Question about Epson Office Equipment & Supplies
Both ink and paper jam lights flashing
And the power light is off . says service required. I use a mac computer
  • Epson Master
  • 783 Answers
The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.Go To Below official Epson Printer Page For Your problem and solve your paper jam problem https://files.support.epson.com/htmldocs/cx11nf/cx11nfug/trb_e_1.htmHope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For Epson Printer Support
Posted on Mar 26, 2014
Inky
  • 691 Answers
SOURCE: Both Ink & Paper lights flashing!
Hi JayBirde Do the lights flash Together (not alternate) and is it a quick flash (0.1 second on 0.1 second off)? If so, check the Status Monitor for a message. If it says Fatal Error or General Error, then you have a task on your hands! If the lights flash alternate (0.5 second on 0.5 second off) then this indicates a maintenence error and the status monitor should say parts inside your printer have reached the end of their life - or something similar. This much easier to fix with an R220 Rescue Kit from www.TheServiceManualShop.com - use their search to look for R220 Rescue. If you can't find it, just drop them a line and they will create one for you. Delivery is via instant download so no waiting around to get your machine fixed. If you have a general or Fatal error it means the printers head can not move using the norm,al amount of force - i.e. something is in the way. You can check a few things: Ensure their is nothing in the path of the print head - paper, foam from the pad, head lock not retracting, toy soldier on manouvers in the mechanism etc Chech the encoder strip ( a grey-ish looking plastic strip, near the drive belt for the print head) is clean and attached. Check the lid for the ink cart cover is full closed.
Posted on Mar 11, 2007
websnail
  • 419 Answers
SOURCE: epson 2400 paper red light and ink red light
It sounds like your printer has reached what is often called the "service required" stage...
To solve this you need to handle two things.
1. Get the printer protection counter (or waste-ink as it's sometimes called) reset.
2. Replace the waste ink pads OR redirect your waste ink flow to an external tank
It's important to note that Epson will encourage you to do a waste pad replacement through one of their service centers, but if you're out of warranty this will cost a significant amount of money (approx: $100 - 200)
To solve these as a DIY you can do the following:
1. Resetting the counter...
Get a resetter, either the SSC utility (google: epson SSC utility) or the IPR utility that Epson have now made available via their website here
The latter is only available to North American printer owners so the SSC is a safer bet.
2. Redirecting waste ink to an external container.
This is something I'd heartily recommend instead of trying to change the waste pads yourself... It's simple enough to do and a little googling using keywords "Epson R2400 waste ink tank" should get you all the info you need.
There are simple kits available that offer everything you need or you can easily go for a DIY with bits you have to hand.
Hope that helps...
Posted on Mar 09, 2009
websnail
  • 419 Answers
SOURCE: flash feed paper & ink light my epson r1800 printer
Do you mean that the paper light flashes at the same time as the ink light or do they flash alternately (ie: paper on, ink off -> paper off, ink on)?
If so the waste ink pads are full and you need to do the following:
1. Reset the waste ink counter:
Grab the tool linked from the wasteink.co.uk site (see bottom).
2. Redirect your waste ink into an external tank OR replace your waste ink pads.. (external tank is easier).
Instructions for the R1800 are available from this site
If the lights are doing something different, please post again with detailed information about how they flash and I can what else it might mean.
Hope that helps.
Posted on Mar 13, 2009
  • 51 Answers
SOURCE: Epsom R200 printer - ink and paper lights flashing red.
theres a guide on how to manually reset the counter here
unless you replace or clean the waste pad from here on in regard your printer as a ticking ink bomb. put it on a tray with a lip just incase of an ink overflow and dont put it on the carpet.
Posted on Sep 26, 2009
pineworks
  • 4041 Answers
SOURCE: Epson Stylus TX110 printer paper jam light flashing but no paper
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 28, 2010
Epson stylus photo px660 with a paper jam error after dismantling it displays a printer error with all lights flashing
Paper jam problems can occur due to strayed, stuck bits of papers in pathway of paper tray, outlet, roller etc. I would recommend cleaning the paper inlet, outlet, and other possible areas to avoid a paper jam situation. I have observed that most people fan the paper pile to keep them dry or non-sticky. It's a wrong method because fanning the pile of papers make them go haywire and often lead to paper jam.
The flashing lights are a "Maintenance request error" or a "Fatal error". Most of the time it is a "Maintenance request error" which means the waste ink pads need to be serviced. You can reset the waste ink counter but the ink pads will need to be serviced at some point.
you can try following points.......
1.turn off the machine for at least 5 minutes and disconnect the interface cable to the computer.
2. push and hold down the "ink" button and the "paper" button and turn the printer on.
3. When the "paper" light flashes quickly release both the buttons and then immediately press and hold down the "ink" button only for at least 10 seconds.
**You will need to try this several times to get the sequence correctly.
If you need any kind of technical assistance, you can contact support cell at http://vtechsquad.com/printer-support/
Sep 11, 2012 | Epson Office Equipment & Supplies
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
Power light (or Alarm and Power lights) alternate(s) between orange and green After long green flash, there are 2 or more alternating orange and green flashes. There may also be a Service Error message on...
