Question about Vehicle Parts & Accessories
Where is the air intake temperature sensor on my 1998 Vw Jetta GLX
Need to replace it and i dont know where it is or how to replace
    Scholar:
  • 107 Answers
It should be located on the side of your intake manifold. It will be a screw-in fitting with a couple of wires connected to it.
Posted on Mar 24, 2014
Undefinedas replacement on civic 98 sensor p0113
Possible causes for this code are: - Faulty Intake Air Temperature (IAT) sensor
- Dirty air filter
- Intake Air Temperature (IAT) sensor harness is open or shorted
- Intake Air Temperature (IAT) sensor circuit poor electrical connection. this code sets when: - An excessively high voltage from the sensor is sent to ECM. Usual Possible symptoms - Engine Light ON (or Service Engine Soon Warning Light) P0113 1998 Honda Civic Description The Intake Air Temperature (IAT) sensor is built into mass air flow sensor or in some vehicles mounted to the air filter duct housing. The sensor detects intake air temperature and transmits a signal to the Engine Control Module (ECM).The temperature sensing unit uses a thermistor which is sensitive to the change in temperature. Electrical resistance of the thermistor decreases in response to the temperature rise. The Intake Air Temperature signal is used as an input for various systems in the vehicle.
Sep 24, 2014 | 1998 Honda Civic
Where is the ECM location on a 96 vw jetta glx 2.8l
It's in the fresh air intake at the firewall, near the center.
Sep 14, 2013 | Cars & Trucks
Vw jetta code p0128
this obd2 trouble code table can help you understand the meaning of code.
and for p0128, you can try:
Verify coolant strength & level
Verify proper cooling fan operation (check if it's running more than it should). Replace if necessary.
Verify proper engine coolant temperature (ECT) sensor operation, replace if necessary.
Verify proper intake air temperature (IAT) sensor operation, replace if necessary.
If the above items check out good, replace the thermostat
Aug 13, 2011 | Volkswagen Jetta Cars & Trucks
P1176 2000 VW JETTA ALREADY CHANGED THE 02
17584/P1176/004470 - Bank1: O2 (Lambda) Correction Behind Catalyst: Control Limit Reached Possible Causes
  • Intake Air System leaking
  • Oxygen Sensor(s) and/or Oxygen Sensor Control faulty
Possible Solutions
  • Check Intake Air System for Leaks (False Air)
  • Check Oxygen Sensor(s) and/or Oxygen Sensor Control (all of them!)
This is the pre 02 sensor located before the catalytic converter.
May 10, 2010 | 2000 Volkswagen Jetta TDI
1991 and 1997 VW Jetta Radiator??
massive size difference get the proper one or you will be overheating next
Jan 02, 2009 | 1997 Volkswagen Jetta
P103 code in a 98 VW Jetta, 2.0 liter
THAT LEAK IS UN-METERED AIR ENTERING THE ENGINE, FIX IT AND RETEST SYSTEM. P103 IS A MAF CODE. A MAF MEASURES THE AIR ENTERING THE ENGINE, AND BASED THAT AND ON OTHER DATA THE PCM DECIDES THE AMOUNT OF FUEL TO INJECT.
Aug 29, 2008 | 1998 Volkswagen Jetta
Jetta v6 lurching and almost stalling
When something in the car's faulty and a sensor picks it up and tells the computer, the computer will cause the car to do exactly that. Could be anything, from a damaged air intake sensor to the breaks.
Have your car connected to a computer and let the computer do the talking for you.
Jun 20, 2008 | 1997 Volkswagen Jetta
Vehicle Parts & Accessories Logo
74 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
