Question about Shakespeare Sport & Outdoor - Others
I have a Shakespeare alpha PRC1310 7' Fishing Rod in a wooden hinged carrying case/wooden box. But it is missing the reel. Would you know what model reel would have been sold with this rod?
Alpha fishing reel PRC1310. Looking for reel that should fit inside the wooden box it came in.
Instruction manual for b-mag 1000
Shimano b-mag 1000 fishing reel manual -
momot-guitars.com/en/.../shimano-b-mag-1000-fishing-reel-manual?...
Jul 22, 2015 - Download Shimano b-mag 1000 fishing reel manual >> Download ...
May 05, 2014 | Shakespeare Surf Fishing Rod and Reel...
How to thread a Shakespeare fishing rod and reel
feed the line down through the eyelets on your pole ,now open the bail on your reel tie the line on the spool,and start reeling(keep tension on the line,prevents line from tangling) when i resting mine I only go about two thirds on my spool.
Jun 05, 2010 | Shakespeare Agility Spinning Reel 6825
Ladyfish fishing pole by shakespeare
try switching sides of the handle by holding the bell and reeling then screw it in on the other side of the real by just reeling in. If that doesn't work then take all the line out and reel in some new line the opposite way.
Aug 06, 2009 | Shakespeare Surf Fishing Rod and Reel...
I have a shakespeare sigma fishing reel that tangles up when I cast it, any solutions
The line needs to installed on the reel as it is on the new spool when purchased. Also check spool drag. If it is a spinning reel it is important to install the string correctly and use a quality brand of string.
May 18, 2009 | Shakespeare Surf Fishing Rod and Reel...
I do not know how to thread line through reel . No instruction on how to set up reel for fishing.
put spool of string on a pencil and have someone hold it, now snake the string through the eyes of the pole and attach it to the reel, on the small shaft in the middle, then just reel your pole in untill you reach YOUR limit of string..
Mar 06, 2009 | Shakespeare Surf Fishing Rod and Reel...
Sport & Outdoor - Others Logo
Top Shakespeare Sport & Outdoor - Others Experts
Bill Eager
Mike Marcotte
Mike Marcotte
Andrew Taylor
Andrew Taylor
Are you a Shakespeare Sport and Outdoor - Other Expert? Answer questions, earn points and help others
