Question about Fisher and Paykel Dishwashers
How to replace handle assembly
The drawer handle has broken. I have bought the replacement part and removed the front panel. The handle assembly is still on the drawer. I don't want to break anything getting it off. Looking at the new one shows clips that would break. How do I remoe this part safely?
  • Fisher and P... Master
  • 3,247 Answers
Well done.
Posted on Apr 03, 2014
SOURCE: Electrolux ESL6114 built in dishwasher door
Although it is a different model than yours, here is the link to the installation manual for an Electrolux DW and it is likely similar. The custom panel instructions begin on page 22 and show templates and how to remove and reinstall the factory door and a custom installation panel: http://www.electroluxicon.com/Files/International_English/0-999/EDW5505ESS_install_en.pdf
Posted on Oct 26, 2008
  • 11 Answers
SOURCE: Broken handle on dishwasher
Bernie,
TURN OFF POWER TO UNIT. Open door, remove all torq screws from door panel, separate inner and outer door panel. latch assy is able to be removed, place black wire connector and white white connector back respectively, place inner part of door back and replace the torq screws. Then turn power back on for unit.
Posted on Jan 10, 2009
jsrock516
  • 5911 Answers
SOURCE: Handle is broken.. how to replace?
This is not a difficult repair. If the model number you have this listed under is correct, all you should have to do is follow these steps:
1. Turn off the power breaker, or unplug the dishwasher.
2. Open the dishwasher door and locate the screws around the perimeter of the inner door panel. These are torx, size T-2, I believe. Remove the screws directly behind the control panel and only loosen the remaining ones. This will enable you to remove only the control panel without having to remove the entire front panel facing.
3. If only the handle is broken, all you have to do is remove the the screws holding the latch assembly in place and lift out of the way. The door handle should lift out from the rear and a new one can easily be inserted.
4. If the latch assembly is broken, I would recommend replacing the small switches that plug into the latch assembly as well. They typically break when attempting to unplug the wires from the terminals, because they are so fragile.
Appliancepartspros.com has all the parts you need, along with some excellent exploded view diagrams you can use for reference. The parts that I am talking about are items 3, 4, and 5 under the "Control Panel" heading.
Item 3 is the Door Handle
Item 4 is the Door Switch
Item 5 is the Latch Assembly
Here are some more sites you may also try for cost comparison:
searspartsdirect.com
pcappliancerepair.com
repairclinic.com
If you have questions about this repair, or if the model number is not correct, please post back with your complete model number so that I may be able to provide you with better assistance. I hope you find this information helpful.
Posted on Aug 22, 2009
TeepOrange
SOURCE: Westinghouse SB907 Top Draw Clips Replacement
Probably too late for you now :( I found this site.
http://spares.alliedappliance.com.au/
If you happen to have yours fixed, I would love instructions on how to reattach my top drawer to the clips! Can't find an image anywhere and just can't figure it out. sigh.
Posted on Jun 13, 2010
  • 3247 Answers
SOURCE: need to remove front drawer panel
There are two plastic bolts on each side of the dishwasher drawer holding the front cover. Get a plier to pull these out but make sure the cover is supported so that it does not fall down.
see installation manual page 7. The location of the plastic screws is shown in insert diagram of notation 6. This is for a later model but yours should be similar.
Hope this helps. Wonder why you want to remove the front cover?
Posted on Jul 08, 2010
For LG front load washer WM1355HW I need to replace the broken door handle. This seems like a relatively easy task. Any help with this would be appreciated, I suspect it might require removing the i
Remove the countersunk screws from the door inner panel to access the handle assembly.
The manufacturers part number: LG (OEM) Part #MEB61281101
Sep 27, 2014 | LG WM Washing Machines
I need to replace the 3 button control panel which is one piece along the top of the draw many thanks wayne
Hi - this should help you out ..... enjoy.
9.1 Drawer Front Removal
9.1.1 Slide open drawer.
9.1.2 Locate draw pin on either side of the tub.
9.1.3 Using a sharp pair of long nose pliers or slip jaw pliers grasp the center dividing web of the pin and pull away from the tub to remove the pin. Support the drawer front with your hand while doing this. Note: The pin web is vertical.
9.1.4 With both pins removed the bottom of the drawer front can now be eased out slightly.
9.1.5 Now carefully pull the drawer front down to allow it to come free from the handle and top locating slots.
9.1.6 Carefully remove the earth wire from the tab on the drawer front. (if it is an integrated model you will also need to unplug the integrated badge from the isolating module)
9.1.7 Refit in reverse manner ensuring the drawer slides are right forward and the pin secures through the hook on the front end of the slide.
