Question about Kohler Home
We have tiny air bubbles in our brand new Kohler tank. We also have tiny streams of water constantly flowing into bowl. It's super quiet while the tiny streams run in the tank, not making the sound o
I also noticed that the mechanism that holds the water level black contraption that moves up and down to shut off the water, leaks a tiny bit at the top..
    Master:
  • 966 Answers
Watch the mechanism after you flush. If the opening that lets water into the bowl does not close snugly, tiny stream will continuously flow. Make sure it closes properly.
Posted on Mar 24, 2014
  • 653 Answers
SOURCE: raising water level in the toilet bowl.
The water level in the bowl is limited by the height of the internal trap down stream from the bowl. There is no adjustment possible. If the problem is odors, you can either flush more often, turn on the exhaust fan, or buy a different brand or model of toilet.
Posted on Apr 04, 2009
  • 659 Answers
SOURCE: Toilet won't shut off
Does it leak from the overflow? If so then the washer at the top of the Fluidmaster needs to be replaced. If it is not going over the overflow then you will need to replace the flapper on the flush valve.
Posted on Apr 11, 2009
  • 308 Answers
SOURCE: super low water level in bowl decreases after flush refills
First, fyi, adjusting the knob? in the tank, or the fill level will not increase the amount of water in the bowl. The bowl fills to a certain point, and then as more water is added it starts to go over the built in trap, and down the drain. When you flush the toilet, all the water in the tank dumps into the bowl, and the existing water is pushed over the trap and down the drain. All of this being said it sounds like you may either have an internal crack, between the bowl and trap; you may have a crack that is draining under your toilet, (water spots?), or you have a more serious plumbing issue, improper venting, which is causing a vacuum, and pulling the water out. Hope this helps.
Posted on Jun 17, 2009
  • 10 Answers
SOURCE: Replaced toilet fill valve - now bowl water level a bit lower
put some water in with a bucket. poor some in slowly until you get it where you think it should have been. If it levels back out at the lower level. Then there is nothing wrong. Maybe the leaking water was keeping the bowl water line high than it should have been.
Posted on Jul 26, 2009
miket756
  • 2702 Answers
SOURCE: Can't adjust flush time for complete flush, low bowl water level
flush time depends on how much water is in it,
the water level flote has an adjuster on it, but i cant rember were it is,,, sorry
Posted on Oct 24, 2009
I installed brand new Kohler toilet w/ a Fluidmaster float. From the beginning the tank empties just enough to fill back up. I also noticed air bubbles on bolt caps and the rest of the parts.
Check the flapper and seat. Ensure that the flapper chain is not tight or caught underneath flapper. Check floor underneath tank for any sighs of water leaking or seeping from tank. tight tank to bowl nuts. good luck
Apr 03, 2018 | Kohler Home
Not shutting off completely when flushing
You're to replace shutting valve.
Jan 25, 2018 | Home
I have a 2yr old Kohler K4634 toilet. After flushing the water level drops about 1 inch in the bowl after the bowl filled. This causes a lower level in the bowl than is recommended. The main issue
check to see if waster continues to run into the bowl after the plunger has returned to stop water flowing. If it is a slow leak then replace the flush washer on the stopper plunger.
Oct 01, 2014 | Kohler K-4634-RA-0 Cimarron Toilet Tank...
Faucet makes noise when turned on but produces only a tiny stream of water
sounds like u got some kind of blockage in it take apart and clean
Aug 13, 2012 | Kohler Plumbing
Have brand new 3489 cimmaron 1 piece toilet. tank empties on flush but no suction empty on bowl. water only eventually leaves bowl
It may be the wax ring expanded and is restricting the flow.
If you did not install the unit FYI ..the wax ring is inserted between the toilet and the waste pipe to prevent leakage. Sometimes it moves out of place when the toilet gets installed and blocks the flow
Feb 23, 2011 | Kohler Home
Water in bowl. water level almost below where bowl saris to widen! , Kohler cimmarron - Toilet tank is full, all water flushes out of tank when flushed it's been this way since we installed it
If I understand correctly, your water level inside the bowl is 3 or 4 inches from the top of toilet seat?
Sounds peculiar to have that water level since you would get splashing etc.
