Question about Sceptre X32BV-Naga 32 in. LCD TV
Military time on screen display
Get rid of military time on screen display
How do I get from military time back to standard time?
ah, 24 hour clock display to 12 hour display. Go to the manufacturers website, look for support and go to manuals. If you had included this information, I could have done it, but it is my bedtime :>)
Sep 13, 2015 | Military Time Watches
How do i stop military time on my asus pc? or change it
You need to go into your control panel, find the regional settings. There you can set the correct time zone, display of numbers and degrees.
The way in there varies from windows to windows, but usually you can do a run/search in the start menu and it will pop up (searching for the control panel).
You need to be administrator for the changes to be permanent.
Feb 21, 2015 | ASUS Computers & Internet
Turn off military time
This baffled me for a bit...Finally I just took the batteries out, then put them right back in and it was no longer on military time.
Apr 06, 2013 | Brookstone LEGO Ninjago Kai Mini-figure...
Change time
1. Begin on the main sales screen
2. Press the purple MORE key twice
3. Choose OTHER SET UP from the display screen
4. Type in your password if applicable
5. Press the purple MORE key until the display reads SET DATE/TIME
6. Choose SET DATE/TIME from the display screen
7. Type in the date mm/dd/yyyy
8. Type in the time HH:MM:SS in Military Time
9. Press ENTER
10. Press the red CANCEL key
Mar 11, 2012 | VeriFone VX510
My timex indiglo Ironman triathlon watchhas twelve hours of military time and then twelve hours of regullar time. HOW CAN I GET RID OF THE MILITARY TIME AND GET ALL TWENTY FOUR HOURS OF REGULAR TIME???...
Actually all the hours are military time. They are the same for the first twelve hours of the day. If you go through the setting procedure it will ask you if you want "12" or "24" hour time. Select 12. "24" is military
May 23, 2011 | Timex 27191 Wristwatch
How do i get my athletic watch off of military time? It's a water resistant watch up to 165 ft. model # aw60447w
military time:
1. When setting the time on your watch, IF you watch can change to Military time(and most can)
2. when you are adjusting the hours go through a full 24 hour cycle. You'll notice that the 2nd time through it is on military time.. 3rd time through back to 12 hour day AM/PM cycle .. 4th time back to Military.
So you can do this as many times as it takes to get to the right time ..
In 24 hour time you will see an "H" displayed where you normally see and "A" for AM and "P" for pm.
Sep 23, 2009 | Watches
Regular Time, Military Time
I believe it's a DIY. Find the owners manuel. You probably have to save it in standard time.
Jan 02, 2009 | 1998 Jeep Grand Cherokee
Getting the clock off military time
This is controlled by hardwired switch (12/24) OR digitally during menu setup sequence.
Sep 17, 2017 | Audio Players & Recorders
Set watch
I have a G Shock DW-004 made in 1997. I had this same problem, and I tried everything to change TO military time and back to standard time. I just read the bit to try and was about to do it. I pressed the top left button to get the time to flash, and hit the light button by accident (the one with the big G on it) and VIOLA! It changed to military time. So in my model, anyway, the G light button (under the display on the edge of the watch body) changed the time to military from standard and back again, when the time is flashing.
Feb 21, 2008 | Watches
With the sytem off, hold down the Alarm Setup button and the On/Off button to switch between 12 hour (AM/PM) and 24 hour (Military) time. If you need the manual go to
http://www.bose.com/controller?event=VIEW_STATIC_PAGE_EVENT&url=/customer_service/owners/guides/music_system.jsp
Nov 28, 2007 | Bose Wave Radio
Sceptre X32BV-Naga 32 in. LCD TV Logo
48 people viewed this question
Top Sceptre Televison & Video Experts
Henry  Thomas
Henry Thomas
Are you a Sceptre Televison and Video Expert? Answer questions, earn points and help others
