Question about Cameras
Have install a 32gig sd card, when recording only goes for 23 minutes then shuts off, how do i fix?
Was expecting it to run until battery or sd card ran out
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Cameras Master
  • 102,366 Answers
What make and model camera?
Some makers limit their primarily still cameras to record only about 20 minutes at a time so they get taxed at a lower rate.
Posted on Mar 24, 2014
Testimonial: "To whom it may concern, The description of my camera is a Mi Snapz Action Camera Model Number MSOVS001. The reason I would like to be able to record longer is because I go bike riding. My rides last much longer than twenty minutes. I hope there is a way this can be amended. Un update or patch would be extremely helpful. Hope this is the information you require. Thank you for your prompt response. bkfoulds21944"
2 Suggested Answers
  • 32 Answers
SOURCE: DSC-W120 Sony. Movie record time frame
I'm afraid that Sony did not think that this was an important feature. The camera is inherently limited to ~10 minutes. There's nothing you can do to make this happen. See this page from Sony (it's a google cached version because the actual Sony page was down when I checked). Scroll down to where it says "MPEG Movie VX Fine Mode"
Posted on Jan 18, 2009
Phone number for support
hi, here you are (just google !)
http://fr.gopro.com/support/telephone-numbers
Nov 17, 2014 | GoPro HD HERO3 Black Edition Camera - Surf...
When I try to shoot a video, it automatically cuts off after 23 seconds
When a green light on the back is flashing, it is not the battery light, it is the memory access light. When the buffer is full, the camera will stop the recording, and save the content of the buffer to the memory card. During the writing, the green light is burning, or flashing. If you want to make longer shots, you should buy a faster SD card.for Video, you should have at least a C10 card, but better a U1 or more.
Feb 09, 2014 | Canon EOS 600D Rebel T3i Digital Camera
SD Card Write Speed Too Slow
Hey Jack! Certainly you've found a solution by now but maybe some poor soul is seeking the solution like I was.I had my Pockettrax CX saying "Memory Full" although I'd deleted everything. What helped finally: I formatted the SD. Now I've got all the memory back. Don't know if that would help the recording speed. but maybe. IMPORTANT: SAVE ANY FILES on your LAPTOP before formatting the SD.Here's how to format the SD:Go to Menu.Click on "Common Menu"Scroll down until you get to "Format"Press "Yes""Formatting SD" comes up and, Voila,You've got more space.
Jan 26, 2012 | Yamaha POCKETRAK CX Voice Recorder
Lens error, restart camera camera shuts off
Try one of these two fixes, if they dont work for you follow the link below for further troubleshooting.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: If the camera's batteries ran down completely while the its lens was still open, the camera may show a lens error or not start properly when new batteries are installed. Remove the memory card and keep it removed, then install the new batteries. When you turn the camera on with the card removed it may come back to life, as this triggers a reset in some cameras. Error E30 (for older Canon's) means that you don't have a memory card installed, so turn it off, slip in the SD card and turn it on one last time
Aug 13, 2010 | Canon Cameras
Lost Instructions for Little Tikes My Real Digital Video Camera
I also recieved a prompt reply, with attachment - here's paste of the text only:
INTRODUCTION
CONTENTS
Item no.: 608728
Ages 3+
ADULT BATTERY INSTALLATION REQUIRED
Get ready to make your own movies with the Little Tikes™ My Real Digital Video Camera! This
durable and fun camera is easy to use and really records video and takes pictures, even up to a
depth of three feet under water!
Illustrations may vary from actual contents.
IMPORTANT: An adult must remove and discard the plastic label from the LCD Display before use.
• Little Tikes™ My Real Digital Video Camera
a. Microphone
b. LED Light
c. Lens
d. Power Button/Mode Selector
e. Mode Display
f. Edit Button/Edit Mode
g. Trash Button/Delete Mode
h. Volume Selector
i. Zoom Button
j. Record/Confirm Button
k. Speaker
l. Left Button
m. Right Button
n. LCD Display
o. USB Port
p. TV Out Port
q. SD Card Slot
r. TV Out Cable
s. USB Cable
t. Adjustable Neck Strap
u. Carrying Case
WARNING
Constant, competent adult supervision
is required at ALL TIMES when small
children are near or in water.
m
g
t k
a b
c
j
d f i
hl
e
p q o
(inside the cover)
n
s
r
u
BEFORE YOU BEGIN
Battery Installation
An adult must install batteries. Here’s how:
1. Using a Phillips screwdriver (not included) remove the screws and Watertight Cover from the
bottom of the camera.
