Question about RCA D52W19 52" Rear Projection Television
RCA D52W19 "crackles" and smells like its burning
My dad just called me, all upset about his RCA D52W19 "crackling" and smelling like its burning. He used it just fine last night, but it started acting up (AGAIN) this morning. The original problem was that it kept shutting off and not coming back on (this has been happening for about 3 months or so). He would wait for about 10-15 minutes and the TV would work again, but sometimes the picture would kinda do this 'flickering' thing. My dad is elderly and on a fixed income and he saved for several months to be able to afford this TV, which was $1300 when he bought it approx 4 years ago. What would cause the burning smell and the crackling noise? Is it even worth fixing, or should he just cut his losses? He has since unplugged the TV for fear that it will catch on fire. Thanks for your help :)
    Genius:
  • 1,139 Answers
Hello pmzone_guard, This problem is quite common in this TV it's due to a capacitor in the power supply being overloaded. The chassis model is a ITC222. The capacitor is located on the deflection board which is part of the power supply and should not be touch by someone that does not have TV Repair Experience, due to the fact that this area of the TV is the most dangerous. I would suggest having a qualified TV repair technician do the repair on this TV. If the problem is just that one capacitor the part will cost about $2.50 at the most, so the charge will be the cost of the part plus the labor involved. I hope this helps, Thank you, Shuttle83 http://www.electron-age-technologies-llc.com
Posted on Jun 14, 2009
Screen went black sounds of crackling and smell of burning wires
Hello
There is somethin wrong with either its EHT section or power supply section. Your description gives me very little to say a strong opinion. In both cases, it is very dangerous to handle the components at these sections. If you haven't got enough experience in handling high voltage electronic sections, never attempt to do anything with this TV. Normally EHT arcing is more common to this type RCA sets. In my opinion, get it repaired by any experienced service technician. OK.
May 24, 2011 | RCA D52W19 52" Rear Projection Television
My RCA hdtv D52W19 smells and has a crackling noise when i turn it on
Check for bad connections at a capacitor near the flyback & flyback pins - at the power supply board. Also possible - 1 or 2 bad capacitors, they can be found by the blown out top. In our shop this is a $240 repair. It is possible the red picture tube has broken and is arcing.
Jan 21, 2011 | RCA Televison & Video
ASTV3619WS went pop and burning smell
replace capactors on mains power board they will have raised tops and look like little batteries with white kine on one side replace with same value e.g (2000.mf 25v) make sure line is on same side take picture to help
Dec 16, 2009 | Televison & Video
Speaker aint hitting like it should and i smell something burning from the speaker what could this be and how can i fix it
sounds like you are frying the voice coil! Push the centre of the cone in and if you hear a crackle then time to buy new speakers.. sounds like they are on way out if you can smell burning!
Apr 19, 2009 | Volfenhag ZX-4715 Car Mid-Range
My 61 inch RCA HD TV started to shut of by itself.
RCA hdtv has a crackle then smell like something burning and then shuts off. What could the problem be
Mar 28, 2009 | RCA HD61W66 61" Projection HDTV
My te rca d52w19 model you can turn it on but within 3 seconds you can see a light then a burning smell
the starter which is what charges up the unit and sends electricity to through out in burnt out
Jan 18, 2009 | RCA D52W19 52" Rear Projection Television
No clean air smell/crackling & static
To stop the crackling sound, you need to remove all of the dust particles from the wire in the back. Sometimes when the unit is extremely dirty you can see sparks emanating from the wire, this is what causes the crackling sound. The unit has a built in cleaner you can lift up and down to perform this task, located on the top, but this doesn't work extremely well.
I usually take a can of compressed air and blow as much of the dust I can off the wire and all surrounding internal areas as I can. This along with a thorough cleaning of the blades should eliminate the crackling noise. Of course, make sure the device is unplugged before performing any cleaning.
Not sure about the smell though. Mine has started to smell a little strange and I haven't figured out how to fix that problem.
Oct 01, 2008 | Ionic Pro TURBO Air Purifier
Burning smell
the power source is trying to start and it sint. the lamp is done with because thiese tvs need high voltage. its probably melting pallastic around it . get rid of this, much money to fix up and or try getting itn fixed if stiill have legeble warranty
Jan 28, 2008 | RCA D52W19 52" Rear Projection Television
RCA D52W19 power problem
these set is what i like to call VAlue sets.. you can get these for 800 at walmart. If you smell something theres a good chance its what is called a flyback transformer... i repair that averages about 300 to replace. Caution it may be more. DANGER, Do not attempt repair of set unless qualifed to do so tv generte high and leathal voltages.
Jan 01, 2008 | RCA D52W19 52" Rear Projection Television
Panasonic pt-47wx53 problem
What does the light on the front of the TV set do. This is a self diagnostic tool. How many times does it blink?
Aug 16, 2007 | Panasonic PT-47WX53 47" Rear Projection...
RCA D52W19 52" Rear Projection Television Logo
334 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
