Num Lock - System board General system board failure Blink: 6 - Caps Lock/Num Lock - BIOS BIOS authentication failure Well Check for the below link it will provide you the steps which you need to perform to isolate the cause so that we can determine which hardware of the laptop is causing this issue. http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01443366&cc=us&lc=en&dlc=en You need to first Remove the memory module (RAM)- Try to power on the laptop ? then again reset it and try to power on. Check whether it is coming on or not. try the same procedure with Hard drive. If laptop is getting power on after removing one of the device then we can be sure that that particular device is faulty and we can change that then? Let me know if you find any difficulties doing this.. I hope this will help you to get it work. Plz vote for me..Dreamkam
Posted on Jun 01, 2010
SOURCE: bought new battery because when you plug in a/c
hi
if you have a dell there is opetion on bettery to chack the bettry charged
frist remove bettery then just try to open with A/C adaptor if your leptop is woking it mence your adpter has problem it's not charging try with other charger
Posted on Jun 26, 2010
  • 56 Answers
SOURCE: i tried to charge my
You could try another battery.But if another battery doesn't work,sorry mate I think it's dead.In future make sure you only use what you know is compatible,also NEVER try to run the PSP with the AC adaptor without the battery in.The PSP safety and support booklet states: Do not use the PSP system with the AC Adaptor when the Battery Pack is not inserted in the system.If the AC Adaptor is disconnected suddenly,it may result in damage to the system.
If it is the motherboard that's burnt out I think you can replace it but they're expensive I think,I saw one for a PSP1000 for
Posted on Oct 04, 2010
Rider On Way
  • 1679 Answers
SOURCE: I cant turn on my HP , Battery wont charge.
You will be able to find all the necessary information related to battery troubleshooting your laptop from the given link below
Battery Troubleshooting
Regards,
Shawn
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Posted on Jan 13, 2011
Why does innotab charging light blink when charging and will not charge?
the charge imdicator is suppose to blink when you plug the toy to the wall adaptor. if it doesnt blink then there's something wrong with either the adaptor, the adaptor port on the toy or the rechargeable power packs. now i said that the light is suppose to blink. but the frequency of the blinks shouldnt be fast. if that's the case clean the compartments and re-insert the batteries. if you are still having problems try the ff T/S:
1)remove the power packs, plug the toy to adaptor and turn it on. if it turns on that means your adaptor is working.
2)remove the adaptor and try using just the power packs.
3)try using 4aa batteries.
if the toy turns on with only one of the power sources stated above you better call vtech hotline.
Sep 01, 2014 | Vtech InnoTab 3S The Wi-Fi Learning App...
I tried to charge my psp with a few 9 volt batteries and i think i fried the motherboard it wont turn on with the battery or without the battery and connected to the AC adaptor. When i try to plug the AC...
Oct 04, 2010 | Sony PlayStation Portable (PSP) Console
Bought new battery because when you plug in a/c adaptor the battery charge light goes on for 20 seconds then goes off. also if you unplug the adaptor the computer dies.
hi
Jun 26, 2010 | Dell XPS M1210 Notebook
Hello , actualy i took the battry out while my hp ,dv600 on then when i turn it on again it turns on but my screen is black and the computer lights goes on and of every few seconds , what do you think is...
Removing the battery shouldn't hurt it, unless you were doing a BIOS update or something, at worst, the PC should reboot and you might get a message about Windows not shutting down properly. It sounds like the battery might be dead and is not getting charged. Have you tried it with the AC adaptor? Is the adaptor definitely plugged in correctly?
Jan 27, 2010 | HP Pavilion dv6000 Motherboard
My Gateway 1450 will not power up. For the last 2 weeks that battery light has been red (battery need recharging). i had the unit turned off with no ac power to it all weekend and not it will not power up....
The motherboard battery is just a little round battery that you can buy at almost any retailer in most pcs. The model number to the battery is usually a CR 2032. This battery does not receive any power from your power supply. Have you noticed your PC loosing time over the last few months? This is usually a good indication that the motherboard battery is dying. The lights that you refer to though should only partain to the rechargable battery of the notebook. During the past two weeks while the red light was on, was the AC adaptor plugged in to the laptop and plugged into an AC source? If your AC adaptor has been plugged in and is not charging the notebook battery then there could be one or both of the following problems: your notebook battery could be bad or your AC adaptor could be bad. Something you may or may not know is that it is not good to keep the AC adaptor plugged in all the time. This causes the notebook battery not to fully discharge after being charged. Over a long period of time, the battery will not even charge anymore. My suggestion is that if you know someone with a similar AC adaptor to yours, borrow it to see if it charges your battery. If the battery doesn't charge then you know to replace. However, I am almost certain that you problem is the battery. Sometime older laptops like the one I have has a reset button on the underside. If yours has one try removing the battery and leave it out. Then plug in the power and press and hold the reset button for 10 to 20 seconds. If no reset button is on yours then do the same process with the battery removed and power adding, but hold the power button instead.
Dec 07, 2009 | Gateway Solo 1450 Notebook
Problem with b130 batteries?
it is very possible that your a/c adaptor/charger is not working well enough to charge or keep you computer runing.
with a new battery you should put it on charge for several hour and charge it to the maximum.
do you know for a fact that the battery is new you put in it?
if the battery is used it may be trash also.
sort out the facts then look for the most obvious.
most obvious at this point it that a/c charger.
May 24, 2009 | Dell Inspiron B130 Notebook
Laptop is not turning on
take the battery out and turn it on with only the ac adaptor, then put the battery back in.
Mar 24, 2008 | Toshiba Satellite A45-S151 Notebook
Laptop not showing light, power button not turning on, AC adaptor light constantly beeping faintly
Unplug the power cable... Hold the power button down for 15-20 seconds... Plug cable back in and check for light... If this still didnt work, then unplug cable again, take battery out, wait 10 seconds.... Put battery back in, plug cable back in and this should allow you to boot...
Feb 05, 2008 | Acer Aspire 3680 Laptop
Help
sounds like you have an intermittent problem with your AC adaptor or dc input jack. Does the light on the AC adaptor light up when you plug it in? If it does then your dc input jack may be faulty. If the light on the ac adaptor does not light then replace the ac adaptor. Good Luck!
Sep 16, 2007 | Toshiba Satellite M30-S350 Notebook
Samsung yepp yp-t7jx
mine did the same thing, but after i reset it, it worked just fine.
Mar 12, 2007 | Samsung Yepp YP-T7JX MP3 Player
Health & Beauty Logo
97 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
Jeff Tilburn
Jeff Tilburn
Are you a Health and Beauty Expert? Answer questions, earn points and help others