Note: When reinserting the pins make sure the dividing web is vertical.
9.2 Tub Removal
9.2.1 Open the drawer fully.
9.2.2 Depress the right-hand tub clip and push it back about 30mm (1 inch). Repeat for the left-hand side.
9.2.3 The tub may now be lifted up off the drawer runners.
9.2.4 Slide both runners back into the product.
9.2.5 Refit in reverse manner.
Drawer and LCD Display Removal
9.3.1 Remove the drawer front as per instructions in 9.1.
9.3.2 The handle fits onto a lip at the top of the tub and then slides from left to right to lock into place. Push the right-hand end of the handle to the left until it feels free then remove it out towards you.
9.3.3 Disconnect the six wire harness from the electronic controller to the LCD interface.
9.3.4 The handle may now be lifted clear. The LCD display is held in place by a spring tab on one
end and a clip in the centre. Use a small blade screwdriver to carefully release the tab and centre clip as shown. The LCD assembly can now be removed.
9.3.5 The wiring harness can now be unplugged from the LCD.
9.3.6 Refit in reverse manner.
Jul 07, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
ReMoving door panel to replace door lock actuator for 2003 ford thunderbird
please rate highly if this helps.
Front Door Trim Panel adobe.gif Printable View (126 KB)
  1. Disconnect the battery. For additional information, refer to Section 414-00.
  1. Remove the components in the order indicated in the following illustration and table.
    Item Part Number Description 1 23712 Sail panel 2 221A18 Door handle cup cover 3 W706476-S424 Screw 4 237A98 Door handle cup assembly
    Removal Note 5 18978 Speaker cover 6 - Speaker electrical connector (Part of 18808) 7 W706476-S424 Screws (7 req'd) 8 23942 Door trim panel
    Removal Note
  1. To install, reverse the removal procedure.
Item 4: Door Handle Cup Assembly Removal Note
  1. Lift up at the front of the door handle cup assembly, move it forward to remove and disconnect the electrical connectors.
Item 8: Door Trim Panel Removal Note
  1. If equipped, disconnect the electrical connector.
Jul 01, 2011 | Ford Thunderbird Cars & Trucks
I have a 1997 F-250 HD. Driver door latch cable is broken at the handle end. I have a replacement cable, but need help figuring out how to remove the broken cable without breaking the plastic rod...
Door Handle/Latch Assembly NOTE: Due to the conversion from single 90-degree rod end shape to double 90-degree rod end shape, it may be necessary to remove more parts than the instructions indicate. This action will allow more maneuverability of the rod and ease the removal process.
Handle, Outside Door, Front Removal
  1. Remove the front door trim panel (23942) and front door trim shield (237A04) from the front door (20124). Refer to Section 01-05 .
  1. Disconnect the front door latch actuating rod (22152) from the handle link connector.
  1. Remove one nut and screw.
  1. Remove handle and pads from door.
Some rods are double 90 degree rods, they require the handle or lach to be free when the rod is attached.
Some have plastic clips that slide onto the rod. they pop off sideways.
May 06, 2011 | Ford F-250 Cars & Trucks
Have LG 1812 front load washer, it is making noise when water tries to drain out, we were able to drain the hose but unable to remove the drain pump filter-just spins
Unscrew the drain pump filter counterclockwise to remove it from the pump assembly. If it cannot be removed, you need to replace the pump casing (part #3108ER1001B) and the pump filter (part #383EER2001A).
Disconnect power to the washer prior to servicing to avoid the risk of electric shock.
Remove the two screws at the rear of the top panel attaching it to the cabinet. Slide the panel rearward then lift it off the washer.
Disconnect the control panel wiring harness from the main board assembly. Pull the dispenser drawer out until it stops then press the locking tab and pull the drawer out completely.
Remove the two screws from the drawer opening then lift the left side of the console and pull it off the cabinet.
Remove the three screws from the upper part of the front panel and the screw from the filter cover.
Insert a putty knife blade or similar flat tool in both sides of the filter cover then pull it out of the cabinet. Remove the screw from the lower side of the front panel.
Open the washer door and remove the wire and spring holding the door gasket to the outer lip of the door opening. Stretch the spring with a pair of needle-nose pliers to clear the wire off the lip of the door opening then remove the wire and spring assembly.
Peel off the door gasket into the drum then tilt the front panel and disconnect the door switch wiring harness from the door switch terminals. Lift the front panel and remove it from the cabinet.
Compress the spring clamps holding the pump inlet and outlet hoses then move the clamps away from the pump casing.
Remove the two screws securing the pump to the base of the washer. Press down the tab at the back of the pump assembly and push the assembly into the washer then lift the pump assembly up and out of the washer. Remove the hoses from the pump assembly.
