Question about Central Machinery 5-1/2 Horsepower Chipper Shredder
Sharping the blades
How do I remove the fly wheel so I can get to the blades.
  • 1,162 Answers
I dont think you need to remove the fly wheel to sharpen blades. Remove the housing an the blades are visible an removed that way. Not a hard job at all.
Posted on Mar 24, 2014
Testimonial: "Thanks cwradio73 To remove the housing or hopper, seems rather hard. The housing is all one piece. The engine & flywheel are to heavy for one person to manhandle. But that may be the solution. I do remember the sales person at Harbor Freight wanting to sell me some kind of blade sharping insurance. Though it was a scam at the time."
  • cwradio73 Mar 25, 2014
    I checked an the blades can be sharpened without the flywheel removed. One shop says you can reach down in the housing, hopper, an take them off. You will need to hold the crank shaft but it is done without without it being removed
What is wrong when bench grinder stalls out when sharping mower blades. Not too much pressure used. Grinder not equipped with a belt
since this is a vague comment, I have to say that some small grinders just do not do well with blade sharpening. I have one that does the same thing when sharpening a blade. It is just too small, horsepower wise, to handle the job.
Sep 29, 2017 | Bench Grinders
FILLET Knife sharpening
I use silicone carbide sharping stones , these keep things sharp and cool , as you never want to heat the blade while sharping them, takes the edge right off them (heat)
Jan 30, 2016 | Garden
How do i replace shere pin on lawn tractor
have to remove the fly wheel nut then remove the fly wheel. to remove the fly wheel first take off the nut on top, then use a puller if you have one or pry up on the fly wheel and tap the top shaft to it gets loose, there is a notch in the fly wheel and one on the shaft make sure you remove the broken key first then line up the two notches and insert a new pin, you can buy them at any mower shop,, or look it up on u tube on how to remove fly wheel and pin, hope this helps,
Oct 20, 2014 | John Deere Garden
Need to purchase fly wheel for Hampton Bay five blade fan 1988 model. Where could I?
I didn't know a low end fan had a flywheel. Can you send or post a pic? fanman9952@aol.com
Oct 17, 2014 | Dryers
My craftsman 190cc 625 series lawn mower stopped and a friend said that there is a pin that drops when the mower blade gets caught and stops, I'm really in need of help on how to get to the pin if possible...
Wow it's a lot of work it's called the fly wheel key that is sheard. In every case like this you have to make sure you remove the spark plug or uncap the spark plug. Remove the pull cord assembly and then use a pipe or wooden board to keep the blade from moving underneath the mower. VERY VERY IMPORTANT TO USE A CLAMP TO HOLD DOWN THE CLUTCH BRAKE AND DO NOT REMOVE IT TILL YOUR FINISHED OR YOU'LL BRAKE OFF THE BRAKE FOOT ON THE LEVER. Use a breaker bar to remove the bolt holding the fly wheel down. Now here is the hard part. The fly wheel is made of aluminum and can brake easily as well as the fly wheels blades. If it cracks or the fly wheel blade is cracked or broken it's junk. If you don't have a Briggs and Straton puller you can use a lug wrench and pry the fly wheel up. You must first place the nut back on the 1 inch bolt on the center shaft so the threads are not showing at the top of the drive shaft. You have to hit the nut on the center hard but not like to hard to brake anything. After you get the fly wheel off you have to use the model and serial number to get the key from a lawn mower shop. Place the key under the fly wheel and very carefully watch to see if it lines up as you push the fly wheel down. Push it down from side to side so it fits flush. Tighten the bolt. Don't start it first see if when you pull the pull cord it moves with out pulling the rope back into the mower. You'll have to make sure the top bolt is tight like maybe 60 pounds. MJ
Sep 29, 2014 | Garden
Craftsman excessive vibration lawn mowers problems
vibration in a walk behind mower is most always a imbalance in the blade , there lots of things that cause this , from loose blade , to bent blades
remove blade and test with blade balance , there not expensive ive seen them with a sharping stone for less than ten dollars before
pull spark plug before you remove blade 4 safety
Jun 07, 2014 | Craftsman 675 Torque 190cc 21" Briggs ...
I need to sharper the blades. How do I remove the fly wheel
The flywheel takes a puller, but you should not have to do that just to sharpen the blades.
Mar 24, 2014 | Central Machinery 5-1/2 Horsepower Chipper...
Sharping the blades
should be a bolt or two that holds them on
May 16, 2012 | Toro TimeCutter Zero Turn Lawn Mower...
Hit steel rod. bent blade. replaced blade, runs but vibrates,bad. and when you try to start it the pull cord, jerks your hand back
probably sheered fly wheel key also check to make sure crank shaft is not bent. lay mower on side air cleaner up remove spark plug wire have some one watch blade bolt while u pull rope bolt should turn with out wobble.
Aug 12, 2010 | Garden
I have a 6 hp self propelled Craftsman mower with
Ok this may be a simple fix. it has a high chance that the fly wheel key has sheared, this will cuse the timing to advance and bite your hand with the rope.
remove the pull starter and the cup ontop of the fly wheel, if you look straight down at the fly wheel nut you can see a cut out in the crank and fly wheel they should be aligned up if not it has sheared. use a lever under the fly wheel and put some pressure on to to lever it up then hit the fly wheel oposite side of the lever AWAY from the the magnet. and the fly wheel should pop up. replace the key and of you go..Make sure you use the OEM brigbs and strat key it is made out of alloy. The cause of this is the blade hitting a kerb or somthing hard,
Jul 02, 2010 | Garden
Central Machinery 5-1/2 Horsepower Chipper Shredder Logo
172 people viewed this question
Top Central Machinery Heavy Machinery Experts
Bill Boyd
Tom Chichester
ray gallant
Are you a Central Machinery Heavy Machinery Expert? Answer questions, earn points and help others
