Question about Car Audio & Video
Wiring colours for radio connection on toyota hilux 1996
Putting in a new radio the colours don,t match the colours on old radio
    Problem Solver:
  • 20 Answers
5 Suggested Answers
  • 242 Answers
SOURCE: wiring radio to toyota hilux
your local car spares will supply a convertion wireing to just plug and play
Posted on Dec 28, 2009
emissionwiz
  • 79847 Answers
SOURCE: need a wireing diagramfor toyota camry 95 for car
1995 Toyota Camry Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Blue/Yellow
Radio Switched 12V+ Wire: Gray
Radio Ground Wire: Brown
Radio Illumination Wire: Green
Radio Dimmer Wire: N/A
Radio Antenna Trigger Wire: Black/Red
Radio Amp Trigger Wire: None
Front Speakers Size: 5 1/4′
Front Speakers Location: Doors
Left Front Speaker Wire (+): Pink
Left Front Speaker Wire (-): Purple
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Blue
Rear Speakers Size: 6′ x 9′
Rear Speakers Location: Rear Deck
Left Rear Speaker Wire (+): Black
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Red
Right Rear Speaker Wire (-): White
Posted on May 05, 2010
SOURCE: Im trying to install a new stero in my car its a
Hi - unfortunatly you can forget colour coding as a means of connecting them as this rarely works. Autoleads sell adaptors to bridge for myour cars wiring look directly to the ISO connector from the Sont. Faining this a trace back or a Haynes manual will let you know what each wireof your loom is for and you sony manual shuld explain the harness
Good luck
Posted on Jul 12, 2010
nsanedrummer
  • 50 Answers
SOURCE: i have a 97 toyota tocoma ext.cab. and am putting
Hello... I will try and help you with your problem. I am assuming that you have cut the factory harness off in the truck? If you have and you can reconnect it, I would recommend doing this and then you can purchase a wire harness adapter and then just match the colors. The benefit in using an adapter harness is the ease of the installation, and the more you change the radio in the truck, the shorter the wires will get. If you do not have the factory harness, or cannot reconnect the old one, here is the hardwire code:
Wire purpose: Truck color: Alpine harness:
Constant 12V+ Blue/Yellow Yellow Switched 12V+ Gray Red Ground Brown Black Illumination Green N/C Dimmer n/a N/C Antenna Right Front Front Speakers 6 1/2" Doors Left Front (+) Pink White Left Front (-) Purple White/Black Right Front (+) Light Green Gray Right Front (-) Blue Gray/Black Rear Speakers 6 1/2" Rear Corners Left Rear (+) Black Green Left Rear (-) Yellow Green/Black Right Rear (+) Red Purple Right Rear (-) White Purple/Black
Hope this helps!
20 year car audio/video installer
Bay manager
Posted on Apr 06, 2011
Putting in a new cd radio on Toyota echo 2003
need to match the wires in the car with the wiring for the radio.. find and mark what they are and connect them in this order...each speaker(normally 4) radio memory(stays on all the time) battery positive/with key on.. and ground wire usually black or brown..and the radio antenna as well.. these wires wont be identical colors but the funtion of these will be..match and connect.. and check before putting in the dash..for proper operation.. good luck and be careful..if the radio did not come with its own conector and wire pigtail.. get one from a stereo dealer that does custom installs..
Dec 29, 2012 | Cars & Trucks
I was needing an Owners Manual for a 1996 Toyota Hilux Surf - In English
Hi there: Try this links...
- Toyota 4Runner - Hilux Surf Workshop and Service Manual (90 - 95)
- 1998 - TOYOTA - 4RUNNER ID: greatfalls / Pass: publiclibrary
Select Auto Repair Center, year, make, model and engine series.
- 4-Runner/Hilux Workshop Manual - 1990-1995 (33 Mb)
- 4-Runner/Hilux Workshop Manual - 1996-2002 (28 Mb)
- Toyota Engine 1KZ-TE 3 Litre Turbo Diesel ( Hilux 4WD ) Service Manual
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Jun 18, 2012 | 1996 Toyota Hilux
I wont instoll anather audio but the whayir in my toyota and the new wair it is not mach
Go to a car audio shop and ask for an install kit. It connects your old wiring to new radio with plug in connecters
Apr 11, 2010 | 1996 Toyota Corolla
Do you know the radio wiring colors for a 1996 jeep
you need a volt meter and 9v battery. then earth black contact from meter & then
  1. with ign off probe wire to find a live , thats the memory feed goes to yellow on radio
  2. with ign on probe wires that the constent live goes to red on radio
  3. when lights on probe wires thats the illumination feed (if fitted to car, but not used on many new radios
  4. then get 9v battery and with remaining wires pair and connect to battery, when speaker buzz's mark pair as they are ( ie front right rear left etc ) the speaker wires from the new radio are paired by colour ( one with black stripe with is the negative of the pair)
  5. there should be a ground/earth which if you cant find just hook one to the body/chassis
Jan 01, 2010 | Car Audio & Video
1979 Toyota Hilux alternator wiring
always, counterclockwise starting with blue, then yellow, then red
Feb 21, 2009 | 1994 Toyota Pickup
Request for the wiring diagram for a 1989 UK spec Toyota Corolla Hatchback
Sure. Glad to provide assistance.
89 Corolla radio wiring colours:
Power- Solid GREY -
from the 7.5 amp RADIO fuse
Backup power - BLUE w/YELLOW tracer
from the 10 amp DOME fuse
RF speaker - LIGHT GREEN and BLUE
LF speaker - PINK and VIOLET
RR speaker - RED and WHITE
LR speaker - BLACK and YELLOW
Ground/Earth - BROWN
The graciousness of a FixYa rating would be greatly appreciated.
Jan 19, 2009 | 1989 Toyota Corolla 2 Door
Wiring colours and what they mean
Are you trying to use that radio in a different vehicle, or are you trying to find out what wires in your vehicle you need to connect to a new radio? Your best bet either way is to go to your local library and find the service manual to that make, model, and year of vehicle, and look up either the wiring diagram, or connector views of the radio. You can also buy conversion harnesses to plug a new radio right into your vehicle, so you don't have to splice wires. You don't want to just start hooking up wires because putting power or ground in the wrong spot can wreak havoc on the vehicle and the radio. Hope this helps.
Nov 25, 2007 | Car Audio & Video
Car Audio & Video Logo
79 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
