Question about Whirlpool WED9200SQ Electric Dryer
Model WED9200SQ0 doesn't progress past the sensing phase. Any ideas? Matt
Motherboard?
  • 3 Answers
Have you opened the cabinet of the dryer yet? Inside you'll find the tech manual. It'll show how to get it into diagnostic mode. Unplug the power first.
I had the exact thing happen on my Maytag self dryer. It said that one of the line voltages wasn't present. After going thru the manual I knew the thermal fuse was bad $15. Since this was powering the motor it wouldn't spin and 2nd line voltage wasn't present. Replaced the thermal fuse, all the other sensors checked out good.
it started like a champ, YES!!!. Saved some serious money.
irvin
Posted on Mar 24, 2014
How to plug up sensing element
Thank you for your post, Inez!
I understand you would like to know how to plug up the sensing element inside of your Frigidaire air conditioner. In order to further assist you may I have your model number? You can locate your serial tag (which lists your model number) on the side of your air conditioner. With that information I can further assist you. -Matt
May 16, 2015 | Frigidaire Heating & Cooling
Washing machine when turned on will not go past water sensing. No water in machine. And no progress from this point.
Hi J Bunn,
If the bowls turning but no water inside, most obvious reasons there is no water going into the machine.
I will assume the water is on, check hose is not blocked with debris, otherwise a fill code 48-50 will show or it will just keep beeping pending on the particular model..
May 09, 2015 | Fisher and Paykel Washing Machines
My electrolux front loading washer won't go past sensing mode. What is wrong? What do I do?
Thank you for your inquiry, Sarah!
I see that your Electrolux washer will not go past sensing mode. This sounds like a possible issue with your sensor or door latch and I would recommend performing a reset on your washer to help clear out any miscommunications. You can reset your washer by disconnecting the power cord for roughly ten minutes.
I would check your door latch and door strike for any physical damage that could halt the progress of your washer. If you continue to have issues with your washer I would suggest having a professional out to perform a proper diagnosis and repair. I hope this information is helpful. -Matt
Mar 17, 2015 | Electrolux Washing Machines
Tv guide doesn't work anymore
I have a Sony model KDL-32BXR6 that the TV Guide first showed no listings this past weekend. Last night when I entered the Guide the screen displaying the Setup/Display Setup Progress came up stating "In Progress". Same thing this morning. Something must have changes with the input signal if this occurred with two different sets.
Dec 04, 2012 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
I have an AA A83421-107 motherboard, E210882. I want to upgrade the video card and was wondering what the details are for my mother board?
Your model 4500 has an AGP slot for video cards. The Accelerated Graphics Port (often shortened to AGP) is a high-speed point-to-point channel for attaching a video card to a computer's motherboard, primarily to assist in the acceleration of 3D computer graphics. Since 2004, AGP has been progressively phased out in favor of PCI Express.
Here is a link to the technical specs of your motherboard:
http://support.dell.com/support/edocs/systems/dim4500/specs.htm#1101572
Jun 24, 2011 | Dell Dimension 4500 PC Desktop
Three-year old 47" Samsung LCD. At first, some pixelation, usually correctable by turning TV off then on again. This situation lasted months, getting slightly more frequent each week. More recently, the TV...
1. the motherboard might be bad and you will need to replace it. 2. or The power supply is bad
Chances are if its making clicks the power supply is bad and you will need to replace it. Which makes sense because constantly powering the tv on and off will damage the power supply or possibly short out your motherboard. These things usually cost about 200 bucks to fix at a local tv repair store.
Sep 02, 2010 | Samsung LN-T4671F 46 in. LCD Television
I have a Whirlpool Duet dryer WED9200SQ0 that has been
Sounds like it. Or your seal around the door is about to give you a headache.
Nov 06, 2009 | Dryers
Machine keeps stopping and showing fo5
ALARM CODES
E11 Problems with water fill in wash phase E10 Cycle PAUSED 8.2
E12 Problems with water fill in drying E10 Cycle PAUSED 8.3
E21 Problems with water drain in wash phase E20 Cycle PAUSED 8.4
E22 Problems with water drain during drying or drying
condenser blocked E20 Heating phase skipped 8.5
E31 Analogic (electronic) pressure switch circuit faulty --- Cycle blocked
with door closed 8.6
E32 Incorrect calibration of analogic (electronic) pressure
switch --- Cycle PAUSED 8.7
E33
Incongruency between level of analogic (electronic)
pressure switch and level of anti-boiling pressure
switch 1
--- Cycle blocked
with door closed 8.8
E34 Incongruency between level of electronic pressure
switch and level of anti-boiling pressure switch 2 --- Cycle blocked
with door closed 8.9
E35 Water level too high --- Cycle blocked with door
closed and water drain 8.10
E36 "Sensing" circuit of anti-boiling pressure switch 1 faulty --- Cycle blocked
with door closed 8.11
E37 "Sensing" circuit of anti-boiling pressure switch 2 faulty --- Cycle blocked
E38 Pressure chamber blocked --- Heating phase skipped 8.12
E41 Door open E40 Cycle PAUSED 8.13-14
E42 Problems with door closure E40 Cycle PAUSED 8.15-16
E43 TRIAC which powers the door interlock faulty E40 Cycle PAUSED 8.17-18
E44 "Sensing" circuit of door delay interlock faulty --- Cycle blocked 8.19
E45 "Sensing" circuit of door delay interlock triac faulty --- Cycle blocked
with door closed 8.19
E51 TRIAC which powers the motor short-circuited --- Cycle blocked with door
closed (after 5 attempts) 8.20
E52 No signal from tachometric generator --- Cycle blocked with door
closed (after 5 attempts) 8.21-22
E53 "Sensing" circuit of motor TRIAC faulty --- Cycle blocked
with door closed 8.23
E54 Relays (motor) contacts faulty --- Cycle blocked with door
closed (after 5 attempts) 8.23
E61 Insufficient heating during washing --- Heating phase skipped 8.24
E62 Overheating during washing --- Drain, end of cycle 8.25
E63 Insufficient heating during drying Heating phase skipped 8.26
E64 Overheating during drying --- Heating phase skipped 8.27
E66 Power relay to heating element faulty --- Drain, end of cycle 8.28
E71 NTC wash sensor faulty --- Heating phase skipped 8.29
E72 NTC sensor on drying condenser faulty --- Heating phase skipped 8.30
E73 NTC sensor on drying duct faulty --- Heating phase skipped 8.31
E84 "Sensing" circuit on circulation pump triac faulty --- Drain, end of cycle
(door open) 8.32
E85 Circulation pump faulty --- Drain, end of cycle
(door open) 8.33
E91 Communications error between main PCB and user
interface --- --- 8.34
E93 Configuration error E90 Cycle blocked 8.34
E94 Incorrect configuration of washing cycle E90 Cycle blocked 8.34
EF1 Drain filter blocked LED-EF0 --- 8.35
EF2 Excessive detergent LED-EF0 --- 8.35
Regards David Marsh
Oct 22, 2009 | Washing Machines
Whirlpool WED9200SQ Electric Dryer Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
