Question about Home
Warped backsplash bbq griddle
I used my backsplash bbq griddle on top of a mountain stove and it got warped
  • Joe Garcia
    Joe Garcia Mar 24, 2014
    Hi Maria Bailey, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?so what is your question??
  • 33 Answers
SOURCE: GE Stove
check all holes on burner make sure all air/gas holes are unclogged do not use any ajax or any cleanser that will leave a powdery residue.
Posted on Jan 04, 2008
  • 833 Answers
SOURCE: Is it all right to
I would avoid it unless the manufacturer says its okay.  I'd get in touch with them.
You did not say what kind of heating system the unit has.  Induction units will not work right with multi-burner systems and other systems such as radiant burners will cause heating that is not in the right places.
Posted on Dec 12, 2008
kachbibi1
  • 979 Answers
SOURCE: GE 40" range griddle
You will have to check GE. With a model this old, it will be hard to find a replacement.
Posted on Feb 11, 2009
localwonder
  • 6784 Answers
SOURCE: stove top elements f1 error code
Hi. you can try to reset the electronic oven control by unplugging the unit for 3 mins. if the problem still exist, you will have to replace the clock/control(electronic range control).
please rate and god bless:)
Posted on Apr 02, 2009
  • 2517 Answers
SOURCE: i would like to replace my griddle on mf fire and
Go to www.pronto.com for spares
Posted on May 25, 2010
Cooking element on stove top goes on full heat,even when dial is set on low.
Electric, I presume. Disconnect power to stove, open backsplash, remove knob, replace control unit.(usually universal type). Available appliance repair shop. Careful with 220volt power!!!!
Sep 20, 2014 | Kitchen Ranges
Need part number for BBQ option to replace griddle
You will need the model number & serial number which may be on the back of the cooker on behind the plate under the oven door, then contact the manufacturer or agent. Reece HVAC are also a very good source to obtain parts from.
May 07, 2014 | KitchenAid KDRP463LSS Dual Fuel (Electric...
How do I season the griddle that came with my new gas stove?
This is taken verbatim from page 11 of my Frigidaire Gallery range:
"Seasoning, using and caring for the griddle Before first use: -Wash griddle in hot soapy water. Rinse and dry completely. -Apply a thin coat of vegetable oil to the entire surface (front and back of griddle). -Preheat your oven to 350*F. Place the griddle on the upper rack in your oven. -Bake griddle for 1 hour at 350*F, then turn oven OFF and let cool before removing. -The surface may have a tacky feel to it from the seasoning process. If desired, wash the griddle in hot soapy water, rinse well, and dry completely.
Using the griddle: Remove the center burner grate and carefully replace with the griddle (some models). Preheat the griddle for 5 minutes on medium to medium low setting. Slow preheat ensures even heat distribution during the cooking process. DO NOT preheat the griddle on HI setting. Preheating on HI may warp the griddle and prevent even heat distribution.
After each use: -To prevent rusting, store in a dry place and keep uncovered. -After each use, clean with a stiff brush and hot water only. -Do not clean griddle in the dishwasher. -Dry immediately and apply a light coating of vegetable oil to griddle before storing.
Sep 20, 2010 | Frigidaire 30" Self-Cleaning Slide-In Gas...
Griddle makes backfire noise
I get the same sound but I found it is actually coming from my stainless steel backsplash, it seems like the heat makes it flex from time to time.
Jul 10, 2010 | Viking VGIC485-6G Gas Kitchen Range
Griddle is warped
Hi, are you sure the griddle is warped, and doesn't just need to be shimmed on one of the corners ? that is all it may take to level it up again, some of the shims may have fallen out and are sitting underneath the griddle surface somewhere. Hope that helps, and thank you.
Jan 04, 2009 | Garland H283 Gas Kitchen Range
GE Stove
Nov 30, 2007 | Cooktops
HELP!! No contact # or web
I have two NEW 14" BBQ Grill Kits available.
Nov 30, 2007 | Rocky Mountain Range Yellowstone Grill
Home Logo
411 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
