Question about Midland 75-822 40-Channels Handheld CB Radio
75-822 can't remove battery pack push button
Battery pack stuck won't slide off
  • 1,162 Answers
Does it have screws? If so try to remove them an take pack apart. You can always put it back together.
Posted on Mar 30, 2014
How to chnage batteries
The four AAA alkaline batteries are securely held in a battery pack attached to the tailpiece, which incorporates the T7's push button "Quick Cycle" selector switch. Unscrew the tailpiece, remove battery cartridge and refill with 4 "AAA" batteries. Slide the cartridge back in the torch and screw the tailpiece back on.
Kevin
Dec 18, 2014 | LED Lenser T7 Flashlight
Can't remove battery pack from radio
LOL funny thing i had the same trouble. When you press the spring button you dont down or away it slide on a tack of sort. Slide to you or away either way you will see it slides off not pull off. Hope this helps
Jan 10, 2013 | Midland 75-822 40-Channels Handheld CB...
Battery release latch won't open
If you push the battery in and try to release? Try a little silicon spray, mind not to over spray.If you hold open the release switch and manually pry out the battery with your finger nails?
Nov 12, 2012 | HP Computers & Internet
Nikon f601 won't rewind
needs repairing at a qualified shop
Sep 06, 2012 | Nikon F601 35mm SLR Camera
Dell Inspiron 1521 battery not charging
Laptop batteries power a laptop when it is not connected to an electrical outlet. If the laptop battery fails to charge when the laptop is plugged into an electrical outlet, the battery is likely dead and needs to be replaced. Unfortunately there is no way to fix a dead battery. However, while a dead battery is the likely cause, it is not the only cause. The AC adapter may be broken, in which case the battery won't charge, or the battery contacts may be dirty and need cleaning. Prior to replacing the battery, perform simple tasks to ensure a dead battery is the cause of the problems.
1.Power down the laptop. Gently pull the AC adapter from the side of the laptop for removal.
2.Place the laptop in front of you, bottom side up. Locate the battery release mechanism. This can be a button that slides or needs to be pushed to unlock or release the laptop battery from the housing unit. Press or slide the mechanism. Slide or lift the battery from the battery bay for removal.
3.Insert the AC adapter into the side of the laptop. Power on the laptop. If the laptop does not power on, ensure the AC adapter is securely plugged into a working electrical outlet. If the electrical outlet is working and the laptop won't power on, the AC adapter is not properly working and needs to be replaced. Remove the AC adapter.
4.Dip a cotton swab in a small amount of rubbing alcohol. The cotton swab should be damp, not dripping wet. Lightly rub the dampened cotton swab onto the battery contacts and battery bay contacts to remove dust, buildup and grime. Allow the contacts to air dry.
5.Align the battery over the battery bay. Either press or slide into place. A clicking or snapping noise produced from the locking mechanism will confirm the laptop battery is securely locked into place.
6.Install the AC adapter. Allow the AC adapter to fully charge the battery for 8 hours.
7.Remove the AC adapter. Power on the laptop. If the laptop does not power on, the battery needs to be replaced.
Sep 01, 2011 | Dell Inspiron 1521 Laptop
How could i change its batteries?
  • Your radio, Midland LXT110, utilizes a NiMH rechargeable battery pack or 3AAA batteries. I have a similar set and when the battery pack runs out I just use regular AAA rechargeable batteries. They are more economical. To change the batteries in general follow these steps.
  1. Remove the back clip.
  2. Now remove the battery cover by pushing down from the top center of the battery cover and slide it off.
  3. Replace batteries observing polarity.
  4. Replace the battery cover.
  5. Replace battery clip.
Regards, Tony
May 17, 2011 | Midland LXT110 Two Way Radio
Cannot remove battery from laptop
You can always refer to manual for such kind of thing.It will bw given with diagram.
If you don't have the manual, download it from the link below
http://www2.panasonic.com/webapp/wcs/stores/servlet/TCCHomePage?langId=-1&storeId=15001
You need to register to their site inorder to downalod the manual.
Jan 03, 2010 | Panasonic Toughbook CF-51 Notebook
Juke frozen, can't remove battery
I had the same problem. I would push the button and nothing would pop up. What I ended up doing was pushing the button, while wedging a pin in between the silver part and the colored back of the phone.
Sep 08, 2008 | Samsung SCH-U470 Juke Cellular Phone
Forgot bios password
1. Shut down the computer. If you are unsure whether the
computer is off or in Hibernation, turn the computer on,
and then shut it down through the operating system.
2. Disconnect all external devices connected to the computer.
3. Disconnect the power cord.
4. Remove the battery pack by following these steps:
a. Turn the computer upside down with the front panel
toward you.
b. Slide and hold the battery release latch 1 to the left. (The
front edge of the battery pack disengages from the
computer.)
c. Lift the front edge of the battery pack 2 and swing it
back.
d. Remove the battery pack.
5. Remove the RTC battery from the socket on the system
board.
6. Wait approximately 5 minutes.
7. Replace the RTC battery and reassemble the computer.
8. Connect AC power to the computer. Do not reinsert any
battery packs at this time.
9. Turn on the computer.
All passwords and all CMOS settings have been cleared.
May 07, 2008 | HP Compaq Presario V2000 Notebook
Midland 75-822 40-Channels Handheld CB Radio Logo
123 people viewed this question
Top Midland Radio Communications Experts
AnyMHz.com
AnyMHz.com
eradiostore
eradiostore
Are you a Midland Radio Communication Expert? Answer questions, earn points and help others
