Question about Samsung NE595R0ABBB 5.9 cu. ft. Large Capacity Electric Range - Black
Samsung Range control panel won't turn on.
Just installed a new Samsung Range and the control panel will not turn on. The surface plates function and get hot. Cannot turn the oven on because the control panel is completely blank. Brand new. Installed exactly according to manual. Checked breaker. Can I reset to get it going?
    Sergeant:
  • 380 Answers
Check the voltage at the ac cord. Make sure you have 240 there. Sounds like your missing one leg there
Posted on Mar 24, 2014
2 Suggested Answers
craig6773
  • 116 Answers
SOURCE: clicking sound from control panel
This clicking sound is a result of the heating element cycling on and off as it tries to maintain a temperature. It heats up rapidly to a maximum, safe temperature and once the maximum is met it shuts off for a couple of seconds so it does not overheat the cooktop and/or your temperature setting. As far as the clicking, just how loud is it? If it's minimal and only fantly noticable then it's normal. If it is quite loud and annoying that may be a whole other issue. Does this information help? Let me know.
Before I forget, there should be a section in your Owner's Manual explaining that the clicking sound is part of it's normal activity.
Posted on Nov 21, 2010
GE Profile range - Digital display went blank when the surface burner was turned on
Hi
Mercedes NEC device can learn an extra key to ALL MB MOTOROLLA AND HAVANA AMAZONAS PALERMO... EIS with black or chrome key Version57
Device can repair any CORRUPTED key data VIA INFRA RED
Device can repair the old 204 steering lock or program a new steering even if the old ESL in not exist
Device works by infra red Much and much functions will be valid to all our customers
Price 7000 Euro you can visit our website to watch the you tube video
(Limited quantity only)
http://youtu.be/0Ce4z8JY-go
•Mercedes W204 - ELV
•Mercedes C W204
•Mercedes CL W216
•Mercedes A W168
•Mercedes G W463
•Mercedes GL W254
•Mercedes GLK X 204 - ELV
•Mercedes GLK X 204
•Mercedes ML W164
•Mercedes W 207 - ELV
•Mercedes W 212 - ELV
•Mercedes W207
•Mercedes W212
•Mercedes G W463 (MOPF)
•Mercedes W221
•Mercedes SL R230
•Mercedes SLK R171
•Mercedes Sprinter
•Mercedes Vaneo W414
•Mercedes Viano W639
•Mercedes R W251
•Mercedes Vito W639
Dec 28, 2013 | GE Profile Spectra JGBP90 Gas Kitchen...
Tip
How to test surface burner on Electric range
In order to test the surface burner on your electric range, the following steps should be taken:
  1. Before repairs or testing can begin you must disconnect the electricity at the fuse panel, at the circuit breaker panel, or by pulling the plug. Make sure the power is off before proceeding. A jolt from 220 volts can be fatal, use caution!
  2. Remove the surface burner from the stove top. On most electric ranges this can be done by pulling the burner up and out of its plug-in receptacle. Other models have the burner directly wired to the cook top. To remove this type of burner, undo the screw that secures the burner to the cook top, remove the clips that secure the insulators to the burner terminals, and carefully unscrew the wires from the terminals. Take care not to bend these terminals.
  3. Visually inspect the burner - often there will be small holes or bubbles on the surface of a defective element.
  4. Now that you have removed the burner, you can test it using your VOM. Using the ohmmeter function, set the range scale to R x 1 and touch the test leads to the two burner terminals. The VOM should show continuity. Typical burner readings should be somewhere between 19 and 115 ohms, depending on the range manufacturer. If there is no continuity, the burner is defective. To test for a grounded (or shorted) burner, place one test lead on the outside surface of the burner and the other test lead on each burner terminal in turn. If there is continuity at either terminal, the burner is defective.
  5. If the burner is defective, replace with a new one by reversing the removal procedure (step 2 above). If replacing a wired-in burner, make sure that you install the wires on the correct terminals, according to the wiring diagram.
REMEMBER YOU ARE WORKING WITH 220 VOLTS - USE EXTREME CAUTION!!!
on Jan 04, 2011 | Kitchen Ranges
Feature not available
I had the same problem with a new kitchenaid range which they have agreed to replace after 1 month. Oven shut off a couple times while baking and feature not available displayed when trying to turn on oven again. I tried starting clean cycle and waiting a couple minutes for element to heat then cancelled clean cycle. Oven worked fine after this but this shouldnt be a solution, obviously something not wired right.
Dec 09, 2013 | KitchenAid KIRS608BSS Induction Electric...
The control panel does not work at all for our oven, the time is displayed, but the oven will not turn on. The range works fine. I think I need to reset the control panel? for model GE Profile J2B918SELSS
If there is no reset on the control panel, which there normally isn't, you will probably have to get a new one if you wish to use auto. function in the future. If you don't require auto. function it is a simple procedure to by-pass the timer so the oven will work. With the timer by-passed the clock will still function.
Feb 11, 2011 | General Electric J2B918SELSS Stainless...
If my electricity goes out is there anther way to light my gas stve that has and electronic ignighter
If you have a gas range that allows the gas to flow freely on the surface burners, you can light them by using a match or lighter. Hold the match or lighter adjacent to the burner you intend to light and slowly turn the gas on. The burner should light.
However, the oven still will NOT work due to that fact that modern ovens are electronically controlled by the control panel on the range. So...you will still be able to cook, using the surface burners, but the oven will not function. If you have any questions, please post back and let me know. I hope this helps you.
Feb 03, 2011 | Kitchen Ranges
Jenn-Air range SVE47600W control panel is partially non-functional. Bake temperature control, off, oven light work. Clock does not display, oven clean and broil do not function. It may need a new panel...
We have this part in stock and can send it out to you first thing Monday morning, if you like. We will include installation instructions for you. You can call us from 7AM until 9PM CST Monday through Saturday. We look forward to working with you!!
Oct 15, 2009 | Ovens
Broiler coil sparked and broke, stopped working; 1 1/2 weeks later bake coil burnt out. I got new coils from the manufacturing, and had someone install. They don't work. The surface cooking area works...
Installer either did not do the job right OR when the coils broke they shorted in a manner that fried the oven control. The installer SHOULD have verified proper operation before they left your premises.
Jul 29, 2009 | Maytag Admiral LER3330AAW / LER3330AAZ /...
0ne of the surface units does not heat. Frigidaire Electric Range
HI, You will need to change the burner switch. When the element shorted, it took out the switch also. If you need help with part#, please let me know
Thanks
Vic
May 17, 2009 | Kitchen Ranges
Hot surface light
across each plate there is a cutout - you can usually see it thro the ceramic and is a rod going across the plate. it also senses that the plate is hot and turns the hobhot light on. this is the part that is faulty. sometimes only available as a complete plate
Sep 02, 2008 | Frigidaire FEF366 Electric Kitchen Range
Samsung NE595R0ABBB 5.9 cu. ft. Large Capacity Electric Range - Black Logo
305 people viewed this question
Top Samsung Kitchen Ranges Experts
Oloyede Monsuru
Are you a Samsung Kitchen Range Expert? Answer questions, earn points and help others