Try resetting the printer by unplugging the printer from the power source for 5 mins. and they make sure ink is full and paper is loaded and not jammed. If not resolved carefully remove all ink cart from machine without touching and ink cart metal contacts, reseat the ink cart and reset and the printer.
Feb 21, 2010 | Canon i850 InkJet Photo Printer
Blinng orange light
Answer Part 1 of 2
An error has occurred in the printer. The number of flashes indicates the type of error, as outlined below. Check the cause and take appropriate action.
Two flashes: Out of paper or paper feed error
Reload the paper correctly and press the RESUME/CANCEL button.
Three flashes: Paper jam
If paper has jammed in the printer, clear the jam, reload the paper in the printer correctly and press the RESUME/CANCEL button.
See Paper Jams
Four flashes: Ink tank is not installed properly
Open the Print Head Cover and check whether an ink tank is installed. If an ink tank is installed, push the button of the ink tank, and reinstall the ink tank properly.
Five flashes: No Print Head installed, or Print Head failure
Install a Print Head.
When the error continues, contact a Canon service representative.
Eight flashes: Waste ink absorber almost full
Ink used for cleaning is absorbed in a waste ink absorber placed in the printer. Eight flashes indicate that the waste ink absorber is nearly full. Press the RESUME/CANCEL button to cancel the error so that you can continue printing.
Important
If this error occurs, replacement of the waste ink absorber and maintenance of the printer are required. Canon recommends to contact a Canon service representative as soon as possible. Once the waste ink absorber becomes completely full, it cannot be printed until the Waste ink tank is exchanged.
Nine flashes: A specified period of time has lapsed without receiving a response from a digital camera or digital video camcorder / The digital camera or digital video camcorder connected is not compatible with this printer
Sep 30, 2009 | Canon PIXMA iP90 Mobile Printer
The light is blinking on my maching (i believe it's the ink--or lack of it). i'd like to find out if that is so, but i can't seem to find the route to that on my machine, which is a mac. How do i get that...
I can't tell you how you could find out on you Mac as I've never used one with my C86 but I can tell you that you can translate the light flashing into a more meaningful "message" by observing the patterns.
  • Paper & Ink lights flashing alternately (power light off) = service required (ie: waste pads need replacing)
  • Ink light flashing = ink cartridge is empty or printhead is in the exchange position. Try pressing the ink button once (don't hold it down) and see if it moves to the exchange position or moves back to park.
  • paper light flashing = paper jam or no paper in feed.. Remove a jam or feed it with paper as required then press the paper button
  • Power light flashing = printer is busy... If it's doing nothing trying pulling the power lead out of the back of the printer, wait 5 seconds and then plug it back in, turn it back on. This should clear any error.
  • Both ink and paper lights flashing (together) = General error.. This could be anything from a serious paper jam, loose wire in the printer, parking station disconnect or similar..
Hopefully that will give you something to go on and get you working again... As far as software information goes, someone else may be able to help but chances are Epson's own support site will have some software called Status monitor or similar for your operating system which may help.
Cheers
Martin
Aug 05, 2009 | Epson Stylus C86 InkJet Printer
Problem on a canon 3100
The Power Light Flashes Orange - Error Codes When an error occurs, the power light flashes orange. The number of orange flashes followed by a long green flash indicates the cause of the problem.
Two orange flashes: Out of paper, paper jam, or paper feed error
If no paper is loaded in the auto sheet feeder, or if the paper is not loaded correctly, set the paper correctly and press the Resume button on the printer to continue printing.
Three orange flashes: Paper jam
If paper has jammed in the printer, carefully remove the jam and press the Resume button to continue printing.
Four orange flashes: A tank inside the BJ cartridge (print head) is out of ink
Replace the empty BJ tank and press the Resume button to continue printing.
Five orange flashes: BJ cartridge is not installed properly
Remove and reseat the cartridge correctly. Make sure the orange protective cap and tape have been removed. Make sure the blue locking lever is locked down securely.
Six orange flashes: BJ cartridge (printhead) is not installed
Seven orange flashes: BJ cartridge (printhead) is defective
Remove the BJ cartridge and check that the contacts on the cartridge and cartridge holder are clean. Make sure the orange protective cap and tape have been removed and reinstall the cartridge. If the error occurs again after you resume operation, you may need to replace the BJ cartridge.
Eight orange flashes: Waste ink absorber almost full
The printer has a built-in waste ink absorber to hold the ink that is consumed during print head cleaning. This error indicates that the waste ink absorber is nearly full. Press the Resume button to skip the error so you can continue printing.
The POWER light flashes orange and green alternately: Service error
A service error means the printer requires the attention of a qualified technician. Count the number of flashes. (You may be asked this information.)
Feb 02, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Blinking both the ink botton ligths and the botton paper
I just today threw away my R220. If your 2 red lights are going and the power light is off, then your printer has died. It just happened to me. It sucks, but there is no way to fix it.
May 04, 2008 | Epson Stylus Photo R220 InkJet Printer
Deskjet 930c printer
Good for you for being on the internet and posting the question! The yellow light usually means, paper, ink or a jam. If it's got paper and ink, check for jams and even power cycle it and see if that helps. And try printing, it may just be reporting low ink. Good luck!
Jun 09, 2007 | HP DeskJet 930c InkJet Printer
83 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