Unscrew the pump from the casing and inspect the impeller for any damage. Rotate the impeller to check whether there's restriction. Replace the pump (part #4681EA2001D) if the impeller is broken or does not rotate freely.
Install the pump assembly and reassemble the washer by reversing the given disassembly steps.
Mar 20, 2010 | LG WM1812C Front Load Washer
The handle on theMaytag Dishwasher Quiet Series 200 broke.
The handle is very easy to replace, you will have to get a new one , it comes as an assembly. To replace it open the door, and at the top inside you will see 5 screws, remove them, you will then be able to tilt the top plastic outer piece forward and expose the handle assembly, remove the 2 screws holding the assembly in and install new handle, reinstall front and screws you removed , your done !
Nov 11, 2009 | Dishwashers
repairclinic.com
Aug 22, 2009 | Maytag MDB9600A Jetclean II Built-in...
Jaguar xj8. 1999. front passenger door will not open from inside. how do I remove interior door panel, and how to fix.
More than likely the door handle assembly is broken. The chrome handle has a pin running through it and through 2 "ears" of a plastic part that creats a pivit point for the handle. One of the plastic ears (probably the bottom one) has broken loose. Glueing it will not hold long if at all. The accepted repair is to replace the handle assembly which consists of a Plastic mounting block of which the "ears" are part, a chrome handle, and a pivot pin. You can buy this assembly used on Ebay at this time (August 2010) for between fifty and seventy dollars including shipping, but you are buying a seven to twelve year old part out of a junked car with the same inherrent weakness as your broken one had. How long the part will last is anyone's guess. My guess is "not long". You can buy a new one that will probably last as long as the original one did, or you can repair the part by fabricating a metal replacement "ear" and attaching it to the Plastic part with very small screws or nuts and bolts as I did. To perform either repair you must remove the inside door panel. In the plastic handle recess there is a small circular plug that can be removed with a thin pointed tool. It reveals a phillips screw that must be removed. Remove the plastic recess part. There is another long screw on the underside of the armrest/handle. With these removed there a number of male to female plastic plugs that can be seperated with a dedicated tool or a flat tool like a common screw driver. Insert tool between the door trim panel and the door at each plug and pry the panel from the door a half inch or so. With all the plugs seperated wiggle and carefully lift the panel over the verticle locking stud because there are 3 wires that must be un plugged. After unpluging the wires, put the panel aside in a safe place. The handle assembly is removed by sliding it toward the front of the car and then removing the cable. Repair or replace the assembly and reassemble in reverse order. Good luck.
Apr 29, 2009 | 1998 Jaguar XJ8L
Replacing the driver side inside door handle
Find and remove two screws visible on the door panel, including underneath small covers. Pop them off with a small screwdriver. Lift front edge of control panel, then pull forward and lift out. Pull upper door panel from door. Disconnect courtesy light connector. Disconnect door open handle cable assembly and door lock cable assembly. You might need to lift panel and twist to get it off.
Feb 23, 2009 | 1998 Lexus Sc 300
2002 Nissan Altima Exterior Door Handle
I seriously doubt that supergluing or even epoxying a handle back will hold at all, or hold for more then few days.
I would only suggest doing the replacement yourself if you familiar with this type of work, or has the aptitude to figure out how to do it, and have the right tools because it is NOT trivial and a number of things can be done wrong, broken or scratched.
The handle itself cannot be replaced. The outside door handle assembly (which includes the handle, the bezel with all associated springs, plastic and metal hardware) has to be replaced. Besides junkyards, which is a long shot for number of reasons, the only place where the handle assembly can be bought is the dealer. And these handle assemblies are not cheap ether. The driver side handle on my 2002 Altima broke first. I paid $60.23+tax, and they had to order it. BEFORE anyone goes to the dealer I suggest to call first, and ask them if they have it in stock. Since door handles are sold painted they will ask you for your car's VIN number so that they match the paint color.
After you pick it up, the replacement will take about an hour (if you know what you doing). The inside door panel has to be removed, it is held in place by the inside door handle and the panel is attached by a number of clips, the handle assembly is attached to the door by three bolts, to remove which you will need a socket with extension. You will also need a good flashlight so you see what you are doing.
If you are familiar how to do this type of work and plan to keep the car for a while I strongly suggest buying a factory service manual on a CD (I bought mine on eBay for under $10). It is worth its price 1000s of times over, and makes almost ALL repair work SOOO much easier.751424a.jpg73e3811.jpgd240851.jpg
Jan 08, 2009 | 2002 Nissan Altima
Dishwashers Logo
315 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
