Question about ViewSonic VX1935wm LCD Monitor
I had my ViewSonic VX1935M-3 Lcd Monitor shut off for 2 years, I tried turning it on now and the power button flashes blue but the screen stays black. How do I fix this?
My ViewSonic Monitor (VX1935wmM-3) was shut off for roughly 2 years, I tried turning it on yesterday and I plugged 2 out of the possible 4 things in(Vga cable and Power cable) and then the power button started to flash blue but the screen wouldn't turn on, it stayed back. My laptop (Toshiba running windows 7) registered it and acted like it was perfectly fine and there was no problem with it
    Novelist:
  • 167 Answers
The absolute worst thing you can do with a piece of electronic equipment is to let it set. If as you stated the laptop registered it OK then it could be that it has lost it's memory and needs the drivers updated. The laptop will only tell you that it is connected it does not run a diagnosis on it. If you have the disc for the drivers try running it while hooked to the monitor. Other than that you may have internal problems with the monitor. It could be the inverters. logic controls and numerous other things that just seem to die of neglect I guess you could say. I have found about every kind of problem with TV's and Computers that have been mothballed for a length of time. I would think it is the drivers though. If you do not have the disc go on line to the Mfg. of the monitor and enter the model # etc. and try to find a download for the drivers. Most Mfg. have free downloads of the drivers for their equipment. Hope this gets it going and if I can be of any other assistance please feel free to contact me.
Col. Dana Gillespie
Posted on Mar 24, 2014
SOURCE: Viewsonic VX900 turns on for second then shuts off
I had to replace a fuse(F1) on the inverterboard of my VX900 to get it back to life as fuzzytek sugested.
It was replaced by a normal "flat" fuse (for cars). Had no clue about the value, so I tried with 0,5A first. It blew right away. Next value I had was 2A, and it worked! (It might be too small, and it might be too big, but I think it is better to usa a "large" fuse rather than no fuse at all. :)
Some pictures from my installation:
Posted on Apr 11, 2008
  • 7 Answers
SOURCE: ViewSonic VX922 monitor - black screen - green power light flashes
PLEASE read Carefully so here is a fix for the green blinking light ...the monitor is going into shutdown....protect mode......THIS is ...Only for the seasoned electronic service tech ......YOU NEED TO BE into Electronics ..or have electronic background and know how to solder to do this........I been doing repairs for 30 years now ..............After extencive troubleshooting and replaceing a lot of electrolitic caps on the inverter board and spending about 10 hours doing so ....i decided to eather go for broke and blow this up more or trash the unit......................Well my blinking light deal went away...my monitor you could see it trying to start and just shut down............first of all make sure you have no broken solder work on the inverter board or swelled up caps ...Thay use lead free solder so the solder work sucks also...........I did pull the main buss line from the inverter pc board that runs the transformers to test to see where the trouble is.....found its at the high voltage end of the inverter board and The viewsonic 922 uses a protection ic on the inverter board and it tells the controll ic whats the High voltage status of the inverters.....I soldered a 47uf @ 25 volt cap on pins 7&8 of ic-u2 [ bi3101a ] Pin 7 is posivtive pin 8 negative of the cap.... and then soldered pins 10 and 11 togeather on the other side of the ic.......ITs fooling that ic telling the main controll / protect line thats all is well........I would guess the whole deal is LOW inverter voltage or maybe a surface mount device thats going to go........could be low resistor tolerence also............The monitor been working for a week now.........Always on.....anyways........YOUR problem may just be bad solder or bad caps...........if you Have a electronic background or have a friend that works on electronics have him look at the caps.see if any or swelled or rounded on the top of the caps..Also chect the main plug that goes to the LCD backplane to make sure its in correctley................if all that checks then the problem is ON THE INVERTER BOARD ONLY ......befor doing what i have done......I also have a Viewsonic VA-800 that had some of the same problems also ,but it had a lot of lines on the video.......I replaced the,,,,, 2.2 mic @ 50 volt cap in the middle of the main board on it and its still running.....but has about 3/8 of white traces following all the words on the desktop...[[[ anyone that knows this fix i would like to hear from ]]] ..........NOTE if you dont know about electronics...dont attemp any of this......their is a lot of voltage on the inverter board........my answer is that these monitors are JUNK...poorley built units.....
