Question about Neon GREEN PC POWER SUPPLY KIT Power Supply
My neon sign gets half way through light and stops, but it will follow the touch of the glass
The first section will light but stop half way through the word, however it will light sections when you touch it. when hook up same power line to another section, it will light that section
    Sergeant:
    Champion:
  • 282 Answers
Sounds like that neon sign might be lacking the proper amount of the gas inside of it. By touching a segment and then it will light you are increasing the capacity around that segment. An old trick is to place a piece of aluminum foil in back of the segment that does not light and see if that works. Other then that you may want to try a larger transformer but you shouldn't leave the light on for prolonged times because the electrodes at each end will get very hot possibly causing the glass to melt. Good luck.
Posted on Mar 30, 2014
Which is advanced or better : Neon or LED illumination?
LED lighting is more advanced. Neon has a long history, having been used for nearly a century.Though Neon has the brightest lighting capacity, it requires maintenance. Neon emits more energy than LED lights. LED works in any climate. This makes LED a very reliable optionfor illuminated channel letters. They require much less maintenance and are more energy efficient than neon. Neon signs are easily broken. Being made of glass, they leak. LED does not have this problem . Once you get a neon sign, there's no changing it. Custom LED signs can be updated as often as you like, with whatever messages you like. Custom LED Signs Toronto Single Double Sided New Style Signs
Jul 31, 2015 | Neon Sign Inc Old Style New Orleans...
Fuel pump fuse blows
It's a short in the fuel pump circuit wiring. Were those damaged wires where the pump fuse is located? If so, that is where to start looking.
The circuit is not that difficult to follow. The pump wire runs from the fuse to the fuel pump relay (probably in the same location as the fuse). And from the relay the pump wire goes direct to the pump in the gas tank. Somewhere in that path, your wire is shorting out-touching metal or another wire with insulation stripped from it.
Techs use a multi-meter to help look for shorts. Checking a section of wire with an ohmmeter will tell you if the section is good or has a break. Good luck. Take another look at those damaged wires.
Mar 29, 2017 | 1997 Plymouth Neon
I have an 2001 dodge neon, When i got it, it drove so good and now every time i try and start my car it has a hard time running and when i push on the gas pedal it sounds like my car is getting flooded or...
May have a few issues here. The first is a possible vacuum leak. Vacuum leaks are so broad though. You'll need to check the entire intake for rotten hoses. The hard start could be a bad fuel pressure regulator of fuel pump. Along with that. The Fuel Pump could be related to more than one of those problems unfortunately. Another thing could be the Throttle position sensor not getting the propper voltage to allow for smooth running and acceration. Does the car have a check engine light on?
Jun 13, 2011 | 2001 Dodge Neon
My 1993 cad sts keep cutting off when i ride for while then when i stop at light or stop sign for min and when i press gas to go forward the car turn off. then i start car back up and run again until i...
If you don't have any engine lights on, the first thing to replace would be the fuel filter. It is located under your car, probably about half way down. Just follow the gas line, and you'll find it.
Aug 30, 2010 | 1993 Cadillac Seville
My phone fell and after that there is no sound..no ring for call or cant here music aven after using head phone...but can talk.
The speaker or the section concerned had received the fault int he fall. You will need to open the phone to look carefully with a magnifying glass for a crack in the section near to the speaker use a good soldering iron to do a touch up to cover any crack in the board. keep you headphones on and carefully touch with the multimeter leads to follow up the cirrcuit lines to the speaker, stop at the spot of connection and redo the solder job. Do it carefully or take help, it is not a failure but a defect that must go into a tampering condition. so decide and continue. Good day.
Aug 16, 2010 | Cell Phones
Electric windows are fine the roof gets half way
If the top is half way down that means that the trunk is open and should be touching the trunk switch to continue the process. The switch must be bad and it is inside the rear right fender close the the stop light
Jul 25, 2010 | 1999 Mercedes-Benz SLK
Engine problem!
these are famous for transmission kick down cable linkage seize up I own two when it first happened to my wife she thought transmission was gone stuck in hi gear and kicked in second like a bronco! the cable is hooked to the throttle cable and to the trans mission these work in synchronization if you pull it off clean it up with steel wool grease and reassemble your good to go infarct with out the car started go push the gas pedal i bet it stops half way like a rock!!!! most will go to the floor!!!check it out I think you will find my description!good luck hope this helps you out merry christmas
Jul 09, 2008 | 2001 Dodge Neon
Neon GREEN PC POWER SUPPLY KIT Power Supply Logo
50 people viewed this question
Top Neon Computers & Internet Experts
David Payne
David Payne
Are you a Neon Computer and Internet Expert? Answer questions, earn points and help others
