Question about Dell Precision M65 Notebook
How can i reset bioss password....dell precision m65
Where is the jumper of reset bioss password on the motherboard .....dell precision m65 ? please help my .......thank you!
  • 523 Answers
My friend the new laptop has no jumper anymore on the board, and u cannot reset the bios this easily, some laptops u still can do that by disconnecting the bios battery and connect it after some minute, but if this doesnot work donot destroy ur laptop.
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Posted on Jun 14, 2009
How do i reset the jumper on the motherboard
First you will need a CD to boot from, like your OS ( operating system ). To boot from that CD, keep tapping the <F12> key until it displays a boot selection menu. There you can create or delete partitions that hold your OS.
Sep 26, 2012 | Dell Mobile Precision M6500 Computer...
My dell precision m65 is locked with a bios password, please help.
You will have to contact Dell for a master password and prove ownership of the laptop too.
Click on the link below fror Dells contact details >>>>>>
http://support.dell.com/support/topics/global.aspx/support/dellcare/contact_technical_support?c=us&cs=19&l=en&s=dhs
Regards.
Dec 10, 2010 | Dell Precision M65 Notebook
How can you reset a Precision M70 Laptop bios password
For that you need to reset bios password.
There is 2 way (1) Reset bios password with cmos cell and jumper settings.For that you need to open back cover of laptop then find motherboard pull cmos cell from motherboard for 10 minutes then reattach it into it's position.There jumper near cmos cell named clear_cmos it has 3 pins 1-2-3 put jumper in 2-3 position then power up then again put it into it;s original position 1-2 then all password RESET.
(2) you can RESET bios password with software download it from below link.
Click here
Click on above link download software there is instruction how to reset bios password.
Let me know if you need further assistance.
Thanks for using FixYa.
May 07, 2010 | Dell Precision M70 Notebook
Dell Precision M65 Locked
There is usually only one true way to clear this type of password...the only problem with some of these systems is the password is stored in a chip on the the motherboard and not in the RTC battery, but this may not be the case with this particular model. Below is the procedure for the "shorting" of the RTC battery leads.
If you have forgotten your BIOS or system password, there are no software tricks or magical gimmicks that will get the password cleared. Laptops are different in that they are designed to not work with “backdoors” etc. for security reasons. There is one true way that works most of the time and that is hardware.
The Cmos (RTC) battery that is mounted on the motherboard in most cases holds the key, if your motherboard has the battery that is connected to the motherboard by using a two wire socket that plugs into the MOBO, then here is the procedure.
On the motherboard where the battery plugs into, you will see two pins sticking straight up, these engage the plug on the battery side. These two pins have to be “shorted” and then the motherboard powered up for approx. 30 seconds, then power down the system and replace the Cmos battery and reboot. Only reboot with the AC adapter plugged in, not the main laptop battery. Your password problem should be cleared up. The best way to “short” the pins is get another cmos battery and cut the wires from the battery part, bare the ends and twist together, this will short the pins. Make sure you tape the connection good on the jumper you just made….don’t want to touch anything else with powered up bare wires. Good luck.
If the battery is the disc type and sits in a horizontal socket on the motherboard, then it is a little more difficult to perform but the theory is still good, the positive and negative have to be shorted and the same procedure done. In most cases, just removing the cmos battery does not work in laptops, this is because there is extra security needed because of their portability.
Jan 17, 2010 | Dell Precision M65 Notebook
How to reset my bios dell precision m65
You did not give your exact model number, you will have to reset the jumper on the motherboard to default factory configuration.
Jun 06, 2009 | Dell Computers & Internet
How do I reset my lost bios password for Dell Precision M70
If you cannot access the machine after if has been powered up, it is still possible to get past the BIOS password. The BIOS password is stored in CMOS memory that is maintained while the PC is powered off by a small battery, which is attached to the motherboard. If you remove this battery, all CMOS information (including the BIOS password) will be lost. You will need to re-enter the correct CMOS setup information to use the machine. The machines owner or user will most likely be alarmed when it is discovered that the BIOS password has been deleted.
On some motherboards, the battery is soldered to the motherboard, making it difficult to remove. If this is the case, you have another alternative. Somewhere on the motherboard you should find a jumper that will clear the BIOS password. If you have the motherboard documentation, you will know where that jumper is. If not, the jumper may be labeled on the motherboard. If you are not fortunate enough for either of these to be the case, you may be able to guess which jumper is the correct jumper. This jumper is usually standing alone near the battery. If you cannot locate this jumper, you might short both of the points where the battery connects to the motherboard.
If all else fails, you may have to clear the BIOS password by resetting the RTC (Real Time Clock) IC (Integrated Circuit) on your motherboard.
The BIOS password may be cleared from a Dell Optiplex by removing the password jumper (PSWD) from the motherboard.
The location of the password jumper on a Dell Optiplex motherboard can be found by reviewing the Optiplex User Guides.
For most Dell Optiplex desktops, the steps to reset a BIOS password and clear all CMOS settings are:
  • Locate the 3-pin CMOS password reset jumper on the system board.
  • Remove the jumper plug from pins 1 and 2.
  • Place the jumper plug on pins 2 and 3 and wait approximately 5 seconds.
  • Replace the jumper plug on pins 1 and 2.
Each Dell Inspiron has a master password which will clear the BIOS password. You can get this number by calling Dell Technical Support at (800)624-9896.
Dell Technical Support will request the Service Tag and Express Service Code from the bottom of your Inspiron.
Thank You,
Your Support Tech.
Manish Shirsikar,
Fixya.com
May 18, 2009 | Dell Precision M70 Notebook
How to remove bios admin password for dell precision m65
If I'm understanding your question correctly, you need to reboot the system hit the F2 key to enter the BIOS setup - find the password page (can't remember what Dell calls it) and disable the password.
May 11, 2009 | Dell Precision M65 Notebook
If you open the tower itself there is a battery on the motherboard that if removed will reset your bios password. just remove the battery wait about 5 minutes and then put the battery back in and power on this should take care of your problem.
when you boot the system hit the F2 key when the manufacturers logo pops up to log into the BIOS setup and look for the password screen and disable it.
Dell Precision M65 Notebook Logo
1,144 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
