Question about Boating
1996 jet ski problems
I cant get enough speed even when its matted, smoke comes out the back of burning oil and it shutters
    Champion:
  • 207 Answers
What kind of ski? do a compression test and change the plugs 1st and comment me back ill be looking for you well figure it out if you have 90 psi for a yamaha or 100+ for a seadoo or kawi
Posted on Jun 27, 2009
I have a 1994 Tigershark Daytona. It has two carb. It has 2 cycle oil in the intake below the carbs. Is this normal for that model?
It is oil injected and if it has been sitting for a long period of time the oil will seep into the intake. This is common on older watercraft. When you get it initially started it will make a huge cloud of smoke and take a few minutes to clear up( burning the excessive amount of oil)
Feb 09, 2017 | kawasaki 2010 Jet Ski Ultra 260X
My jet ski is lacking power. It ceases to accelerate after 15kph
this jet ski has over 300 hp so should go much faster than this , but now it does have a few features /items that others do not have , one feature in particular that comes to my mind after hearing your description is its smart learning operation mode , or simply refered to as SLO Mode its activated by operators choice of key , do you have a red/blk key or a blu/blk key in the dash ?
since its engine is supercharged there are some other causes that could produce a power loss id consult a watercraft tech for more details as this machine is loaded with diag tech stuff to help a tech figure out whats wrong with it quickly
Nov 14, 2015 | kawasaki 2015 Jet Ski Ultra 310X
My yamaha jet ski doing black smoke
If it is a 2 stroke and it smoke black then your main seals on the crank is leaking so the motor suck oil from the transmission case into the motor and burn it with the fuel
Mar 15, 2015 | Yamaha Motorcycles
What couse the blue smoke
Blue smoke from the exhaust typically indicates oil is being burned in the combustion chamber. The term blow-by refers to engine oil being pushed by the piston rings or through the valve guides. If the problem is severe, an engine re-build or engine replacement is in order. After a few miles of running, the oil has had a chance to warm up, which makes it thinner in viscosity.You may try switching to a higher viscosity oil -10-40 weight, etc. Also, there are additives sold on the market for the purpose of sealing off piston rings, etc. You can also try one of these products. Good Luck !!!!
Mar 12, 2014 | 1998-2002 Saab 9-3 Designer Auto Mat Floor...
Jet ski smoking
what colour smoke , correct fuel ??
Jan 04, 2014 | Yamaha Wave Raider 700 760 1100 Waveraider...
Jet ski bogs out under load.
I had a similar experience with that model. It turned out to be a mouse nest in the water box. However , in this case i think you just have some moisture corrosion on the rubber tipped needle in the carburetor. Clean that part of the carb and do not alter the tiny spring in any way. If that does not work open the electronics box, if it is wet , dry it out , and seal it back up. Those are the three things I know of that will cause your problem. Start with the carb.
Apr 06, 2010 | Encore Software Kawasaki Jet Ski...
Only runs half throttle
so, can you tell me what kind of carb was on the bike before? was it factory? and what kind of carb was just installed? blue smoke can be caused by burning transmission oil or a rich fuel mixture. that might be a bad crank seal or case gasket, or just improper fuel/oil ratio or improper jetting. black smoke on the other hand is usually caused by too much gasoline burning, but if there were enough gas entering the engine to cause black smoke, the bike probably wouldnt run at all. but, if you can give me more info on the carb swap, and if possible any jetting information or jetting changes, thenI can definitely tell you what your problem is.
Sep 04, 2009 | 2003 Yamaha YZ 250
Jet ski will not run at full throttle
Check for holes in the diaphram the pulses the needle and seat in the carb.
Jul 23, 2009 | Sport & Outdoor - Others
Boating Logo
300 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
