Question about HP Pavilion dv9000z Notebook
Posible problem of never restart again
Can not restart
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 174 Answers
Reinstall os
Posted on Mar 26, 2014
Why my engine wont restart after it dies
some electrical part is over eating posible fuel pump
Sep 04, 2014 | Cars & Trucks
Trunk won't close
If after every re-adjustment the trunk close only to refuse to close after sometime, it is posible that striker is not tight enough and probably shifting after some uses. It is likely also that the threads on the bolts or screws are worn lightly. If posible try using a spring washer or some threadlocker medium strenght.
Jan 31, 2014 | 1995 Nissan Altima
My yahoo masanger is shwoing full blank i culd not abel to see who is online evn im nt getting rpely on that i download agai again new masanger but it showing same problem so pls help as soon as posible...
Hmm, well... you may have scripting disabled in your Internet Explorer.
To enable scripting:
Click the "Tools" menu on your Internet Explorer toolbar and select "Internet Options."
Click the "Security" tab.
Click the Internet (globe) icon and click the "Custom Level" button.
Scroll down to "Scripting."
Enable the following:
Active scripting
Allow paste operations via script
Scripting of Java applets are all enabled
Click the OK button at the bottom of the window.
Note: Restart Yahoo! Messenger and you should start seeing text in your IM windows again.
Nov 06, 2010 | Yahoo Messenger
I conneccted my new pc with windows7 to LG 775N and i was able to install the OS but latre after restarting it came up with a message "out of frequency" and monitor shuts off. any solution please. thanks...
If you have the posibility try to connect to another monitor and then set the rezolution to minimum (800 x 640 or 1024 x 768) and set the frequency to minimum also (about 60 or 72) and then after the shutdown connect the LG monitor. If all it's ok try to resize to maximum refresh rate (for 1024 x 768 is 85 Hz or for 1280 x 1024 is 60 Hz).
If you don't have any other monitor try to enter in Safe Mode (press F8 key before entering in operating system). After that right click on my computer icon from desktop or from Start Menu and from the Management, Device Manager - Display Adapter right click on video adapter name and choose uninstall and then restart. After restart windows should detect again the card and the monitor.
Apr 09, 2010 | LG Studioworks 775N 17" CRT Monitor
Carrier Low pressure lockout - 4 hours Code 83 The system is less than 1 half years old. Will it start cooling again after four hours? Infinity control shows Fan - On, A/C - off
If the low pressure sensor trips, the least likely problem is a bad sensor, more than likely, you have a leak in the system, this will require leak location, repair and recharged.
Also posible, a dirty air filter, plugged indoor coil, causing the indoor coil to ice up, causing a temporary low pressure issue, solution would be to clean the coils, power the system down and restart and test.
If this has been helpful, please rate the new guy :)
If you have any other questions, please give me a shout.
Sincerely,
Paul Gibson
Apr 06, 2010 | Heating & Cooling
I taken mz laptop n for repair and now mz y is z and all mz szmbols are not what thez saz thez are like mz @ sign is ć how do i fix it (question mark) thats broen to
1. Posible issue with the hardware, might affedted by the repair process.
2. Trouble shooting - restart computer (make sure it is completely before turning back on)
3. Press Fn key hold then numlock key together then release (posible that the numlock is on so you need to turn it off)
4. If it is the same issue - send it back to the tech who fix that he might done something on the hardware part.
Mar 28, 2010 | Acer Aspire 5500 5570-2609 Laptop
Gaggia TS Espresso Machine although my machine seams to work OK, It does not seam to produce much steam any help would great
Their is a grait posibility that the steam want is blocked from dry milk that is why you have weaker steam out. So you can first try to boil only water for some minutes and then leave the steam want in for more than 30 minutes. Then try the steam again and posibly the dry milk will be spit out. You can even boil the water with some cooking soda in it which can help more.
One more think that can help to clean the steam wand is to use a thin flexible steel wire in the steam wand so it can clean it more.
This is the most posible solutions you can try.
Good Luck
Mar 22, 2010 | Gaggia TS Espresso Machine
Air bag light is flashing. Car then sputters
It is a short in one of the ignition wire, car start, and while drive wire get hot and in
short circuit, drain the battery and posible burn the diodes in the alternator.
Identify wire and replace
Feb 23, 2010 | 1999 Nissan Altima
Went to plug in. Green light came on, no heat.
it's posible to have a disconected wire or a heating element burned. also is posible to have a problem whit saftey thermostat. good luck!
Feb 20, 2010 | Cuisinart WM-SW2 Sandwich Maker
I just bought aused computor with a mi wireless keyboard and mouse. The keyboard works fine but do I need somthing for the mouse to work?
you probably have a reset button on transmitter and posibly on bottom of mouse make sure you reset them
restart pc and if it still does'nt work I would run software again
Dec 07, 2008 | Micro Innovations PD7250LSR Wireless RF...
HP Pavilion dv9000z Notebook Logo
18 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