2. Remove the screw and Battery Compartment Cover .
3. Install two (2) AA alkaline batteries (not included) making sure the (+) and (-) ends face the
proper direction as indicated inside the battery compartment.
4. Replace the Battery Compartment Cover and tighten the screw.
5. Replace the Watertight Cover and tighten the screws firmly to ensure a good seal.
Optional SD Card
Your Camera will hold approximately 10 minutes of video or 250-1000 still photos. Since portions
of the free memory space indicated in the Menu Mode are used to store the photo program, the
available space for storing photos etc., may be reduced. These numbers may also vary depending
upon the camera mode settings and the images being captured. To enlarge the memory, an
SD card (not included) may be purchased from your local camera store. To install the card an
adult must:
1. Make certain the camera is turned OFF.
2. Using a Phillips screwdriver (not included) remove the screws and Watertight Cover from the
bottom of the Camera.
3. Slide the SD card (not included) into the slot until it clicks. (DO NOT force the SD card. If you
feel resistance, remove the card, make sure it is facing the correct direction, and try installing
again).
NOTE: SD card label must face toward the Camera Viewfinder and the edge of the card with the
copper contacts must be inserted first.
4. Replace the Watertight Cover and tighten the screws firmly to ensure a good seal to keep
water from entering the card slot.
IMPORTANT NOTES:
• If the Watertight Cover is not completely sealed, water may enter the compartment causing
irreparable damage to the camera.
• USE CAMERA IN FRESH WATER ONLY. DO NOT USE IN SALT WATER.
• Using the Camera at a depth of more than 3 feet is not recommended.
TIP: Keep an eye on your battery level by checking the Battery Gauge in the top-right corner of
your screen. If the Gauge is red, new alkaline batteries need to be installed.
1.5V AA/LR06
1.5V AA/LR06
unscrew
TV Out Port
USB Port
SD Card Slot
unscrew
unscrew
1.5V AA/LR06
1.5V AA/LR06
Battery
Compartment
Cover
Watertight
Cover
IMPORTANT: To save your photos and videos directly to an SD card, you must go to the Storage
Section of the Menu Mode (see Page 5) and change the setting from internal memory to external
memory.
NOTE: Never insert anything other than an SD card into the card slot as doing so may damage the
camera and the SD card. To remove the card, press in on it and it will pop out.
IMPORTANT: Should water or any foreign object get into the Battery Compartment or the Card
Slot, turn the camera off immediately, remove the card and/or batteries, and allow the camera to
dry out completely before attempting to use again.
QUICK START
ATTACHING THE NECK STRAP
An adult must attach the Neck Strap. Here’s how:
• Place the clip on the end of the Neck Strap into the
opening in the connector which is attached to the camera
and press firmly until it clicks into place. (Fig. A)
• Repeat the instructions above to attach the remaining
end of the strap. (To detach the Neck Strap squeeze the
clip edges and pull apart.)
• Adjust the length of the Strap by using the plastic buckle
located along the strap.
NOTE: To attach or detach camera portion of connector,
see Fig. B.
CAUTION - DETACH NECK STRAP FROM CAMERA
BEFORE ENTERING WATER.
CAMERA MODES
VIDEO MODE
In this mode the Viewfinder will show what the camera sees in real time.
• Set up your shot in the Viewfinder then press and release Record to take a video.
NOTE: A red “RC” icon will appear in the top-left corner of the screen, and the elapsed time will
appear in the lower right corner.
• To stop recording and store what you have recorded, press the Record button again. The screen
will switch to the beginning of the film you just recorded with a big red Play arrow in the middle.
• Press the Record Button and the video will play back.
• Press the Left Button (or wait 5 seconds) and the camera will go back to the live image.
TIP: You can zoom the camera in and out by pressing the Zoom buttons! The Zoom Indicator on
the right side of the screen will tell you how far you are zoomed in or out!
NOTE: There is no zoom function in 640 X 480 video mode.
Video Mode
Still Picture Mode
Playback Mode
Fig. A Fig. B
ADDING SOUND TO YOUR VIDEO
• Before recording, press the Edit Button. You will see Sound and Image icons. (Fig. 5)
• Use the Left or Right Buttons to select Sound then press Record to confirm.