Posted on Oct 05, 2008
SOURCE: Viewsonic monitor VG2021m won't awaken
I understand the vg2021m has a 3 year warranty. Phone number for Product Support is (800) 688-6688. Give 'em a call and see if they won't fix it for free or some nominal charge. (OK! So this is the cowards way out.)
Orval
Posted on Feb 13, 2009
  • 225 Answers
SOURCE: Black screen, power button flicks
The monitor should come when the power button is pressed once - period. If not, and it continues to happen when connected to another PC, then the hardware is having trouble powering up the panel / ccds and it should be replaced/serviced according to the terms of the warranty. I suggest to bring it to an authorized service center for proper diagnosis & fix the problem. regards
Posted on May 23, 2009
graemevm
  • 519 Answers
SOURCE: ViewSonic 19" flat screen monitor goes black - intermittently
There could be a problem with your display card settings or the display card itself. If you are using Windows operating system, make sure that you have the monitor driver installed for that specific monitor. This is to ensure that Windows only allows settings for which your particular monitor was designed.
Let me know if I can assist you any further regarding this.
Best wishes,
Graemevm
Posted on Jun 12, 2009
ViewSonic VA1930wm Screen stays on for about 2 seconds, and then goes off. 1) If no computer is connected you get a "no signal" message which stays for about 1 seconds and then goes off; blue...
Very typical of View Sonic. Sounds like a back backlight or inverter. I would go to www.viewsonic.com and open up a RMA. Most view sonic screens have a 3 year warranty. They will repair at no cost ..(if it is within that period) There is a date code on the back of the screen that will help you validate the above information.
Nov 07, 2010 | ViewSonic VA1930WM LCD Monitor
My ViewSonic VG1930WM (Black) LCD Monitor wont turn on
You need to open it up and the first place to look will be the power supply, look for bad caps with bulging top, post back what you find so we can guide you further. See example of failed VIEWSONIC monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Mar 01, 2010 | ViewSonic VG1930WM LCD Monitor
I have a Mac Mini connected to a 22'' View Sonic monitor. It has worked well for over a year. Now the monitor will come on and immediately shut off. The ''on button'' stays on (blue). I have tried...
peterballeng, Read my other response on a viewsonic VX910 in my fixya profile. You will find out your options to the black screen of death you are having trouble with. Do you know how to do the simple flashlight test for SMPS evaluation of LCD monitor power supply status! 12fixlouie on fixya, aka louie12fix Pete, sounds like SMPS is in SHUTDOWN mode. Do a comment after your evaluation.
Nov 16, 2009 | Computers & Internet
Screen goes black,power light stays green. display only stays on a couple of seconds
This happened to me and I was able to fix it. I cracked it opened and found a bad capacitor, bought a replacement at Radio Shack and I'm back in business. Actually using it right now to post this.
-Jon
May 27, 2009 | ViewSonic Optiquest Q19wb LCD Monitor
Monitor flashes on then goes black.
I think you have the display shut off. the button on the bottom left will shut screen off. It will come on for a few seconds if you touch the screen, but will shut off again. just push the display button again and it should stay on.
Apr 02, 2009 | ViewSonic OptiQuest Monitor
HP vs17 monitor power button flashes blue but screen stays black.
Try put off Monitor uplug power cord and the VGA cord for 1min and reinsert and restart your PC.
Nov 25, 2008 | HP Vs17 17" LCD Flat Panel Monitor
Orval
Oct 05, 2008 | ViewSonic Graphic VG2021m LCD Monitor
ViewSonic Monitor has trouble to wake up after been shut down.?
Well with this type of fault it is invairably a problem with the Power Supply, in the PSU Electrolytic capacitors dry out and often cause this type of exact problem... It is a relitively simple fix, by replacing the caps with new ones... Any good shop should be able to fix for a modest fee.. OR if ya know anyone handy with a soldering iron maybe they could do it for you there are generally about 4 - 6 to replace... in the PS section, just do them all to be safe..
Jul 24, 2007 | ViewSonic VX924 19" LCD Monitor
ViewSonic Monitor has trouble to wake up after been shut down?
Ok sounds to me like a power supply problem.. this a a fairly common symptom. I suggest that as a temporary fix you set the monitor to NOT turn the power off to the monitor in sleep mode if possible, in your power settings for the monitor.
ViewSonic VX1935wm LCD Monitor Logo
129 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
