Question about Breville Barista Express
Water presure or clogged up.
I've had my Barista Express for three years, and changed the water filter three times. Two days ago, it seems it pumps water in when I turn it on, but it does not release water through the group. I took the filter out and the inside of the group (the mesh part) apart. It sounds really clogged up, and lost all presure. What else can I try?
  • 31 Answers
I don't have the same brand, but I had a similar problem. These machines depend on generating high pressure (bar) and clogging is a problem. One source of clog is calcium and minerals in the water. Even though you have and change the water filter, there will still be minerals in the water and it can result in clogging.
You should use a decalcifier periodically but for the problem you are having now, you most likely need to take the head apart and clean the mesh and parts. Make sure light comes through all the holes. Don't enlarge the holes. Just clear them. That is what did it for my unit. Hope that helps.
Posted on Mar 24, 2014
4 Suggested Answers
  • 37 Answers
SOURCE: grinder jam on breville barista express
Only way to know for sure is by taking it completely apart and expose all the internal parts
Popping is not a good sign If it is electrical arcing you are playing with fire
or electrocution
If you are mechanically inclined they are not that hard to take apart as long as they have no security screws on it and you have to remember you might be voiding your warranty
But it is fun taking things apart No?
Posted on Feb 06, 2012
SOURCE: Can you help us.
TOO FINER GRAIN OF COFFEE WILL CREATE THIS PROBLEM
Posted on Jan 10, 2010
SOURCE: Pump Problem
Our lucky fix for this identical Christmas day problem was to put the reservoir in place about half full of water, then to reach down in it and pull the plunger up to open it. We had the machine running at the time, but that may not be necessary. regards, Gene
Posted on Dec 26, 2007
\i just got a Canature water softener and ionizer installed, every time it cycles water gets into my water lines and spurts out for about 15 minutes, pipes shake
sounds like a mix of things
if you have pipes not locked tight
and 1ft = 1 clamp spaces
also check any 'gate' type valves are all fully open
use a presure 'keep' valve regulator to turn down the water presure
to 1.5 - 2 bar {60psi}
if you half close a gate valve
then the whole intake can vibrate and sing
even how much you try to wedge the pips
its the gate valves cause issue
in cold water then it uses presure joints and presure makes the seal
but gate valves will bring like the read in a woodwind instrument like a claronete
so your pipes will sing
check all the filters intake valves at the machine filters
and your gate valves on your water supply to the machines hozes
Mar 04, 2015 | Washing Machines
Water is leaking from my Breville Barista Express Espresso machine's water tank valve.
u r is the 4th problem with the same unit. take it bak to the store and git another 1.
Feb 23, 2015 | Breville The Barista Express BES860XL Open...
Not filtering
too many chemicals will cloud contact the company website or did you maybe its the water change the water
Feb 28, 2017 | Pentair Tagelus TA 60D Filter
Ice smells like mildew! We purchased the refrigerator/freezer new 6 months ago. It does not seem to be a problem caused by other foods in the freezer. Model number: FFTR2126LW
Mildew smell in your ice is caused by one of three things. 1. Old, dirty, clogged water filter 2. Bad water quality from your house water supply 3. Ice that has not been used and sits in the bucket for time can become stale tasting.
Sep 01, 2011 | Frigidaire FFTR2126LW Top Freezer...
What is the best time of day to run the Salt Water System...Morning, Afternoon or Evening?.....and how long? Manual says run for about three hours but that doesn't seem enough...we have been having...
I have an 18 X 33 oval and temparatures here range from 80 to 102 in the summer. I run my cycles at 10 to 12 hrs pump with 8 to 10 hrs chlorinator. Water stays crystal clear, no cloudy.. Now...if you don't keep the electrolytic cell clean and maintain the proper salt levels, you will struggle with making free chlorine...
Hope I helped??? AND... I HAVE NOT ADDED ANY CHEMICALS TO MY POOL IN THE 2 YEARS I'VE HAD MY INTEX SYSTEM...
Jul 18, 2011 | Intex Automatic Salt Water System for ...
Hi I have a Starbucks Barista Italia Digital that has been sitting in storage for over a year. When I try to prime the pump, it makes a noise like it is trying, but no water comes out. I have tried...
You could have a seized water pump if you haven't been descaling regularly. Take the pump out and disassemble, clean, reassemble. Work carefully as there are several small parts.
Feb 08, 2011 | Starbucks Saeco Italia Digital Barista...
Hayward Perflex EC-75. The DE is gumming up after about 1 week all up in the fingers. Keep taking the filter apart and washing it down then replace the DE but only getting one week out of the new...
I maintain three commercial pools ... one a hot tub. We replaced the DE with sand filters this spring. The last year of DE - even with insisting the patrons shower first, we only got one week out of the DE ... and we were dumping the water also. Suntan oil, body oils ... it was a mess. The water was sparlking for 6 of the 7 days ... The only way to keep it that way was dump the water and change the DE.
Maybe your filter is not big enough. Had you given the gallons or the size of your pool, I would have calculated the filter area for you. If you can post it and if FixYa, notifies me, I would be glad to do the calculation.
Aug 03, 2010 | Hayward EC75 HAYWARD PERFLEX FILTER SYSTEM...
It won't start, Seems to be a fuel problem, Had yhe fuel pump change a year ago.
It may just be a plugged fuel filter. I also recommend checking fuel pressure at the fuel rail.
Jun 30, 2009 | 2001 Chevrolet Blazer
Pump goes on and off
Does the pump have thermall protection? It sounds like its getting hot and tripping the thermal protection switch in the pump windings.
Oct 06, 2008 | Sunterra 450gph Pond Pump
Breville Barista Express Logo
214 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Steve
Colin Stickland
Colin Stickland
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
