Question about Toshiba 55H70 55" Rear Projection Television
How do you the ballast
How do youfix the defective ballast
    Scholar:
  • 195 Answers
How do you know it is bad? i do not EVER recall a bad ballast on a Toshiba. Likely the generic lamp you used will NOT fire--Toshiba sets are VERY particular about lamps. that--or a bad color wheel.
Posted on May 08, 2014
Lamp does not stay on
You need to find out if it is because of the system control turning off the ballast lamp driver or the fact that the ballast or lamp is not defective measure the connection volts from the mother board to the ballast (NOT THE 350-400 VOLTS FROM THE MAIN SUPPLY RAIL) this will then confirm it may be an over sensitive temperature sensor.
Apr 16, 2013 | ViewSonic PJ860 Multimedia Projector
I have sound to my t.v, but no picture. bulb is good, i read it could be a ballast?
try to check first if there is a voltage input in to your ballast before replacing it. If there is a current going to your ballast and the bulb still not powering for sure the ballast is defective and you can replace it.
Aug 02, 2011 | RCA Scenium M50WH187 50" HDTV
Blue light flashes 5x times for about a minute,manual says bulb,replaced bulb,still doesnt work.
The "bulb" indication means that the lamp has not "fired". This can be due to a defective lamp or a defective ballast. Since you have replaced the lamp, I would next chack the ballast. A professional service shop should be able to help with this. It is extremely rare for a lamp to be delivered defective.
Hope this helps a bit.
Dan
Apr 25, 2011 | RCA HD50LPW175 50" HDTV
Red light bkinks, screen goes black for few seconds , picture comes back and then repeats
You have either a defective ballast or a defective lamp. The lamp is the most likely and is user replaceable. If your ballast is defective you will need to contact a service person
Nov 08, 2010 | Sony Grand WEGA KF50WE620 Television
Hi i have a kdf e50 a12u the bulb went so i relaced it and still no picture just keeps flashing green and red any ideas?
Ballast board it is what powers Lamp on.
Encompass Parts Distribution 1-800-638-3328
You need to make sure you do not have any defective Cooling Fans -If Lamp Fan is Defective Lamp will not come on either.But if Fan is running and Lamp Fails to light Ballast board
Sep 30, 2010 | Sony KDF-E50A12U 50" LCD HDTV
Toshiba TDP-P4 Defect Ballast The lamp starts for ahalf a second, just a little flash. Tried a new lamp same thing. I suspect the ballast. Used de service manual and from Power Supply it gets the 5v wich...
the 5v from the power supply is just the signal voltage. the ballast, once ignited, sends about 350vdc to strike the lamp for a few seconds then lowers to 40vdc to maintain it. unfortunately, $261 is a standard price for it.
Oct 02, 2009 | Toshiba Office Equipment & Supplies
When turning power on, nothing happens and then it blinks red five times in a row. KDS R50XBR1
The five blinks indicates a lamp driver failure. The lamp driver is commonly called a ballast. Odd thing is that these set rarely have ballast failure. But the microprocessor in your set thinks the ballast is defective and is rendering the five blink code.
Jul 09, 2009 | Sony KDS-R50XBR1 50" HDTV
My rear projection tv stopped working the lamp has not blowen but the lamp is showing its open circuit with a multimeter. Should it be open circuit? the model of the lamp is 120w BP96-00271C
yes it is high resistance could be your balast... do you hear the arc in the spark gap on the ballast?
if not you may have no power to the ballast as in an open fuse or the ballast is defective or your bulb is defective ..they may not look blown.
Oct 07, 2008 | Televison & Video
TV WILL NOT POWER UP
The ballast uses open ended high voltage. Both the start current, and the running voltage must be verified.
Normaly the ballast is replaced unless you have the test jigg which is essentialy the specified lamp simulator.
If there is a sensor fault that indicates there may be a potential cooling problem, or an unsafe fault condition (bad socket), or if the lamp is sensed as being defective, the ballast will be shut down.
Jerry G.
Apr 17, 2008 | Samsung DLP HL-P5663W 56" TV
Toshiba 55H70 55" Rear Projection Television Logo
101 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
