Question about Smoothfitness Smooth 6.17 Folding Treadmill
Belt don't move
The treadmill runs okay when I am not standing on it. As soon as I stand on the it, the treadmill is not moving, while the belt keeps on moving.
    Master:
  • 966 Answers
You may have to adjust tension notch at a time and see if it makes any difference.
Posted on Mar 24, 2014
9500 hr belt stops when stands on it and funny noise from machine , noise stops when adjust front tension bolt but belt still loose
see the video and proceed. This happen because the lack of maintenance schedule . If the problem remain after you did LUBE is time to replace the old board belt. God bless you
Apr 01, 2013 | Life Fitness Used 9500 HR Treadmill
The belt is not moving but the motor is
You didn't mention the treadmill model but most treadmills will have a diagnostic code appear if this type of thing happens. If you are not standing on the treadmill does the belt move just a little?
My guess is if you do not have an error code then the belt may be trying to move and is either obstructed or loose. If you are getting a code then there is usually a belt (like a timing belt) that goes from the motor to the drive roller and it is probably broken or has just popped off. You'll need to remove the cover to see this - CAUTION - unplug the treadmill if you are going to remove the cover!
Feb 02, 2013 | Exercise & Fitness
I currently replaced the walking belt on my C954i/C956i treadmill. When I plugged it back in and turned on the power, the treadmill has no power. What could have happened?
Dear Sir:
I can read you trouble, and follow the next steps:
ALIGNING AND ADJUSTING THE RUNNING BELT
The correct alignment of the running belt is critical to the smooth operation of the treadmill. The belt is properly aligned at the factory. However, during shipping and handling or by use on an uneven surface, the belt may move off center and require a few simple adjustments. Before aligning the running belt, check its operation by following the procedure in Checking the Alignment of the Running Belt. If you determine that the belt needs alignment, follow the instructions here. CAUTION: Special care must be taken when aligning the running belt. Turn OFF the treadmill while adjusting or working near the rear roller. Remove any loose clothing and tie back your hair. Be very careful to keep your finger or any other object clear of the belt and rollers, especially in front of the roller and behind the deck. The treadmill will not stop immediately if an object becomes caught in the belt or rollers. Realigning the belt takes a few simple adjustments. If you are unsure about this procedure, call Precor Customer Support (see Obtaining Service.) Take the following steps to align the running belt on the treadmill. To ensure your safety, make all adjustments while the treadmill is OFF. 1. Make sure the treadmill is OFF and the running belt has completely stopped. 2. Locate the right belt adjustment bolt in the rear end cap of the treadmill. (To determine left and right, stand at the rear of the treadmill and face the display.) See Diagram 24. The direction you turn the bolt depends on how the belt is tracking. Make all belt adjustments on the right rear corner bolt using the hex key provided. • If the belt is off center to the RIGHT, turn the adjusting bolt ¼ turn clockwise, which moves the running belt to the left. • If the belt tracks off center to the LEFT, turn the bolt ¼ turn counterclockwise; this moves the belt to the right. Important: Do not turn the adjusting bolt more than ¼ turn at a time. Overtightening the bolt can damage the treadmill. 3. Turn the unit ON. 4. Stand beside the treadmill and press QUICKSTART. 5. If you are prompted for a password, press INCLINE ??¼, SPEED ??¼, SPEED ??². The running belt starts automatically after the 3-second countdown appears on the display. 6. Press the SPEED ??² key until the display shows a speed of 3 mph (5 kph). 7. Walk around to the rear of the unit and observe the running belt for a few minutes. The belt should run centered along the running bed. If the belt drifts off center, you will need to make adjustments. CAUTION: If you hear any chafing or the running belt appears to be getting damaged, stop the running belt immediately by pressing the red STOP button. Contact Precor Customer Support. 8. If the belt needs additional alignment, repeat steps 1 through 7 until the belt is properly aligned. 9. After aligning the belt, press the STOP button and RESET. Turn OFF the treadmill. Tighten any loose fasteners or other components on the equipment. If you hear unusual noises or you feel that the treadmill is in need of repair or service, contact Precor Customer Support. Refer to Obtaining Service.
Finally, check if the power cord is loose, connect it again. a) See if the breaker of Home is tripped? b) See if the breaker of the Treadmill is tripped. If do the Belt is very Tighted! loose a little. Try again.
Thank you in advance, if you need assistance, you can contact me, Blessing. sincerely.
E. CUADRA Managua, Nicaragua. C.A.
Sep 26, 2011 | Precor C954i Commercial Treadmill
Belt won't move
does is just not move when you're standing on it, or not even move when you're not standing on it. It may be a simple belt adjustment or if the motor is running but there's no track movement you may be looking at a loose/broken drive belt. Take the cover off, start it up and look at the motor/drive pulley assembly. If the motor turns and the front roller doesn't, tension the drive motor by moving it back. If the front roller turns but the track doesnt, do a track adjustment as per your users manual.
May 26, 2010 | Proform CrossTrainer Treadmill
I started up my treadmill after a year sabbatical :) to find that it stops abruptly when I increase the speed above 4 and then when I restarted it as soon as I stood on the belt the motor lagged & then...
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the allen wrench, turn both rear roller adjustment bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift the edges of the walking belt 3 to 4 inches off the walking platform. Be careful to keep the walking belt centered. Plug in the power cord, insert the key and run the treadmill for a few minutes. Repeat until the walking belt is properly tightened.
Apr 28, 2010 | HEALTHRIDER S600 Treadmill Motor Control...
The belt is slipping when running on ithas been standing in cold conservatory
At the end of of the running belts2_bing.gif in the end caps will adjusting bolts you will need a allen wrench to adjust the tension. Start your treadmill2_bing.gif and turn clockwise a 1/4 turn each time see i f you can stop the belt. You need to be aware that the drive belt can also cause this problem so I suggest that you remove the motor shroud and when you are adjusting whether the front roller is moving and the running belt has stopped or the roller has stopped and motor is rotating ( adjust Drive Belt)
Mar 01, 2010 | Horizon Exercise & Fitness
The motor belt slips on my treadmill and does not turn walking belt when i stand on it. I have a pro form 535x and it had worked fine until now. The walking belt goes fine without pressure but stops when i...
Remove the cover, you will see the motor and an adjusting pivot bracket. Loosen the nut/screw on this bracket, use a HD screwdriver or pry bar and move to take the slack out of the belt. The resistance/tension in belt should be 3/4"-1"
Aug 12, 2009 | Exercise & Fitness
Candence 825, motor not driving belt, smells of burning
Hi Jill, have you found a solution yet as I seem to be getting a sililar error. Do you get a E02 message and a beep. Thanks Nicky
May 18, 2009 | Cadence Weslo 825 Treadmill Walking Belt
Smoothfitness Smooth 6.17 Folding Treadmill Logo
102 people viewed this question
Top Smoothfitness Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you a Smoothfitness Exercise and Fitnes Expert? Answer questions, earn points and help others
