Question about Springfield Optics
Changing hand grips on Springfield DxM 40 cal
Change hand grip on gun
  • 351 Answers
SOURCE: Kleenmaid KAW 693W-3050 7KG Washer
open the control panel use pliers on the back of the timer shaft then try to remove the knob
Posted on Aug 27, 2008
  • 2336 Answers
SOURCE: installing new grips
I use hair spray. -Cut the old ones off -Soak the clip-on (left) w/hairspray -Quickly slide grip on and align. Once it is aligned allow it to dry. -Soak throttle tube (right) with hairspray, slid grip on, align, and allow to dry. I guess this is probably a bad time to tell you about the R1 throttle tube (or BRG throttle tube) mod. It's a bigger throttle tube which means less twisting to go WOT. Late model Gixxers are notorious for a long twist to go WOT.
Posted on Nov 10, 2008
barkencoa
  • 3463 Answers
SOURCE: change grip/handle on a indesit washing machine w105tx
Undo any screw that you can see on the inside of the door frame, and then prize the two halves apart,
This should give you access to the door handle assy.
Hope this helps.
Posted on Dec 02, 2008
SOURCE: My Guitar hero on tour grip won't work!
Allways check what you actualy order. Son did not realise what he ordered did not come with the game card.
Posted on Jun 03, 2009
wd4ity
  • 4565 Answers
SOURCE: Changing grips. Any suggestions or warnings,
Usually when you change the grips on the throttle side, depending on what type of replacement grips you bought, you'll be replacing the throttle sleeve as well. This means that you will be messing with the throttle and idle cables.
Loosen both cables at the adjusters as loose as they will go. Then, remove the two bolts that hold the right hand switch housing together. Carefully seperate the two halves. Do not damage the wires going to the switch. Work the throttle cable and the idle cable out of there slots in the throttle sleeve of the old grip. Be careful not to loose the brass ferrel that goes over the cable end. Lubricate the inside of the new throttle sleeve, the handlebar, and the area where the cables hook up with white lithium grease. Reassemble cables into new sleeve and reassemble the switch housing.
Once you have everything back together, adjust the throttle cable first and leave just a bit of slack in the cable. You should be able to freely "rock the throttle grip" before you feel the cable tighten up, Just a bit. Then adjust the idle cable about the same way.
Now, Turn the throttle cable to Wide Open throttle position and release it. It should "snap" shut, do this again from half and quarter throttle to make sure it works as it should. Failure to insure that the throttle operates properly can cause serious injury or death.
If you are simply replacing a grip on each side of the handlebar, use a long slender blade screwdriver or an ice pick to slide between the handlebar and the grip. Spray some WD40 in the work the grip a bit and it will break loose. Clean the throttle sleeve and handlebar off alcohol. Now, some people like to use "Grip Glue" on the new grips. Put the glue inside the grip and slide it up on the handlebar. If you put the glue on the handlebar, it will roll up in front of the grip as you slide it on to the handlebar or throttle sleeve. Make sure you "align" the two grips so they look the same before the glue sets.
Good Luck
Steve
Posted on Jul 18, 2010
I can't get the chuck to work or open to change the drill bit. I have really tried!
Hi Alice:
Is this a "key"? If so, put it in place with the drill pointing up and the key handle pointing level and towards you. A light tap with a hammer on the key handle should loosen it.
If it is a "manual grip", try putting the drill in reverse, and at low speed. Hold the drill handle with your right hand, and hold the grip firmly (really firmly) with your left hand, and squeeze the trigger. It should release the chuck. If it doesn't, try putting a pipe wrench on the grip.... gun facing away from you, wrench from the top, handle on right. gently tap on the wrench handle should loosen it.
Cheers.
Apr 08, 2016 | Ryobi Drills
Break bolt lose on harmonic balancer keep spinning
Hello. If you have a impact gun it will spin off , if not you can use a pair of vise grips and a leather glove. Put the glove around the pully and pinch it with the vise grips. This will help you keep from bending or putting nicking up the pully. Then just turn the bolt until the vise grips hit the side of the housing and you should be able to break it lose.
Feb 23, 2015 | 2004 Volvo S80
I have Smith and Wesson down break .38 cal handgun .The side of barrel has a stamp ".38 S&W CTO" Serial is 484555 What model is this, when was it made and any worth?
Can't tell the model without looking at it. Condition is everything in older guns.
.38 S&W Ctg. is a DIFFERENT caliber than .38 Special.
Feb 16, 2015 | Crimson Trace Smith-and-Wesson Handgun...
Fox nailerfirering pin not retacting fully
The majority of the time this is caused by damaged or broken o-rings inside the gun. The rebuild kit for the Grip Rite GRTBN200 is part number GRRBK100. Make sure to lubricate the o-rings as you put the gun back together and always put a squirt of pneumatic oil in the gun before using it to keep the o-rings lubricated.
Feb 15, 2012 | Grip Rite Grip - Rite 18 Gauge Brad Nailer...
How can I fix Springfield Precise Time atomic clock which has correct time on large (minute) hand but is behind several hours on hour hand?
I'm not sure if we have the same clock. Mine has needed batteries for a while, finally picked them up today. Once the batteries were in I had to reset the Zone by pressing and holding "CLK/CAL" button until the time blinks, then release and push the button until you see one single number on there... then set the zone. There is info in the user's guide (I can't find mine) so I kept changing until the time was correct. Now works perfectly.
Jan 23, 2012 | Audio Players & Recorders
Carver one e grip has no power button. how do i get it 2 work?
Look really close at the front of the grip. There should be a couple of small holes and one has the power button recessed inside. Tippmann.com should have a schematic on it and the programming instructions as well for setting/changing modes.
Enjoy!!!
Play hard, play safe, play with honor!
8^)
Dec 25, 2010 | Tippmann A 5 Standard Paintball Gun
How do you load BB's in Marksman repeater 177 cal pistol (hand gun)
1) If you have sucessfully released the safety lever, grab the textured black grip of the cocking mechanism and pull it back until it locks into place.
2) In a safe manner, hold the pistol by the handle with your left hand and carefully grab the black plastic sighting mechanism at the end of the barrel with your right hand and pul this black tip end of the pistol downward. You should find that the other end (which lies more mid-barrel) will pivot upwards, giving you access to the loading tube.
Feb 03, 2010 | Marksman X7 Extreme 3-Channel Remote Start...
Optics Logo
20 people viewed this question
Top Springfield Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Springfield Optic Expert? Answer questions, earn points and help others