That is not sanitary, and would be a code violation.
Look at side profile of tank.
Look at porcelain behind bowl and you can see outline of "s trap."
This is the internal trap that each toilet has built in.
Purpose of trap is to a) set water level inside bowl and b) just like a sink trap, seal pipe from sewer air from entering home.
Photo shows trap on sample toilet, with line showing approximate level of water inside bowl.
Since photo is at an angle, the line appears to go downward instead of level. Again the line is approximation, and photo intended to show where you can look on your toilet.
Your tank should have similar s-trap feature. From the feature on your tank, you can see what level water is intended to be inside bowl.
Some more expensive tanks, outline of s-trap is not apparent.
If the water level is so high that you experience unsanitary conditions, this is a code violation, and toilet should be replaced.
Quick web search turned up Kohler contact page: http://www.us.kohler.com/general/contact.jsp
KOHLER Customer Care at
Phone: 1-800-4KOHLER (1-800-456-4537)
Hours: 8:00 AM - 5:00 PM (Central Time) Monday to Friday
You can refer Kohler to this link on Fixya so they can clearly understand issue.
Jan 09, 2011 | Kohler - Toilet - Two-piece - Highline -...
My 2005 yamaha TTR 125 will not let gas flow into the carb bowl, you can pour gas into it and it starts right up, thanks!
Your float in the bottom of the carb is likely stuck in the up position. The float attaches to a valve that shuts off fuel flow when level is just right. Can you see the little screw at the bottom of the bowl? Do you see the little overflow hose below that? Get a plastic soda bottle, put the outlet of the tiny hose into it. unscrew that little screw a few turns. Do you see fuel coming out? No? then take the back end of a screw driver and tap the bowl of your carb sharply 5 or 6 times. (Make sure the fuel pet **** under the tank is turned on. If you do not see fuel going into your bottle in a minute, shut off fuel at the tank. Screw the bowl drain back in. Remove the larger incoming fuel line that goes from tank to carb and put it into the bottle. Now you will open the petcock a little bit slowly. If you never see fuel come out of the tank, thru that hose, then your screens on the petcock may be clogged. Shut off fuel , Remove the cap on your fuel tank. blow into the line while slowly opening the petcock valve. Hear air bubbling in the tank yet? If you do, shut off valve, remove air pressure from line, point it back into the bottle and reopen the valve. If none of this works, then you need a new petcock valve.
Nov 29, 2010 | 2004 Yamaha TT-R 125 L
Our Kohler K3402 suddenly stopped flushing. When you pull the handle and the flapper comes up, all that happens is the tank begins draining into the bowl and the bowl level rises, almost to the rim. The...
If there is a shower in the same bath is it also draining slowly?
If so check that drain systems air vent, (on the roof).
Find the pipe coming out of the roof nearest the bathroom with the problem and when a second person flushes the toilet you should be able to feel
air moving in and out of the pipe with your hand covering the end. If not the vent could be blocked by leaves or animals etc., this vent has to be clear in order for water to drain properly.
May 20, 2010 | Home
BRand new elongated Cimarron shoots water out of bowl durng flush
Is the fill line in the tank loose? Does it just shoot water into the tank itself? I had this issue until I realized the while fill tube is supposed to be pushed into the black cylinder/small plastic tube in the middle of the stopper assembly. After i pushed the line into the tube, the bowl would always only fill a little bit. Now it fills almost a 3rd of the way up the bowl and doesn't bubble during flushes.
May 09, 2010 | Kohler Cimarron Comfort Height elongated...
Cimmaron one piece elongated doesn't have enough water in BOWL.
Make a small mark with a pencil or marker that can be erased of were your water line is in your bowl. Pour some water from a bucket into the bowl SLOWLY and see if the water line rises or drops back down to your original mark. If it drop back to the original mark, then that is the way the toilet was made. You won't be able to do anything about it. If it rises and stays at a higher level, then you have a problem with the fill tube in the tank. You will need to call a Pro!
Jan 28, 2009 | Kohler K-3489 Cimarron Comfort Height...
Home Logo
96 people viewed this question
Top Kohler Home Experts
john h
Tim Whalen
Mike
Are you a Kohler Home Expert? Answer questions, earn points and help others