• Press the Left or Right Button again to hear the available sounds. (Fig.6) Stop at the one you
like, then press Record to add it to your video. The camera will then return to the live image.
Press Record to record your video with the sound included. Press Record again to stop
recording. (Press edit to exit edit mode.)
NOTE: Turn the Volume up high so the microphone can hear and record the sound!
ADDING IMAGES TO YOUR VIDEO
• Use the Left or Right Buttons to select your choice then press Record to confirm.
• Press the Left or Right Buttons to see the available images. (Fig.7) Stop at the one you like,
then press Record to add it to your video. The camera will then return to the live image with
your selected graphic. Press record to record your video with the image! Press Record again to
stop recording. (Press edit to exit edit mode.)
IMPORTANT - images on videos will only appear when viewed on camera viewfinder or on
TV screen.
Fig. 5 Fig. 7
L R
Fig. 6
L R
Construction
TURNING THE CAMERA ON
Once an adult has installed the batteries:
• Press and hold the Power button for 2 seconds. The Little Tikes™ logo will appear on the screen.
• Once the logo disappears the camera will automatically be set to Video Mode.
NOTE: To change modes, press and release the Power button. To turn the camera off, hold down
IMPORTANT: Before making videos or taking pictures, see Page 4 (MENU MODE) to set picture
quality. Also, camera must be at least 2 feet away from subject for best focus.
1 2 3
Jan 03, 2009 | Little Tikes My Real All-Ter Digital Video...
I have the SD-1. It stops recording on my 8gb after only 43 min
Try formatting the card while its in the camcorder, this might sort the problem for you, also look in the camera's menu to see if its restricted to a certain amount of used memory at once, basically return the camera to factory settings.
I find a lot of camera's don't like certain SD cards anyway even if the camera says it supports them, Sandisc are making just about the best SD cards at the moment
kind regards
Dec 11, 2008 | Panasonic HDC-DX1 DVD Camcorder
Edirol R-09 Recorder Controls Frozen
This is a PARTIAL solution...
I've found that if I partially remove the SD-Card, then push the power button, it then starts and continues (without freezing) to show the meters and shows "no-card", then I push the SD-Card fully and it then shows "Loading"...
From there, it can be operated. But if I try to power-up with the SD-Card installed, it freezes and ceases to obey any buttons; which requires to remove the batteries to turn it off.
Please be aware that removing OR installing the SD-Card with power-on is NOT recommended, BUT is THE ONLY way my R-09HR now can be operated. I'm contacting the factory to solve this, but in the mean time, I had to record a live concert that I had promised to get recorded, so I tryed everithing and discovered the reinstallation of the SD-Card as the only thing that allowed me to get that concert.
The SD-Card that I bought for my R09HR is a Kingston 16GB. good luck, give it a try.
Sincerely, amclaussen at amarquez@imp.mx
Sep 09, 2008 | Edirol R-09 Digital Voice Recorder
Connecting / Mac / Tiger / Midi
I have just downloaded and installed the version 2.20 of the software for the H4 from the Zoom site. It solved my problem and the H4-SD card now shows up in the Finder as expected.
Zoom site: http://www.zoom.co.jp/english/download/software/h4.php
Matthieu (MacOS 10.5.5 on a Mac Pro)
Note that I formatted a spare SD card to do this update in order not to lose any existing sound files.
Jun 10, 2008 | Zoom H4 Handy Recorder
TomTom Go 300
boot up failure / switching off part way through the boot up is usually caused by corrupted data or files on your SD card.
When booting up with faulty data the TomTom has 3 options
  1. Continue to boot up and run the errored software
  2. Boot up until a file cannot be correctly loaded then shut down
  3. Try to boot up but if not possible show a RED X on the screen
The other cause for shutting down is a partly charged battery but since you are running off a charger lead this cannot be the case .
So , with the above in mind , its most likely that you have corrupted SD card . The only ways to recover from this is to format and re-install from a backup of the card. OR , it might be possible to overwrite some files or folders from a similar "friends" card in the hope that you overwrite the correct / corrupted file. This is a longshot in the dark but is a possible cure.
Good luck
Mar 08, 2008 | Tomtom GO 300 GPS Receiver
Mpeg recording to SD card
This may have something to do with the fact that the camera powers down before the battery is exhausted as the maximum run time is 140 mins which is roughly the time you say it stays on for.
Oct 05, 2007 | Panasonic PV-DV953 Mini DV Digital...
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
